Easy Rusting And Plastic Ageing
+2
6 posters
Hi all, firstly let me say I'm not saying I'm good at this or that ist any of my own ideas (well apart from the plastic ageing)all the rust techneques I use here have been used by others, perhaps not all at the same time or combined with other thchneques, I was asked by juno to do a tutorial on my methods so here it is, hope it is of some use.
Firstly this is old spare parts and I am going to spray the overall top colour black, simply because I think it will show the effect off best, first I paint the rust colour on the part roughly where I want the rust,
If I want blistering bubbles in the paint I use pva glue and a cocktail stick.
please excuse the blured pic, its difficult to use the camera whilst applying the glue, I allow that to dry
then apply a few more dabs around and on that one and allow those to dry
next I use sea salt in a grinder (you get more uneven grain sizes than table salt
Now there are 2 methods you can use now, water, or hair spray
the bottom one is just water which is applied where you want the rust only the top part I applied the hairspray all over it (I decant the hairspry into a lid from the can so if I wanted I could only apply it where the rust is, I've done it all over on the top piece I will explain why in the next step)
now wee sprinkle the salt all over whilst everything is still wet. then allow it to dry.
then we spray it all black< you can see from the water one that some of the salt has already fell off
now we brush all the loose salt off
that is as far as you can go with removing paint on the water and salt one, however with some warm water and a stiff brush you could also remove all the black paint from the hairspray part if you wanted to, the advantage of this method is if the salying has not shown enough rust you can show more like this.
The next stage (this wont work on the hairspray one ) is to use some cellulose thinners
I like to use the dirty thinners I clean my brushes in as it helps with the staining , I also have a special brush with very few bristles left so it cant hold much, I literally shake the tin and whats in the lid is what I use(WARNING THIS MELTS PLASTIC BE CAREFUL)
I literally just run it down the seams to give the rust tracking you get.
Here endeth the rusting part now onto easy plastick ageing
this is the stuff I use
as you can see I just daube it on the part
then I get my dirty old thinners bottle
and flood the part letting the thinners wash the oil over and down the part, then I get my wash whilst everything is still wet with the thinners and let that wash all over the part
let all that dry
and there you are
easy what.
let all that dry
and there you are
easy what.
Re: Easy Rusting And Plastic Ageing
Very nice KP. Are you using the same thinner for the aging (cellulose thinner)?
For those of you State side, cellulose thinner is called Lacquer thinner here.
God no I'm glad you pointed that out white spirit is the thinners I use for the agenig if you used cellolose(laquer) you would melt the plastic.
CHEERS!! KP.
Hi Mr KP,
Many thanks for this Sir, I think a collection of peoples different rusting & aging techniques would really help make the ultimate technique if someone used the best bits from each version...
Many thanks again...
Thanks for the tutorial. Nice to have an arsenal of varying methods at one's disposal.
Thank you. Well written very informative tutorial. I enjoyed reading it twice.
» My way with rusting.
» Rusting Race Cars
» More easy springs....
» Easy photo backdrop
» Quick 'n' easy coil springs
» Rusting Race Cars
