Straightening Resin!!!
4 posters
I'm supposed to be doing a dual build, with a member on another site, on a new Belly Tanker in the next day or so. This time I'm using the resin kit I couldn't find anywhere last time.
However, the tank is warped and I don't want to start it until I have a fix.
Lateral twist is easy to straighten with steam but this one is warped longitudinaly which presents a much more difficult proposition.
Steam isn't working and I fear it's too much to sand out.
Anyone got any ideas??
Re: Straightening Resin!!!
?? Clamps and industrial strength glue ??
Make a vertical cut (you might need more then one) in the belly in line with the panel line on the top half. We do the same thing to bend large pieces of wood.
Bring a pan of water to a rapid boil. Dip the piece for 10 seconds and place on a flat surface and hold till it cools. Repeat as needed.
Al, I surmise that when the resin is warm, you will need to pull the sides apart to bring the ends up.
» Resin kit newby
» Resin Parts Cleanup.
» Resin casting aria on Forum
» Mack CL700 Custom (Resin Conversion)
» Resin body/paint advice needed.
