Taking a wheel aprt
3 posters
Re: Taking a wheel aprt
Try getting it wet, putting it in a zip lock bag and put it in the freezer. Has the water freezes and expands it will break the glue loose. That would be my first choice.
Mine too John.
I'd go for that too .... when you get it out the freezer give it a sharp tap on the bench asap, that works !!!!
Second shot would be 10 minutes in some boiling water and a bit of brute strength and a prizey thing!!
Wow guys, every day is a school day, I will try to remember that technique should I ever need to use it.
The zip lock bag, water and freezer tip worked, I had to do it twice but it worked
Thanks for the tip guys
It works with getting your wallet away from the missus too
Pop her in a plastic bag with some water and bung her in the freez......... oooopppss wrong forum :)
Snake wrote:It works with getting your wallet away from the missus too
Colin, that might be a good tip for some guys but I'm not married so no problem
» Tyrell P34 6 Wheel GP Car - Tamiya 1/12
» Big Wheel Drift Trike
» I'm taking myself..........
» Styrene glue not taking...
