Roll cage padding and cable ties.
+3
Gothic Kustomz
7 posters
This is my way of replicating roll cage padding and zip ties.
You will need the following items:
Some nylon fishing line of around .165mm to 02mm or around 3lb to 4.5lb breaking strain. Clear or smoke to represent those whiteish zip ties or black for the black versions.
Some small bore silicone tubing for the padding.
Some CA glue.
A cocktail stick.
An Exacto knife with a BRAND NEW No11 blade.
And finaly, a LOT of paitence as this is a time consuming but satisfying job.
First of all cut your tubing into lengths to suit your roll cage.
Now cut each piece down its length so it fits over the cage bars. This is how it would be done in the 1:1 world anyway. Don't worry if when you fit it, it doesn't go all the way around. It usually doesn't in the 1:1 world either.
Place the 1st piece on the cage and check it is sitting properly with the slit where you want it (away from the driver) and that it looks good.
Now study the following diagrams and description carefully and make some practice knots using a piece of line abou 12" long to start with. You will be able to shorten this to about 6" with practice.
Instead of passing the line through the eye of a fishing hook, pass it around the roll cage padding instead and pass the line THREE times around itself.
Now pass the 'tag' end through the small gap between padding and line.
You can eliminate the 'tuck' whereby the 'tag' is passed into the loop. This only makes the knot more bulky and is only needed for added anti slip while fishing.
Finaly draw up the knot by pulling slowly and gently on the other end of the line to the 'tag' end, supporting the cage with the other end. Draw it up tight enough to just sink into the padding a little.
When you have the 'zip tie' completed, swivel it around the padding until you have it in the position you want.
Now dip the cocktail stick in the CA glue and apply a TINY drop of glue to the knot.
Lastly, using the Exacto knife, trim the knot as closely as possible.
When you have finished you should end up with something like this:
For scratch building roll cages see HERE
Some CA glue.
A cocktail stick.
Re: Roll cage padding and cable ties.
kewl thanx, this will perfect for my pro touring collection I will be building, thanx man.
Gothic Kustomz- New Member
Thanks Al, great tip. This forum rocks!
Great tutorial. I have used thread before for zip ties, but never fishing line with these knots. As a fly tier, I recognize the knot! Thanks.
I'm glad you guys liked it.
Hi Mr Skid,
Thank you for sharing this, it looks so real...
Fan-tastic! I always wondered how to improve the molded look of cage padding. Now, a builder could file a "groove" around the molded on plastic and do your zip tie idea for greater realism, as well as doing it on scratch building. Nifty idea, and if one chooses, have a cocktail after!
I have one additional question. Where, or what type of store carries the small bore silicone tubing (in black or colors)? Thanks.
Pete
Pete
Pete, here in the UK it's easiest to find in a fishing tackle store as we carp anglers use it a lot.
Not sure about the US though.
You have mail.
You have mail.
» Tip for building roll bars, roll cages. by Brent
» Steel cable, rope and camo netting
» My way with roll cages.
» Roll on 2016...............
