Thunderbird & 32 Roadster
5 posters
Page 1 of 2 1, 2  Next
Thunderbird & 32 Roadster Empty Thunderbird & 32 Roadster
Post by Guest Wed 20 Nov 2013, 6:28 pm
Here we go with my second build thread - and building a pair of cars side by side.
The Thunderbird will be influenced by the Larry Watson car, but not a reproduction,
and the '32 Roadster will be full-fendered
- although I bought it to make a Highboy, until I found it didn't have a separate chassis.
Both cars will come from the same period in time, so it's natural to build them both.
Thunderbird & 32 Roadster F03095b9-4798-43c9-ba8d-8e3944a05da3_zps53772703
Thunderbird & 32 Roadster Empty Re: Thunderbird & 32 Roadster
Post by Guest Wed 20 Nov 2013, 9:41 pm
001
Post by Geezerman Wed 20 Nov 2013, 10:51 pm
Thunderbird & 32 Roadster 3331969777  Bring 'em on !!
Post by Guest Fri 22 Nov 2013, 6:27 pm
With the weather being cold and damp today, I carried on with the two cars.
I started preparing the T-Bird, filling in sink holes and, if it was real life,
appeared as if the wind had caught both doors and creased the front wings.
Biggest issue being the nasty twist in the body that often occurs with models of convertibles.
However, the body is now filed, filled and has a flat white primer coat,
but the twist is bothering me and I might glue in the doors to make it more rigid,
as my success in the past with opening doors has only been so, so.
I’ll sleep on that, and try and get a gloss basecoat on tomorrow
Thunderbird & 32 Roadster 0f53b008-319f-407d-9579-3c9733b57c8e_zps889012f1Thunderbird & 32 Roadster 5c378a2b-e057-499a-87ba-28de2efea519_zps9dd1c838
Thunderbird & 32 Roadster D33cadc8-4f25-4322-b86e-2b2362824b18_zpsc5cf2f0f
Thunderbird & 32 Roadster 8bc08e36-ebc1-4bf6-b7be-aa94b49a4976_zpsdee152a6
The ’32 Roadster is another story. I was hoping to paint it Gold/Bronze but it turned out to be shade of orange,
and I have quite a few orange cars - so I tinted it with a touch of red so is now a sort of ‘Burnt Orange’
but the colour will contrast nicely with the proposed white interior and whitewall tyres.
Thunderbird & 32 Roadster A81b62eb-d0bb-4e70-9aef-7a9ff839b83d_zps1fdcc167
Thunderbird & 32 Roadster Be529b67-b6c7-48be-8b43-eda1bb0659f2_zps8e5a419b .......ORANGE HenryJ nearing completion !
Post by Guest Fri 22 Nov 2013, 6:49 pm
Some nice progress on both builds. I really like that 32.
Post by Brizio Fri 22 Nov 2013, 7:00 pm
Looking great!
Post by Guest Fri 22 Nov 2013, 7:06 pm
I was planning a 'Kookie' type car, but the colour is way too dark now.
I was really annoyed that the '32 didn't feature every week on 77 Sunset Strip,
but I do remember the 'Chrome Coffin' episode.
Post by Guest Sat 23 Nov 2013, 1:44 pm
Good start Ron. For me I'd glue the door shut, if it means a straight body and less issues down the road.
Orange is my fav colour.
Post by Skid Sun 24 Nov 2013, 12:01 am
Good work on both Ron.
I'm not a fan on mving parts on styrene models and you may still find that the body is twisted when you glue them in position.
However, you should be able to straighten it by using steam from a boiling kettle.
Post by Johnag Sun 24 Nov 2013, 2:44 pm
Hi Ron,
These are looking good so far Sir, I really love the Burnt Orange colour...
Skid wrote:However, you should be able to straighten it by using steam from a boiling kettle.
May I ask, is there a set time or do you just go by eye, also would you have to strap it down onto a board or something or would it just slowly straighten itself out...
Sorry for the questions...
Many thanks...
Post by Guest Mon 25 Nov 2013, 11:03 am
I've tried the steam thing, once, but didn't work for me.
It will probably 'glue' down straight to the chassis when it is finished, I hope.
...and rightly, I don't think cementing the doors will help - so plodding on with the open door build.
The T-Bird is now painted VW Candy White, and I have mist coated the Satin Black upholstery
with Metallic Purple ready for my brush painting of the Off-White seat inserts
Post by Geezerman Mon 25 Nov 2013, 11:15 am
001
Post by Guest Wed 27 Nov 2013, 4:29 pm
Okay...this is the latest :
Thunderbird & 32 Roadster 9284fd56-537a-4428-b73f-46e804622024_zpsdef197e3
Paint is now lacquered and engine wired.
Chequered firewall was drawn up on the computer and printed out on photopaper, then lacquered.
Gearshift is the usual long ball headed pin - bent to shape, obviously,
and the underside of the mudguards - sorry, fenders, have been painted gloss white.
More detailing to come, (white running boards, Edsel steering wheel, etc.) but the '32 is almost there,
hopefully all done by the weekend.
A bit put off by the twisty body on the T-Bird,
I have diverted my attentions for a while on finishing off another car : my 427 Fairlane,
which may also be finished for the weekend - before I get back to the other job in hand.
 Thunderbird & 32 Roadster Affa4c19-8c43-4f84-928c-9c1eb1440d36_zps8f68f26f
Post by Guest Wed 27 Nov 2013, 4:58 pm
Fine looking Roadster. WTG.
Post by Guest Wed 27 Nov 2013, 5:09 pm
Looks real sharp Ron super smooth paint. Did you mask the checkers on the fire wall?
Post by Skid Wed 27 Nov 2013, 6:03 pm
Ron.... sorry not to get back to you on body straightening.
This is what I would do:
Glue the doors in place and let cure for a day or so.
Set your COLD tap running. With the kettle boiling, hold the body in the steam at the point of the twist. Now twist in the opposite direction a little more than the original twist and hold there for maybe 15 seconds, remove from steam, and still holding the 'anti-twist, twist, (LOL) run cold water over it for a few seconds.
Works every time for me.
You may have to repeat until you get the desired result. If you go to far, just repeat and reverse the twisting.
Post by Guest Wed 27 Nov 2013, 9:35 pm
Thanks Al - problem is I've already painted it, and wonder whether if I use steam ,will it affect the paint?
Looking at the T-Bird again, because the doors are not fixed (yet), the twist is not 'tight',
and in this case I've decided to cement the body to the chassis - before I mask out any more paintwork.
I'll clamp it down square, and hope when the glue is cured, none of the wheels will be lifting
- like a dancing Lowrider.
Thanks for the info and it's noted if I get another twisty kit.
Post by Guest Wed 27 Nov 2013, 9:41 pm
Thunderbird & 32 Roadster 9aa15dce-d5ec-42ff-9886-2a38d2f30efb_zps2d568a73
Paint could do with a compound to be honest Curt, - and yes I cheated by using the computer to print out the chequered firewall.
There was a time I could do it by hand !
Post by Guest Wed 27 Nov 2013, 11:13 pm
Ah I'm sure you can still do it, you've just got wiser in your old age. Love the colour, you're right it could do with a bit of rubbing, it still looks good. Just blast on some poly clear.
Post by Guest Thu 28 Nov 2013, 2:40 am
001
Post by Guest Thu 28 Nov 2013, 11:24 am
It's a bit of a grey day in the Village today - but a balmy 13 degrees - ideal for a long session in my meagrely heated attic cave,
so looking forward to finishing one of the models earlier than expected.
Thunderbird & 32 Roadster D65e9a04-94a7-4953-a4a7-68e3f8456858_zps4717ca6e
Post by Guest Thu 28 Nov 2013, 1:18 pm
001 have at it Ron, good luck. It's -8 here.
Post by Guest Thu 28 Nov 2013, 5:07 pm
Ditto what Curt said.001
Post by Skid Thu 28 Nov 2013, 6:08 pm
Nice village Ron. Which one? I'm just outside of Haydon Bridge, Northumberland.
Post by Johnag Thu 28 Nov 2013, 10:13 pm
Hi Mr D,
This looks sweat, I love the chequered firewall, it looks very effective...
