1968 Ford Drag Team
Re: 1968 Ford Drag Team
Here are the body's painted in White and sitting on the chassis
Body's with decals on
Bill Lawton, kit decals
Hubert Platt
Dyno Don
and Gas Ronda
Don't even have the kit started for Gas Ronda's car but it's painted and decaled.
Have to do the front bumpers and grille's and headlights, rear tail lights and bumpers, then finish putting them together
Thanks for looking and comments are always welcome
Hubert Platt
Dyno Don
and Gas Ronda
Nice lookin team set !
Great work so far, John. The engines, bodies and chassis look neat and clean.
WHOA THERE! I see even a fuel line/pump running from the tank. Most excellent work and what a team of drivers!
Holy assembly line Batman! And with the quality control boys doin' a fine job too.
Are you going to build a Team Hauler for all of them?
Nice setup !
dogfish7 wrote:Are you going to build a Team Hauler for all of them?
I'm not sure if they had a Hauler in 68 I know in 69 they did
You have a regular production line going here John.
Good looking engines.
I like the look of this project..... And yes, I agree.... The engines are particularly nicely done!
I have a Revell Bill Lawton Mustang started,
which I must get it finished one day.
..NICE set of cars, and of course I'll be 'borrowing' a few of your ideas !
dadooronron wrote:I have a Revell Bill Lawton Mustang started,
Ron, look at your kit and check the clear parts tree cause the clear headlight lenses where not on any of the 10 - 68 Mustang GT kits I have You can get them from Revell by going to the web site www.revell.com to find out how to order them.
Take your time on this kit and test fit every thing, the hood is too wide and needs fitted and some others that I don't remember right now put will put a post when I do
Thanks John, I've painted the car - but not checked the bonnet fit (or headlight lenses).
Maybe I should have test fitted first, but I often dive straight in and hope all is well.
Ron, this is what I did to get things fitting good
1. Inside the roof there are 4 pins, remove the 2 front pins so the glass will fit right
2. the body. chassis guides on the body and the ones on the chassis got cut to half the length, so it's easier to get together and sit lower on the chassis.
In the picture you'll see red dots as to the location I'm talking about
The guide at the rear gets cut also and I filled the hole in the chassis that the screw goes into, I didn't use the screws at all for assembly. Hope this will help with your build and make it a little easier to do
I didn't use the front axle either, goes through the eng. block, used a plastic rod for the axle and filled the hole on the eng. block and made mounts for the engine to sit on. Can't think of any other major issues right now but if I do I'll post them so you'll know
I've not got that far as yet - but I have found my headlamp lenses, thanks for the info, will do !
Wow John ........... those Mustangs are impressive .............. even if they are Mustangs
Your work on these kits has really been impressive ......... can't wait to see all four
Old Coyote- Intermediate Member
Looking good John. Nice mods too.
I was kind of happy back in the day, when the top drivers brought their skills to actual near stock class racers. You've done a super job recreating one of the teams. Imagine the real thing taking on all comers and the diorama it would make! THANX a lot!!!!
Your'e cracking on with these John. Well done.
Hubert Platt's car
here are some out side pictures
and the trio
with Gas Ronda's shell
I'm going to start Gas Ronda's chassis some time this summer and will do these 2 at that time also
Rye Ford - Driver; Dinny Lyons
and Foulger Ford - Driver; Tom Stafford. This is Dyno Don's car that they bought after The Winter National's in 1968
When I get the other 2 done I might do some more detailing on all of them, have to see how things go first.
Thanks for looking and the nice comments
and the trio
Awesome! The Three Amigos!
» 1968 Ford Mustang
» 1968 Ford Mustang
» Firebird Drag Car
» Volvo (really!) drag car
» Monza S drag car
» 1968 Ford Mustang
» Firebird Drag Car
» Monza S drag car
