8th scale Pontiac.
+2
6 posters
Page 1 of 2 1, 2  Next
8th scale Pontiac. Empty 8th scale Pontiac.
Post by Ron234 Sat 07 Sep 2024, 11:38 am
Good day folks. :grin:
A massive package arrived yesterday - from my son, as he thought I looked a little down last time he saw me. I have told him before that my model building is on hold, but I guess he wanted to put a smile on my face, which it did.
I have been pondering buying this model since it was released, because I really dislike the ‘79 nose cone, and often wondered why it wasn’t the more popular 1977 version - but I presume that will have heavy copyrights on it being the Smokey and the Bandit car.
The model is huge compared to the ‘32 Fords and ‘T’ rods that I build.
Anyways, I may not be building this car any time soon, but I do have plans.
The ‘79 nose cone WILL have to be altered to appear as the preferred ‘77, lights, grille and slimmer bumper - I’d also slim down the rear bumper too.
The ‘T’ roof would be glued down, filled and sanded smooth to make it a tin-top. The lattice alloy wheels are not to my taste either, so they will have to go.
….and as I can never build a ‘stock’ car, I’d make this into a weekend racer, and loose the rear seats and fit a simple roll hoop.
These cars were never popular on a drag strip, nor many used in circuit racing, so I still have to think what slot to fit the car into regards being used in competition….or just leave it as a street racer? The availability of parts to do any conversion is of course dependent on the final outcome.
But don’t hold your breath to see this car built as I still have 4 other 1/8th models in the pipeline. I’ll add updates as and when I tackle it.
Cheers, Ron. :grin:
8th scale Pontiac. Img_0319
Ron234
Ron234
8th scale Pontiac. Empty Re: 8th scale Pontiac.
Post by Ron234 Sat 07 Sep 2024, 3:09 pm
I couldn’t resist a test of these Halibrand wheels.
8th scale Pontiac. Img_0320
Ron234
Ron234
Post by Mr Hirakawa Sun 08 Sep 2024, 12:25 pm
It looks quite big next to your organ there. Tell me, how detailed is the provided engine in such a large scale? I would expect it would be quite ready for loads of detail but my experience with larger scales has disappointed. I'm also a tight git and would blanch at the amount of paint needed to cover it.
Ron234 likes this post
Post by Ron234 Tue 10 Sep 2024, 11:45 am
Hi, yep, this model will end up being about 2ft long, once nose and bumpers are added - so quite a size.
…..but yes, size doesn’t always mean quality, in fact it is similar to the 1/8th.’65 Corvettes that I have and lacks a lot in terms of fit and detail parts. It’s as if they have simply enlarged an old 1/25th scale model.
Unlike the 1/8th.hot rod kits there are no vinyl /rubber hoses and ignition wires, no options, even the moulded exhausts and certain rounded parts are hollow to the rear - half a part, if you will. I certainly could build this kit without the instructions.
Although I did say I wouldn’t be building this kit soon, I was tempted, and have already started to trim up the body of flash, glued in the roof panels ready for sanding and filling, and built the engine up in stages ready for paint.
It will certainly need a lot of extra detail to be up to my usual standards, such as sanding off the moulded hoses in the engine compartment to replace them with tubing - but currently my ability to move about as I once did will hinder progress.
However, I did find a UK class for racing these cars on the Classic Sports Car Club website - and that is the ‘Future Classics’ series, for cars of all sizes from the 1970/80’s, so it might end up in racing colours.
8th scale Pontiac. Img_0410
8th scale Pontiac. Img_0411
Ron234
Ron234
Post by Sam Thu 12 Sep 2024, 7:11 pm
Oh yeah! I have this on the shelf as well. I have heard that the hood is slightly warped on this one, and mine is no difference. Looking forward to seeing your take on it.
Post by Ron234 Thu 12 Sep 2024, 9:45 pm
Yep the hood is I believe a problem with most, as it has very little support underneath to give it any rigidity.
Mine will need heat to give it some curve as it is a little flat and in no way will it sit correctly in place.
Ron234
Ron234
Post by Sam Fri 13 Sep 2024, 12:06 am
A little heat, and maybe a little under hood construction to keep it that way? 🤔
webby and Ron234 like this post
Post by Ron234 Fri 13 Sep 2024, 7:49 pm
Meanwhile…..in the bodyshop - after the first skim of filler.
My plans are not to stick to the Trans Am Firebird T top formula - deleting the $650 option, and creating a tintop Firebird race car. Making it a competition car means I can take liberties with changes and details, and it stops the purists trying to find faults in the build.
8th scale Pontiac. Img_0412
Ron234
Ron234
Post by Sam Fri 13 Sep 2024, 9:37 pm
Looking good.
Post by Ron234 Sat 14 Sep 2024, 11:41 am
After mowing my lawns - which now takes me two days, when it once took two hours, i espied a spade in my shed with a gently curved blade which might make a good former to heat my bonnet/hood over.
The question is, when I get around to shaping the hood, will I remember this useful hack ? 😁
Ron234
Ron234
Sam likes this post
Post by Ron234 Sun 15 Sep 2024, 3:30 pm
The Tin-top T/A moves on : Second skim of filler added and sanded roughly - and a quick guide coat of paint which will be lightly sanded to show the high and low spots - and where the next lot of filler is going. 🥴
8th scale Pontiac. Img_0413
8th scale Pontiac. Img_0414
Ron234
Ron234
Post by Sam Sun 15 Sep 2024, 4:56 pm
Whatever happened to "Anyways, I may not be building this car any time soon". 🙃
I have been toying with the idea of turning mine into one of the cars from Rockford Files.
I do know that an aftermarket company makes a much better rendition of the screaming chicken as well as the rest of the decals, just for this kit.
Post by dublin boy Tue 17 Sep 2024, 5:30 pm
Jim Rockford briefly had the facelift twin square headlight version Ron, I preferred the original, but I think this has the original tail lights but what do I know, was MIA in Coventry.
Nice start
https://www.google.com/search?q=Jim+Rockford+pontiac+Firebirds+vids&rlz=1C1GCEA_enIE1096IE1096&oq=Jim+Rockford+pontiac+Firebirds+vids&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIJCAEQIRgKGKABMgkIAhAhGAoYoAHSAQkyODU4MWowajeoAgCwAgA&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:d1185c45,vid:R_el2PwnqjE,st:0
Post by Ron234 Wed 18 Sep 2024, 11:27 pm
Well Sam, I had no intention of starting the kit, but it never travelled up to my loft work room, and sat on my desk looking at me each day……I just couldn’t help myself !
I briefly looked at making the car into a cheaper model, but altering the nose and bumpers was going to be a big enough job without having to loose the add-on wheel flares and rear spoiler - that I decided against it.
The Decals? Being an awkward sod, I had no plans of using them in the build - and actually put the Revell sheet on ebay for £20, and it sold within the hour….gone !
Hi Shay, yep I recall Jim Rockfords tidy looking Gold Firebird Esprit, but don’t recall the later ugly ‘79 version. I heard somewhere that the car with the 1977 look, was just the old car with a new nosejob, thus the same Esprit trim, wheels, etc.,as the old one, and they both carry the same licence plate.
Ron234
Ron234
Post by Ron234 Thu 19 Sep 2024, 9:44 am
After doing a little research - if the Rockford’s early car was transformed, it would need a hood too - maybe it was given a make over, but it might have only been used for stunt scenes. However, photos of the two cars appear to be different shades of gold in most photos I have found….which kinda sinks the theory of ‘just a nose-job’.
I’m presuming that Pontiac furnished the cars for the show, and highlighting their latest model wouldn’t be a great cost to them to replace the cars.
I can only find one photo relating to the ‘79 Firebird - that of a presumed Formula model with snowflake wheels.
8th scale Pontiac. Img_0415
8th scale Pontiac. Img_0416
8th scale Pontiac. Img_0417
Ron234
Ron234
Post by dublin boy Thu 19 Sep 2024, 12:57 pm
Even with much more options in 1/25 scale, I seem to rember it's difficult to re-create the big block Rockford Esprit Ron.
Or am I tempting you....lol
Post by Ron234 Thu 19 Sep 2024, 1:10 pm
I’m making this build easier than most Shay….it’ll come almost out of the box, with a bit more detailing, and a dash of boy racer ,
Just like working on real cars, bodywork is a case of filling, sanding, filling, sanding, using smoother and smoother wet and dry papers - then adding more filler. Like real cars I use car filler on my models, but Stopper, meant for pin holes is a little too soft even at this scale. Not finished yet.
I’ve started to add more plastic strip around the inside of the pillars to give the body more thickness and rigidity - and filled some of the ‘half-round’ exhaust system which I’m keeping for a change.
I’ve also set up a bench and trestles in my garage to build the Firebird, now that I have room….since my Golf has gone, and it keeps the dust at bay. 😁
8th scale Pontiac. Img_0418
Ron234
Ron234
Post by Sam Thu 19 Sep 2024, 4:14 pm
I'm really starting to dig the solid roof. Yes, Pontiac provided the cars for the show. The last one was a 1978, which stayed the same even though the series ended in 1979. It was actually a formula 400 package that was made to look like an esprit. If one is paying attention when watching the show, you will notice a fancier interior with power windows. 😁
...and yes, it would take a lot of grinding to replicate the Rockford car.
Post by Ron234 Wed 25 Sep 2024, 11:44 am
Hi folks,
I’m slowly modifying the engine bay of the Firebird - sanded off the moulded in hoses on the inner wheel arches, removed the moulded in liquid bottles and the complete heater/air con system too - including deletion of the pulley/belt and pump on the engine.
I have been considering buying a resin 1977 ‘Bandit’ conversion kit, produced by Cameron’s Modelworx in Nevada, but at $100 plus postage and import tax, it’ll actually cost more than the kit in the first place. They have a European contact, but as that is in the Ukraine, there is little difference in cost, but their versions need trimming and come 3D printed in clear.
As this kit is going to be a race car, then I can be a bit creative with my scratch-building and if it doesn’t look accurate, I’m putting the result down to ‘racing incident’ quick repairs. That will about cover it, and a saving of over 100 bucks ! 😁
8th scale Pontiac. Img_0510
8th scale Pontiac. Img_0511
8th scale Pontiac. Img_0512
Ron234
Ron234
Post by Sam Wed 25 Sep 2024, 5:28 pm
Tempting, but not necessary for an old road racer. Now if you could find a set of Minilites, that would be awesome.
Post by Ron234 Fri 27 Sep 2024, 12:12 pm
I’ve been searching for suitable wheels - got a set of minilites for the 1/12th Camaro that I built, but can’t find anything in 1/8th, as usual.
A nice set of painted wide steels would be nice - so might have a go at banding some from what remains in my parts boxes. 😁
Ron234
Ron234
Post by Sam Fri 27 Sep 2024, 3:40 pm
I might know where a set is. 😎
Post by Ron234 Thu 03 Oct 2024, 1:34 pm
Not much in the way of real progress on the Pontiac - to think, a couple of years ago I would have this kit finished in a few weeks
The engine has received a few added details and its first coat of paint - and the engine bay is process of detail, particularly a firewall. It’s not quite accurate, but better than a flat sheet of plastic that was there previously. I’ve also started to box in the hollow chassis rails and I’m somewhere near to adding a radiator which wasn’t in the kit too.
Wheels ?
My son mentioned he had some RC alloy wheels that might do, and brought them over. They are in fact real alloy! Not quite what I had in mind, but they fit the tyres that come with the kit, albeit 1/10th scale, and have the old chunky look, and not later low profiles.
I feel obliged to use them because my son showed interest in the model, but I think they will make a nice change, and would be different. I’m warming to them - but do I paint them or leave them REAL alloy ?
….and I’ve started to alter the nose cone ! Ahhhh! 😁
8th scale Pontiac. Img_0910
8th scale Pontiac. Img_0911
Ron234
Ron234
Post by Sam Fri 04 Oct 2024, 3:51 am
Beings that this is a road race car, you could have done a heater delete.
Post by Skid Fri 04 Oct 2024, 9:04 am
Nice work Ron.
On the wheels, if it were me, I'd go with an 'anodized look'. Something on the lines of the Ferrari 312b.
Colour subject to your chosen body colour of course.
8th scale Pontiac. 20_20110
