Franzis 1/3 Porsche type 547 engine
Hi all not been able to post on here for a while till I tried the web version instead of the tap talk version so quite a long way on in this build
https://youtu.be/wG8IpL55tx4
Re: Franzis 1/3 Porsche type 547 engine
Got the exhaust on and more experimental metal effects, a word of warning to anyone building this kit and painting parts of it the black shiny plastic is of a different type of plastic to the rest of the kit I sprayed the cowl for the fan (with the same type of paint used everywhere else) the plastic on the cowl has crazed and cracked (and that's even with using plastic safe primer) im hoping a layer of filler sanded down then sprayed over will fix it.
Nearing completion now.
Well its done (the supplied belt is too tight making the top pully bind and stopping it)
https://youtu.be/5b3f-i0C1Ng
» Franzis 1/2 BMW R90S engine
» Entex Ford Turbine engine, model 707 gas turbine engine
» 1910 B Type Bus - Airfix 1/32
» Purple V8 E-Type
» Purple V8 E-Type
