Left For Dead Part 1
Gothic Kustomz
This is part 1 of this Diorama build. I know I'm doin' this a bit backwards by starting on the cars first and not the base and buildings. But I promise I'll get there. The title will change as things progress so let's prepare for this journey.
This is the Junker Charger. It's a 1971 Dodge Charger R/T I gave a friend of mine named Pete M. He wanted to try a model and was going to do a diorama with this car. Upon his passing his wife found it in a desk drawer and gave it back to me. She felt I could finish where he left off. It has been moved around a few times, box got crushed, body separated from the pan, and a few parts became AWOL. But I got parts and spares of a few parts so I'll manage.
What I started with: Passenger side was crashed on the car, doors, trunk lid, and a fender were removed from the body. Some of the interior has been assembled. The door jambs have been made with Bondo, the driver door had the interior panel attached with 5 minute epoxy and then Bondo'd in the holes to complete the door. Here's the pics.
Continued .... :scratch:
Re: Left For Dead Part 1
Before I could continue on with the my part of the contribution. I had to figure out how to get the dash in place and make it where I could still remove it in needed. So my solution was simple. Two pieces of square tubing that slide into one another. I attached one to the underside of the cowl with MEK and then stuck the other tube inside that one and put some glue on the other end where it would meet the dash. And presto! It holds the dash like the factory did and looks correct for what I needed.
See y'all soon with the next installment to this project! 8)
I really want to see where you go with this dio. Right now it looks like it could be sitting in a vacant lot with a couple of bums warming their hands around a barrel.
Looks good, Jason!
Like the tire separated from the rim. 8)
Junkin 'em sure is fun, eh?
Looks like this will be fun.
Gothic Kustomz- New Member
Great start, looks like a major fender bender happened :affraid: John
Thanx everyone for the comments. This is a tough build as I've never done a severe weathering job on a model before. I'm hoping that I can finish what someone else has started. Not easy stepping into someone else's shoes.
Here is another shot of the dash in place on it's hanger.
As you've seen in previous pictures the driver door is now hinged, there is patch panel to cover the hole in the firewall where the fender was removed.
Yes it sags like all these big doored cars do after all the years of neglect.
I have drilled holes in the engine bay to simulate where the missing fender would bolt up. I've also made some of the inner fender details. I did put a lip on the fender and drilled holes to mimic the mounting points.
Then I started in on the brakes. I took a few bits and turned it into the rear brake backing plate, axel hub, and lug studs.
And I've started the same process to make the front disc brake.
Enjoy! 8)
Enjoy! 8)
As yer finding out, Jason, the nature of this genre does not require super neatness. Attention to details is what sells this junker stuff. Realistic weathering and appropriate detailing make it happen.
You are doing a great job !!
Looks like it should. Good eye for the detail. I like the bolt holes in the fender. Nice touch. The brakes are going to be cool when worked out.
Thanx guys for the comments and compliments. I've always heard the Devil is in the details and for some reason it's so true with this build. I'll get this done someday. LoL
Ok. I've sat down at the desk with Laptop beside me and worked on a few fiddly bits. I got the hood latch bracket and the lower valance mounting brackets made up and installed.
Then moved my attention to the truck area. I already had the inner lip made but it still lacked some detail and looked rather crude. So I added another strip to connect the two sides, made a flat panel to hide the rear bumper/taillights when assembled, and added a .10 diameter rod to simulate weather stripping.
Next it was time to work on the headlights and brackets that hold the buckets. So I broke out some extra headlights I had and filed them down to look like buckets. Make the brackets out of styrene sheet .20 in thickness. And here is where I am now.
So there ya have it. I'm still workin' on other li'l fiddly bits and then it'll be time to hit it with Primers, paints, and try and weather it up some. Enjoy! 8)
Awesome detail and scratchbuildin' Like it a lot. John
Lots of attention to lots of details, Jason. A fine start.
I missed this on at the begining and just caught up.
Great stuff Jason and I like the way you attached the dash.
Enjoying your build, as I'm sure you are !! :drunken:
Heavy Duty! You're doin a bang up job :D
You have a real winner going here Jason. Your attention to detail is astounding.
The detail is great. I'm looking forward watching where this goes.
Damaged vehicles are always a tuff challenge. Once you do one thing well, you want to do the rest as good. It takes time and there are usually a few imperfect defects, but doing what you can and seeing the finished model makes it worth while. Good luck!
» Took A Left At Albuquerque
» Oh, No !!! Who left the door open ?
» I'm back!! I'm not dead, tho .....
» US based car part
» 71 Hemi Cuda part two
» US based car part
