 Good Third Hand
PostSubject: Good Third Hand   Mon 25 Feb - 17:13
I use handi-Tack for so many things. It never seems to wear out. If it starts to get a little hard just stretch it a few times and it's soft and good to go.
This stuff works get for mocking up parts. I have used it as a mask when painting. It can also be used to hold parts when you are painting them.
Cheap at any Walmart or Staples around. I have been using this one pack since 2004.
PostSubject: Re: Good Third Hand   Fri 29 Nov - 8:55
Hi,
Could someone tell me is this the same as Blue Tack that is sold here in the UK...
Thank you...
PostSubject: Re: Good Third Hand   Fri 29 Nov - 10:29
Yes John, it's called Blu Tak over here. Been using it for years!!
PostSubject: Re: Good Third Hand   Fri 29 Nov - 10:51
Thank you Sir...
PostSubject: Re: Good Third Hand   Fri 29 Nov - 13:01
No problem.
Here's one use for it:
PostSubject: Re: Good Third Hand   Fri 29 Nov - 16:13
This is something I have never thought of using, thank you both...
PostSubject: Re: Good Third Hand   Sat 30 Nov - 3:39
Sweet. I've used tape for the same job, but Blu-Tac is the go from now on.
Thanks for posting it Buck.
PostSubject: Re: Good Third Hand   Sun 1 Dec - 22:57
I ues SILLY-PUDDY in the egg shape container for a lot of things like you use HANDI-TAK
PostSubject: Re: Good Third Hand   Sun 1 Dec - 23:07
That stuff really comes in handy. BTW, Hobby Lobby sells an off brand of the same stuff really cheap. It can usually be found on a rack near the check out.
PostSubject: Re: Good Third Hand   Mon 2 Dec - 5:59
Blu Tac is the big brand name over here but I just by the cheapest generic stuff available. It does the same job.
PostSubject: Re: Good Third Hand   Wed 4 Dec - 14:27
Cool tip! I will keep it in mind!
Gothic Kustomz
PostSubject: Re: Good Third Hand   Wed 4 Dec - 14:40
nice
PostSubject: Re: Good Third Hand   Wed 4 Dec - 19:02
blu tac is great stuff.........use it for holding parts whilst painting, use it for making masks whilst doing camo patterns, even used it for ballast in the nose of aircraft when ive had nothing better at hand
Good Third Hand
» Good, successful writer websites?
» Link to Dynaco SCA-35 rebuild article - good information
» Night Goblins, I never was good at painting greenskins...
» Good things can happen when you're taking out the garbage.
» Gamemaker pro = good FPS maker?
