Italeri 1/16 Mercedes SL 300
2 posters
Hi all next victim is the italari 1/16 Mercedes 300 SL, first thing I don't like is the distributor and plug leads are molded as part of the rocker cover (I don't even know why they would do that at this scale)
Re: Italeri 1/16 Mercedes SL 300
Hi all well for a kit of this age I can't believe how well the body goes together (considering all the complex curves) look how little filler ive used.
[img]https://i.ibb.co/XJJqthF/IMG-6080.jpg[/img
I was going to do this deep impact blue (I had a can of it and thought I would use it on this) not quite enough, but it worked as a good primer for this colour. Added some ht leads.
Hi all here is the next update just put together what I have so far
No matter what angle you look at the front of the SL 300 she is sexy and beautiful. As a classic its got to be up there with the EType
So I ran into a small problem with the 300SL the track rod end and the top of the king pin were broken off I tried gluing them back on but they just kept braking off so I drilled out where they should have been and added some bent rod to fix it.
It doesn't look very pretty but is not really visible on the model so I'm not too worried about it.
More done on this
The 300 SL nears completion. Just the exhaust and the fuel tank to add to the underneath then time to add body doors and details.
Quite a production! Detail is good, but it is LARGE scale too. I had a chance to buy a kit at a garage sale long ago, but passed on it. Glad you took your chance and did a beautiful job!
Nearing completion now (tomorrow I think)
» Italeri 1/16 Mercedes SL 300 cabrio
» A-20G by Italeri
» Italeri Schwimmwagen 1/35
» CV-22 Osprey Italeri 1/48
» Lamborghini Countach 5000 (Italeri)
» A-20G by Italeri
