Drilling a dist. cap
4 posters
Hi Gang and I have a question about drilling a dist. cap so the holes are in a circle and spaced properly....
HOW DO YOU DO IT ??
I've tried a couple ways but no luck.
HOW DO YOU DO IT ??
Re: Drilling a dist. cap
The kit ones seem to have little lugs on them, I cut these flat and then use a needle as a centre punch to get a starting point using the lugs as a reference for position. Then drill with a micro drill in a pin vice.
If you're making your own then use the needle again to start you off, punch the centre first then evenly space the outer points (easier with 4 and 8 cylinder by marking the opposing positions as you go round ( I.e. 12 o'clock, 6 o'clock, 3 ... Then 9 etc) bit harder and more fiddling with position with a 6 banger)
Hope this helps
Hope this helps
What snake said, but I wouldn't worry about perfection, lol. Just take your time.
midnightprowler- Intermediate Member
Thanks guys
Colin I never thought about using a needle as a center punch now I just have to figure out how to see them with my going blind eye's
Oh, and I sometimes use a jewellers eyepiece to get the centre with a needle.
Cheapo magnifying reading glasses come in some reasonable strengths ..... i sometimes pop a 2x pair over my prescription modeling glasses (made for me as a 12 inch focal length) to get some smaller bits a decent size to work on.
worth picking a pair up, i've seen some good quality pairs up to 5x in my local pharmacy for around 8-10 pounds so i would imagine 15 - 20 dollars would get you a good set over there
I already have cheapo reading glasses that go to 350 but my prescription ones are 275 ( blind in one eye and can't see out of the other )
I also have a visor magnifying set that I use over my prescription glasses and they work pretty good so I'll just have to play with the lenses on the visor to get the right strength.
Thanks for all the help guys, very usefull
I use the same method that others have described. I use a 2X magnifier and a drill bit that is .013" a Number 80 in wire scale. Like everyone said it is a skill that has to be learned but once you get it it's becomes easier with every one. I think the two best tips are filing the nubs so they are flat and using a straight pin for a center punch. Oh And the not too much pressure one rocks also.
Unfortunately my eye sight is not the best anymore and my hands are not as steady as they once were so I kind of cheat and use metal tubing I picked up with number 80 wire and make my plugs this way. I then get a thicker gauge of wire, remove the wire within and use as the boot
Hendo- New Member
