1960 Ford Falcon Two Door sedan
4 posters
I am going to post the wip pictures first so you have an idea of how extensive the restoration was. I started with this brown, curbside kit. I stripped the paint only to find black underneath...and what looked like 100 grit sand marks. Since almost all the detail was sanded off, I decided to make it a mild custom, and finished removing the trim.
20210223_115128 by Sam Grabenhorst, on Flickr
20210223_120402 by Sam Grabenhorst, on Flickr
20210225_090758 by Sam Grabenhorst, on Flickr
20210226_105006 by Sam Grabenhorst, on Flickr
Johnag, Mr Hirakawa and Ron234 like this post
Re: 1960 Ford Falcon Two Door sedan
You have your work cut out for you there Sam.
It looks like a lot of effort sanding and scraping? Do you not use a form of paint remover ?
I recall a kind of thick paste that you covered the body in, and placed it in a sealed plastic bag overnight - by morning the paste and paint fell off without damaging the plastic.
Not sure if it is still available. 🥴
Ron234- Moderator
Johnag likes this post
Wow Sam, that sure is going to be a lot of work. Kudos for taking it on, don't think I would have.
Ron.... on the paint stripper side, I immerse bodies to stripped in Dot 4 brake fluid for twenty four hours then rinse off in running warm water using an old toothbrush.
Thanks Al, Yes, I remember the Brake fluid now.
Ron234- Moderator
I've bought couple of built kits in similar condition. An over night soak in caustic soda revealed pristine body in one case. The second........not so pristine.
Looks like the B pillar has been cut to make hardtop? Good luck, I do like me a good restoration.
Thanks everyone. Hear is the next step, A Ranchero body gave up its life for a good cause. Followed by a little scratch building, and a mockup.
20210226_105205 by Sam Grabenhorst, on Flickr
20210314_152820 by Sam Grabenhorst, on Flickr
20210314_153836 by Sam Grabenhorst, on Flickr
20210314_155051 by Sam Grabenhorst, on Flickr
20210314_164448 by Sam Grabenhorst, on Flickr
20210314_174036 by Sam Grabenhorst, on Flickr
20210314_174238 by Sam Grabenhorst, on Flickr
20210315_102300 by Sam Grabenhorst, on Flickr
20210315_134912 by Sam Grabenhorst, on Flickr
20210315_163447 by Sam Grabenhorst, on Flickr
20210315_171026 by Sam Grabenhorst, on Flickr
20210316_155233 by Sam Grabenhorst, on Flickr
20210316_174028 by Sam Grabenhorst, on Flickr
Nice work ! If you hadn’t shown the repair and rebuild I wouldn’t have known the effort that had gone into it.
- pity a good Ranchero had to give up it’s life, but it has turned out really well.
Ron234- Moderator
Ron, the Ranchero kit is plentiful and cheap. The chassis from this kit was used under the sedan delivery I built, and the body for this. So nothing went to waste.
Ron234 likes this post
That's some nice work Sam. Well done.
I presume the seemingly endless 'filling' work will follow?
Skid wrote:That's some nice work Sam. Well done.
How did you guess.
Here are a few pics to catch up with. I wont boor you with the rinse and repeat that Al mentioned I had to polish the glass, and used Novus products. Detailed out the chassis, and interior. Also stripped and "re-chromed" the bumpers. Oh, and my plan was white...as in, covers a multitude of sins.
20210323_214755 by Sam Grabenhorst, on Flickr
20210324_183945 by Sam Grabenhorst, on Flickr
20210328_192251 by Sam Grabenhorst, on Flickr
20210328_195325 by Sam Grabenhorst, on Flickr
20210403_205125 by Sam Grabenhorst, on Flickr
20210410_113459 by Sam Grabenhorst, on Flickr
20210411_171317 by Sam Grabenhorst, on Flickr
20210328_191234 by Sam Grabenhorst, on Flickr
20210409_201001 by Sam Grabenhorst, on Flickr
20210410_160328 by Sam Grabenhorst, on Flickr
20210415_104252 by Sam Grabenhorst, on Flickr
20210517_123519 by Sam Grabenhorst, on Flickr
Looking great Sam, and I can’t see the joins.
White is a good colour, but I also understand people leaving cars in primer - that gloss coat can really show any imperfections.
Interior looks well, so is this going to be near stock, with aftermarket wheels ?
Ron234- Moderator
Great restoration Sam. The interior rocks too!
» 1960 Ford Falcon two door sedan
» 1961 Ford Falcon Ranchero and Falcon Sedan Delivery
» 1937 Ford Sedan
» Jim Richard's Ford Falcon
» Jim Richards 1964 Ford Falcon
» 1937 Ford Sedan
