Tamiya 1/12 Porsche 934
4 posters
Page 1 of 2 1, 2  Next
Tamiya 1/12 Porsche 934 Empty Tamiya 1/12 Porsche 934
Post by kpnuts Tue 16 Jun 2020, 9:54 pm
Hi all this will be my next build looks up to Tamiya normal standards but when I first assembled the engine block the fit was awful and I had to use clamps scarily tight to pull the engine halves together (luckily this area is hidden by the timing chain cases) also luckily the gearbox is a perfect fit so maybe the engine halves were warped for some reason and that will be the only problem I get. Which is also lucky as I intend to build the engine on a display stand to be put alongside the car (as if it's just been rebuilt ready to be put back in)The body moulding is awesome hardly any seams at all and the detail in the kit seems incredible
This is the same scale as the Bentley so is quite a large car.
Tamiya 1/12 Porsche 934 IMG-3356
Tamiya 1/12 Porsche 934 IMG-3351
Tamiya 1/12 Porsche 934 IMG-3354
Tamiya 1/12 Porsche 934 IMG-3353
Tamiya 1/12 Porsche 934 IMG-3350
Tamiya 1/12 Porsche 934 IMG-3358
Tamiya 1/12 Porsche 934 IMG-3348
Tamiya 1/12 Porsche 934 IMG-3352
Tamiya 1/12 Porsche 934 IMG-3349
Tamiya 1/12 Porsche 934 IMG-3357
Tamiya 1/12 Porsche 934 Empty Re: Tamiya 1/12 Porsche 934
Post by kpnuts Wed 17 Jun 2020, 9:19 pm
Ok so here is a start on the engine.
Tamiya 1/12 Porsche 934 IMG-3365
Tamiya 1/12 Porsche 934 IMG-3364
Tamiya 1/12 Porsche 934 IMG-3366
Tamiya 1/12 Porsche 934 IMG-3367
Post by kpnuts Thu 18 Jun 2020, 8:59 pm
More work on the 934 engine.
Tamiya 1/12 Porsche 934 IMG-3386
Tamiya 1/12 Porsche 934 IMG-3383
Tamiya 1/12 Porsche 934 IMG-3384
Tamiya 1/12 Porsche 934 IMG-3385
Tamiya 1/12 Porsche 934 IMG-3381
Tamiya 1/12 Porsche 934 IMG-3382
Post by kpnuts Fri 19 Jun 2020, 9:10 pm
Hi all more done to the engine (the rest seems to be going together in the usual tamiya fashion (in other words perfectly)
Tamiya 1/12 Porsche 934 IMG-3396
Tamiya 1/12 Porsche 934 IMG-3398
Tamiya 1/12 Porsche 934 IMG-3397
Tamiya 1/12 Porsche 934 IMG-3400
Tamiya 1/12 Porsche 934 IMG-3401
Tamiya 1/12 Porsche 934 IMG-3399
Tamiya 1/12 Porsche 934 IMG-3402
Tamiya 1/12 Porsche 934 IMG-3403
Post by kpnuts Sun 21 Jun 2020, 4:05 pm
Hi all more work on the engine and a start on the bodywork
Tamiya 1/12 Porsche 934 IMG-3452
Tamiya 1/12 Porsche 934 IMG-3449
Tamiya 1/12 Porsche 934 IMG-3451
Tamiya 1/12 Porsche 934 IMG-3450
Tamiya 1/12 Porsche 934 IMG-3466
Tamiya 1/12 Porsche 934 IMG-3469
Tamiya 1/12 Porsche 934 IMG-3467
Tamiya 1/12 Porsche 934 IMG-3441
Tamiya 1/12 Porsche 934 IMG-3470
Tamiya 1/12 Porsche 934 IMG-3446
Post by kpnuts Sun 21 Jun 2020, 9:13 pm
Hi all made a start on the engine stand and did some work on the front end.
Tamiya 1/12 Porsche 934 IMG-3484
Tamiya 1/12 Porsche 934 IMG-3487
Tamiya 1/12 Porsche 934 IMG-3485
Tamiya 1/12 Porsche 934 IMG-3486
Tamiya 1/12 Porsche 934 IMG-3488
Tamiya 1/12 Porsche 934 IMG-3482
Tamiya 1/12 Porsche 934 IMG-3481
Tamiya 1/12 Porsche 934 IMG-3483
Tamiya 1/12 Porsche 934 IMG-3480
Post by kpnuts Wed 24 Jun 2020, 9:42 pm
Hi all more work on the engine.
Tamiya 1/12 Porsche 934 IMG-3512
Tamiya 1/12 Porsche 934 IMG-3511
Tamiya 1/12 Porsche 934 IMG-3510
Tamiya 1/12 Porsche 934 IMG-3518
Tamiya 1/12 Porsche 934 IMG-3517
Tamiya 1/12 Porsche 934 IMG-3514
Tamiya 1/12 Porsche 934 IMG-3513
Tamiya 1/12 Porsche 934 IMG-3516
Tamiya 1/12 Porsche 934 IMG-3515
Post by kpnuts Fri 26 Jun 2020, 8:57 pm
More work on the engine and a start on the body.
Tamiya 1/12 Porsche 934 IMG-3533
Tamiya 1/12 Porsche 934 IMG-3530
Tamiya 1/12 Porsche 934 IMG-3531
Tamiya 1/12 Porsche 934 IMG-3532
Tamiya 1/12 Porsche 934 IMG-3534
Tamiya 1/12 Porsche 934 IMG-3539
Tamiya 1/12 Porsche 934 IMG-3535
Tamiya 1/12 Porsche 934 IMG-3538
Tamiya 1/12 Porsche 934 IMG-3536
Tamiya 1/12 Porsche 934 IMG-3537
Post by kpnuts Sun 28 Jun 2020, 8:43 pm
Hi all well the tamiya supplied engine is done, I've looked on line but cant find picures the throttle linkages, I will have to ask my boss if he has any references (he seems to have an know anything Porsche related (hes an advisor on several official Porsche boards and is highly respected for his knowledge))started the decals, which are great but, the ones round the grill are really hard especially the ones around the square cut outs (if I could have guaranteed the colour match it would have been far and away easier to mask and spray it.
Tamiya 1/12 Porsche 934 IMG-3557
Tamiya 1/12 Porsche 934 IMG-3555
Tamiya 1/12 Porsche 934 IMG-3556
Tamiya 1/12 Porsche 934 IMG-3558
Tamiya 1/12 Porsche 934 IMG-3553
Tamiya 1/12 Porsche 934 IMG-3554
Tamiya 1/12 Porsche 934 IMG-3552
Tamiya 1/12 Porsche 934 IMG-3561
Tamiya 1/12 Porsche 934 IMG-3562
Tamiya 1/12 Porsche 934 IMG-3560
Ps I've barely started the decals (what ever happened to the English version (which I much preferred transfers) decals, where did that even come from you transfer the image from one place to another what you de (cant even think where cal fits in) sorry rant over, I just dont understand it.
Post by kpnuts Tue 30 Jun 2020, 9:29 pm
Done some work on the fuel tank. a word of caution to anyone building this kit. When it comes to mounting the oil tank, on page one of the instructions it tells you to attach the mount for the oil tank, unless you skip ahead and build the oil tank first dont attach the mount in the first picture the bracket on the left had side is for the oil tank (the shelf with the oblong rail coming out from the side.
Tamiya 1/12 Porsche 934 IMG-3581
The steel pipe laying on its side next to it in the next pic goes into the tank and then into a hole in the bulkhead.
Tamiya 1/12 Porsche 934 IMG-3585
In the position of the next picture.
Tamiya 1/12 Porsche 934 IMG-3580
Here is a picture of the oil tank in position
Tamiya 1/12 Porsche 934 IMG-3583
Getting that pipe into the hole in the bulkhead and into the hole in the oil tank with that bracket in place is impossible (on this model of course that bracket was well and truly stuck) so I cut that rail off in order to get that pipe in then glued it back on again.
A better option would have been to attach the bracket and tank with the pipe on at the same time.
Here are some pics of the fuel tank.
Tamiya 1/12 Porsche 934 IMG-3575
Tamiya 1/12 Porsche 934 IMG-3576
Post by kpnuts Wed 01 Jul 2020, 8:26 pm
I used the kit hoses but I do have some braided hose so may well change those.
Here is where I am now.
Tamiya 1/12 Porsche 934 IMG-3602
Tamiya 1/12 Porsche 934 IMG-3601
Tamiya 1/12 Porsche 934 IMG-3596
Tamiya 1/12 Porsche 934 IMG-3598
Tamiya 1/12 Porsche 934 IMG-3600
Tamiya 1/12 Porsche 934 IMG-3597
Tamiya 1/12 Porsche 934 IMG-3599
Post by kpnuts Fri 03 Jul 2020, 9:03 pm
Thanks Randy
I must say I'm really enjoying this kit (although I thought it would take longer to build )
The seat is just placed there not glued loads to do to that yet.
Tamiya 1/12 Porsche 934 IMG-3620
Tamiya 1/12 Porsche 934 IMG-3614
Tamiya 1/12 Porsche 934 IMG-3613
Tamiya 1/12 Porsche 934 IMG-3618
Tamiya 1/12 Porsche 934 IMG-3621
Post by kpnuts Sat 04 Jul 2020, 8:48 pm
Hi all bought a mirror to mount the 934 on will have the car on axle stands with the engine alongside it, not sure whether to have the tyres stacked or arranged around it, also thinking of putting 2 walls up around it with pictures of the car racing on them I'm going for a look of it being in a museum display.
Any suggestions welcome.
Tamiya 1/12 Porsche 934 IMG-3637
Tamiya 1/12 Porsche 934 IMG-3633
Tamiya 1/12 Porsche 934 IMG-3632
Tamiya 1/12 Porsche 934 IMG-3636
Tamiya 1/12 Porsche 934 IMG-3634
Tamiya 1/12 Porsche 934 IMG-3635
Post by kpnuts Thu 09 Jul 2020, 8:57 pm
Hi all made a start on the axle stands but had a major set back on the bodywork looked great till I clear coated it and it went matt (strange as I sprayed the bonnet and wings exactly the same way and they are nice and glossy)
I decanted the laquer out of the can and sprayed it through my air brush, the only difference being I sprayed the body this morning (it rained over night) I sprayed the bonnet and wings during the day in the sun (i wonder if it was damp and it has bloomed)
Tamiya 1/12 Porsche 934 IMG-3656
Tamiya 1/12 Porsche 934 IMG-3657
Tamiya 1/12 Porsche 934 IMG-3658
Tamiya 1/12 Porsche 934 IMG-3659
Tamiya 1/12 Porsche 934 IMG-3660
Tamiya 1/12 Porsche 934 IMG-3661
Tamiya 1/12 Porsche 934 IMG-3662
Post by kpnuts Sat 11 Jul 2020, 9:26 pm
Hi all I decided to add the brake pipes to this kit and was going to use wire but then realised that the working steering and suspension wouldn't work so I added the bracket to  the suspension leg and then added a flexible hose from that. Should I mention this was my third attempt(no ones perfect)
Tamiya 1/12 Porsche 934 IMG-3676
Tamiya 1/12 Porsche 934 IMG-3678
Tamiya 1/12 Porsche 934 IMG-3677
Tamiya 1/12 Porsche 934 IMG-3674
Tamiya 1/12 Porsche 934 IMG-3673
Tamiya 1/12 Porsche 934 IMG-3675
Post by harron68 Sun 12 Jul 2020, 1:48 am
Superior work, equal to the quality of the kit. The one twelfth scale Tamiyas are remarkable, tho the newer ones have lost some quality as the company struggles to keep the prices from going higher and higher.
Thanx for helping keep the site alive! Warmer weather and an aging membership equals fewer visits from us generally. You're one of our best in building!
Post by kpnuts Sun 12 Jul 2020, 10:58 am
Thanks for the compliment Harron. I will be here till they close the site or they drag me away in a straight jacket.
Post by kpnuts Sun 12 Jul 2020, 7:06 pm
Hi all made a start on the display base, still need to make a tool chest for the back corner.
Tamiya 1/12 Porsche 934 IMG-3691
Tamiya 1/12 Porsche 934 IMG-3693
Tamiya 1/12 Porsche 934 IMG-3689
Tamiya 1/12 Porsche 934 IMG-3690
Tamiya 1/12 Porsche 934 IMG-3692
Tamiya 1/12 Porsche 934 IMG-3687
Tamiya 1/12 Porsche 934 IMG-3688
Post by kpnuts Tue 14 Jul 2020, 9:16 pm
Made a start on a tool chest for it.
Tamiya 1/12 Porsche 934 IMG-3714
Tamiya 1/12 Porsche 934 IMG-3713
Tamiya 1/12 Porsche 934 IMG-3715
Tamiya 1/12 Porsche 934 IMG-3717
Tamiya 1/12 Porsche 934 IMG-3716
Tamiya 1/12 Porsche 934 IMG-3718
A5h likes this post
Post by kpnuts Thu 16 Jul 2020, 9:10 pm
Ok so I need something on the tool chest but most of the car is built so not much choice but the rear suspension, problem is the spring plate is moulded integral with the suspension arm (on the car if you were working on the suspension arm you would have left the spring plate on ) so I cut it off and made a new spring plate separate to put on the car (still got to make the casters for the tool chest)
Tamiya 1/12 Porsche 934 IMG-3732
Tamiya 1/12 Porsche 934 IMG-3734
Tamiya 1/12 Porsche 934 IMG-3738
Tamiya 1/12 Porsche 934 IMG-3735
Tamiya 1/12 Porsche 934 IMG-3737
Tamiya 1/12 Porsche 934 IMG-3736
Post by kpnuts Wed 22 Jul 2020, 9:28 pm
Hi all well the front end is finished. On the last leg now.
Tamiya 1/12 Porsche 934 IMG-3748
Tamiya 1/12 Porsche 934 IMG-3747
Tamiya 1/12 Porsche 934 IMG-3745
Tamiya 1/12 Porsche 934 IMG-3746
Tamiya 1/12 Porsche 934 IMG-3749
Post by kpnuts Thu 23 Jul 2020, 10:21 pm
Damaged the roof and had to respray the whole thing again (if the rest of the masking comes off like this I think I got away with it)
Cut some of the tiles away from the edge to give a bit more room to display things.
Tamiya 1/12 Porsche 934 IMG-3755
Tamiya 1/12 Porsche 934 IMG-3757
Tamiya 1/12 Porsche 934 IMG-3756
Post by kpnuts Sat 25 Jul 2020, 9:25 pm
Did some work on the boot lid and the body.
Tamiya 1/12 Porsche 934 IMG-3788
Tamiya 1/12 Porsche 934 IMG-3789
Tamiya 1/12 Porsche 934 IMG-3785Tamiya 1/12 Porsche 934 IMG-3787
Tamiya 1/12 Porsche 934 IMG-3793
Tamiya 1/12 Porsche 934 IMG-3791
Tamiya 1/12 Porsche 934 IMG-3792
Post by kpnuts Sun 26 Jul 2020, 9:30 pm
Hi all I saw these dental sticks in a shop somewhere and thought they must be usefull in modelling, well I've found a first use for them.
Tamiya 1/12 Porsche 934 IMG-3815
Tamiya 1/12 Porsche 934 IMG-3814
Tamiya 1/12 Porsche 934 IMG-3813Tamiya 1/12 Porsche 934 IMG-3816
Tamiya 1/12 Porsche 934 IMG-3817
Also made the casters for the tool chest.
Tamiya 1/12 Porsche 934 IMG-3818Tamiya 1/12 Porsche 934 IMG-3820
Tamiya 1/12 Porsche 934 IMG-3819
Tamiya 1/12 Porsche 934 IMG-3821
Tamiya 1/12 Porsche 934 IMG-3822
Post by kpnuts Wed 29 Jul 2020, 9:13 pm
Made a start on the various pipes and cables for the engine bay.
Tamiya 1/12 Porsche 934 IMG-3836
Tamiya 1/12 Porsche 934 IMG-3846
Tamiya 1/12 Porsche 934 IMG-3850
Tamiya 1/12 Porsche 934 IMG-3847
