'33 Willys Van Gasser.
5 posters
This is the other build from the same cbp as the Austin Gasser.
This kit has some major fit issues and poor tooling, but it can be sorted. The nose in particular is pretty bad.
Got the nose almost sorted
A little bit of filler and should be done.
Some more filler here, I assume they have something to do with the coupe as nothing in this kit corresponds with those 3 divets.
Reinforced the inside of the firewall
Basic engine assembled, need to make the engine mounts wider as it drops straight through the frame.
That's just the start, the saga will continue.
stevegt738- Rookie Member
Re: '33 Willys Van Gasser.
Plenty of masking tape to see how it all fits together.
Will need some filler pieces to fill those gaps.
1 mm square rod to make a more secure engine location
Also added some styrene to the ends of the engine mounts to eliminate any sideways movement.
Made the diff mounts on the springs wider for a stronger adhesion.
Stripped the chrome as the parting lines need a lot of clean up
First mock up, here you can see the rear tyre is almost touching the front of the arch. The other side is centered.
After lots of care full measuring of everything, it was found that the diff mount is slightly further forward than the other side. I trimmed some of the rear spring mount and some scrap styrene to the front mount, and using a off center AMT slick it all sits were I want it too.
Decided to change the wheels
Hood fit is not the best
Tilted the center mount (it was vertical) so the drive line matches up better, and added some styrene to the dive shaft to eliminate the gap at the center mount
It best to not be over enthusiastic when removing a twist in the chassis
That's it for now.
That's nice work blending in the headlights John.
Not sure I like the rear steelies though. Makes it look like a Jalopy IMO.
So now that I have the basic configuration and fit problems sorted, I started to play with ideas.
Which engine to choose?
Could not decide which V8, so I went for a resin flat head Plymouth i6. That should make it a bit more unique.
And steelies all round.
Made some noise makers out of 1.5mm solder
While scrounging through junk pile boxes I found these. Large one is AMT '57 Ford, Small One is AMT '64 Mercury Marauder.
Small one fits like it was always meant to be there
Now to create all the pipe work, and find or scratch up a Magneto.
As there is no scoop on this engine I filled the bonnet hole, using one of Ed Fluck's resin pieces as a guide.
Started to work out the logistics of getting all those little pieces in the interior bucket when it dawned on me that this is a van, so removed the back wall behind the seats.
Completed engine
In its new home
Started on filling gaps.
This shows how much twist the chassis has, yet all 4 wheels are one the ground.
Spreading the bonnet to fit the body better, just need to get some heat to it.
Remade all the door hinges
Ed Fluck (forums sig - krassandbernie) mentioned above gave me the idea to redo the door hinges on these old AMT kits.
This was my first attempt at doing them, and my '40 Ford Sedan Delivery was the 2nd.
Here is the link to his '40 Coupe gasser build that shows how he did them (pics 111 to 113).
Mine were done slightly differently, but the overall effect is the same.
http://public.fotki.com/drasticplasticsmcc/1/ed_fluck/nostalgia_drag_racing/39-ford-/page4.html
Completed engine
In its new home
Re primed the body
The hinges look better now with some colour. Have also got the bonnet to fit better.
Completed the chassis.
Started painting the interior.
Skid wrote:That's nice work blending in the headlights John.
Didn't know I'd changed my name Al.
Late '50s to mid '60s Gassers ran all sorts of wheels and in any combination.
Check out the Gassers section on this site.
http://wwww.georgeklass.net/index.html
WARNING THOUSANDS OF IMAGES - NOT RECOMMEMDED IF YOUR INTERNET IS SLOW..
Didn't know I'd changed my name Al. wrote:
Whoops!
Sorry Steve!
Nice work all around.
Altho I'm a fan of HUGE engines with lots of attitude, That flathead Ply. looks great !!
This is a great subject and you are doing a good job on it. The fit of the hood to the body as always been an issue with this kit. You solved it very well, Love the flathead Six.
Clay, I like monster engines as well, but I wanted to differentiate this build from all the box stock Willys builds I've seen. I'm thinking the Cammer out of the Willys might end up in a "T".
Buck, I'll post some pics of the changes I made to get it to fit better later.
This is my modified tilt nose set up.
There is a 1mm difference in the front frame rails length which is the main reason for the poor fit, and the chassis rails also have a twist to them which is hard to remove without breakages. I found that out the hard way. The angle of the trailing edge of the nose and the leading edge of the body is slightly different from side to side, resulting in another gap.
The first thing I done was to remove the tilt pins from the chassis and put some 1mm square rod at the ends.
Then I glued some rod into the pivot holes in the nose
Then I trimmed the left side rod to compensate for the twist in the chassis rails to get the nose sitting square with the body. Then I worked on the nose to cowl fit with till it looked acceptable. So now the nose no longer tilts but sits on the chassis with a better fit.
Hope this is helpful to some one that wants to have a go at one of these AMT Willys. The same applies to the '33 Coupe as well.
I also got enough of a break in the weather to prime the Willys, Austin & the '40 Ford bodies.
Neat job Steve. Thanks for showing how you did it!
Yup .. little tips like this help out ...thanks.
Nice smooth primer job, looks flawless from here
Super solution on the front end probs. Luv the six up front. Only weakness is the one-piece look to the supercharger-to-carbs piping. I'd add some sort of demarcation, like hose clamps or scored spots to look like separate sections. Different shade of silver, too, would make it look more multi-piece.
Interior is finished.
A coat of white primer.
It will probably be yellow.
harron68 wrote:Only weakness is the one-piece look to the supercharger-to-carbs piping. I'd add some sort of demarcation, like hose clamps or scored spots to look like separate sections. Different shade of silver, too, would make it look more multi-piece.
I had wondered about that, me knowing where the joints are doesn't help anyone else either. I used 3 different shades of Aluminium which is very visible to the eye, but my camera is a bit dumb at distinguishing the differences. I'll give a black wash at the joints a go and see if that helps.
Cool work so far. I admire the patience you have for "getting things right." Bad alignment and warpage are real probs sometimes. Thanx!
It's looking good Steve. Interior is spartan as it should be.
Finally got colour on this. Tamiya TS34 Camel Yellow decanted and sprayed through the air brush.
Getting closer.
Getting closer.
Now that's a proper colour.
» 33 Willys Gasser
» Ohio George's 33 Willys Gasser
» 1933 Willys Gasser (Ohio Geaorge)
» Austin Gasser
» ‘65 Corvette Gasser (1/8th)
» Austin Gasser
