Cobratee parts box build
stevegt738
Page 2 of 2 Previous  1, 2
Cobratee parts box build - Page 2 Empty Re: Cobratee parts box build
Post by Skid Sun 16 Aug 2015, 5:18 pm
Thanks guys. It's been a real fun build so far. Everyhing has just gone so well. (Famous last words)
Any way you can bevel the roof opening so the thickness isn't quite so obvious? wrote:
Got a couple of ideas on that John.
In the meantime, I found some more suitable mesh:
Cobratee parts box build - Page 2 01412
The interior is more visible:...
Cobratee parts box build - Page 2 01612
.... and it lets in even more light.
Cobratee parts box build - Page 2 01513
Post by Guest Sun 16 Aug 2015, 6:07 pm
Maybe make a lip of styrene sheet so the thicker edge isn't in view??
mesh looks a little more in keeping with the theme being a tad heavier gauge
Post by Skid Sun 16 Aug 2015, 6:40 pm
Ahead of you Colin.
Cobratee parts box build - Page 2 Dscn3110
Cobratee parts box build - Page 2 Dscn3111
Cobratee parts box build - Page 2 Dscn3112
Needs a bit of tidying up yet but not too much as it is a rat rod after all.!! LOL
Post by Guest Sun 16 Aug 2015, 6:55 pm
Looks good, Al. Needs a couple wooden slats going across the top. I really like this build, good subject.
The opinions expressed here are completely my own.. Cobratee parts box build - Page 2 524092055
Post by Skid Sun 16 Aug 2015, 6:58 pm
Thanks Buck.
I have the slat's in mind, never fear!! LOL
Post by Guest Sun 16 Aug 2015, 7:19 pm
Thats two good ideas in as many days from me .. amazing .. i'm gonna quit while i'm ahead Cobratee parts box build - Page 2 1792231099
Post by Skid Sun 16 Aug 2015, 10:29 pm
Get outta here!!! Cobratee parts box build - Page 2 1792231099
Post by Johnag Sun 16 Aug 2015, 11:43 pm
Skid wrote:
Get outta here!!!
Cobratee parts box build - Page 2 36_11_6Cobratee parts box build - Page 2 36_11_6
Post by Skid Sun 16 Aug 2015, 11:45 pm
Cleaned up but not 'made perfect' for obvious reasons.
Cobratee parts box build - Page 2 00145
Cobratee parts box build - Page 2 00246
Post by Skid Mon 17 Aug 2015, 6:36 pm
The chassis in yellow I didn't think looked right for a ratty rat rod, so I sprayed it in Humbrol Metalcote Steel. It may or may not get polished.
I also painted the wheels and changed the front tyres for fat whitewalls. There are a few chips out of the white walls but I think they will fit in OK when the body etc is 'weathered'.
Cobratee parts box build - Page 2 00146
Cobratee parts box build - Page 2 00247
Post by Speed Racer 65 Mon 17 Aug 2015, 6:44 pm
You going to get a interesting sun burn from that roof Al.
Post by Guest Mon 17 Aug 2015, 8:05 pm
And you're reserving judgement on MY wheels Al ....... Cobratee parts box build - Page 2 1792231099
Looks good mate.
Post by Skid Mon 17 Aug 2015, 11:31 pm
I'm going to try an replicate a body finish similar to this....
Cobratee parts box build - Page 2 Maxres11
... so I started by spraying it with Red Oxide primer, followed by Humbrol Metalcote Steel.
Cobratee parts box build - Page 2 00339
Cobratee parts box build - Page 2 00435
It dried a little patchy over the red primer which is just perfect for the look I want. I then gave it a light buffing:
Cobratee parts box build - Page 2 00816
Cobratee parts box build - Page 2 00917
Cobratee parts box build - Page 2 01019
Cobratee parts box build - Page 2 01111
It still has the slightly patchy look I was hoping for, so now it's on to some light weathering.
Post by Skid Tue 18 Aug 2015, 6:50 pm
Well that didn't work out. Tests showed that the Humbrol Metalcote paint, didn't like the 'fixer' solvent used for the rust pigments.
SO..... I looked in my paint stash and came up with Tamiya Flat Dark Iron. Test show it's impervious to the fixer solvent.....
Cobratee parts box build - Page 2 00147
but you know, I think it would look good as is with maybe the addition of door decals.
Cobratee parts box build - Page 2 00341
Post by Guest Tue 18 Aug 2015, 7:18 pm
These pigment things seem more trouble than they're worth.... try some acrylic rust paint (revell aqua is great) and just thin it slightly and add a small amount of bicarb. If you want an area thicker with rust just sprinkle bicarb on the wet paint and when dry touch it with a thin mix of rust paint and it'll soak it up and blend in.. use different rust colours (just add matt black or cream) to vary the look
Use this technique all the time with weathering whether it be rust, mud, sand, soil ... works everytime
If you're going with decals Al ... maybe a skull and crossbones or similar???
Post by Skid Wed 19 Aug 2015, 12:48 am
The weathering powders I use are fine Colin, it was the Humbroll Metalcote that was causing the problem.
This time around I went for the solid body but with old surface rust look:
Cobratee parts box build - Page 2 Rusty_10
This is what I ended up with, which I'm pretty pleased with:
Cobratee parts box build - Page 2 00148
Cobratee parts box build - Page 2 00248
Cobratee parts box build - Page 2 00342
Cobratee parts box build - Page 2 00436
Cobratee parts box build - Page 2 00525
Cobratee parts box build - Page 2 00620
Cobratee parts box build - Page 2 00717
Cobratee parts box build - Page 2 00817
Ever mindful of the 'less is more' principle when weathering, I stopped here. But I'm wondering now, should I add a little even lighter coloured rust?
I also added a firewall and distressed the Maltese Cross. (No skull and crossbones Colin)
BTW, I used Bragdon Weathering Powders which were sent across the pond to me by by good buddie, JohnJ.
Thanks Bro.
Cobratee parts box build - Page 2 00918
Post by Geezerman Wed 19 Aug 2015, 4:35 pm
Cobratee parts box build - Page 2 2776978727
Post by Skid Wed 19 Aug 2015, 5:20 pm
I went ahead anyway with some lighter pigment and also did some streaking:
Cobratee parts box build - Page 2 01020
Cobratee parts box build - Page 2 01112
Cobratee parts box build - Page 2 01214
Post by Johnag Wed 19 Aug 2015, 5:22 pm
Looks great Sir, may I ask how do you use these powders please, do you spray them on with the airbrush and dab them on with a normal hairy brush, maybe time for a tutorial (pretty please)...
Andy... popcorn
Post by Skid Wed 19 Aug 2015, 5:40 pm
Thanks Andy.
OK... fair do's. Gimme a couple of days and I'll work up a proper tutorial.
Post by Guest Wed 19 Aug 2015, 5:50 pm
Cobratee parts box build - Page 2 1705482731 Looks great, Nice work on the weathering.
Post by Johnag Wed 19 Aug 2015, 8:03 pm
Skid wrote:Thanks Andy.
Thank you very much Sir, I am ready for class to start...Cobratee parts box build - Page 2 Geek1_zps7384ab63
Post by Speed Racer 65 Wed 19 Aug 2015, 10:55 pm
I am interested too.
It looks awesome by the way.
