1/8 scratch build porsche 904
5 posters
Hi all well move went well new job is going well and I have negotiated a modelling area (well when we don't have guests that is) so gulp I've jumped in to try this scratch build, ive managed to find some profile drawings of the body so I've copied them onto paper and glued it to this ply wood.
I'm hoping to make a former from this as a rough starting point. I'm expecting this to beĀ a long build, somewhere between 3 and 60 years (but that's just an approximate guess could be much longer ;)
Re: 1/8 scratch build porsche 904
Now that is ambitious, best of luck Ken. It looks to be a huge project.
An ambitious project indeed. Will you be using any existing components, eg wheels, or all scratch built?
Hi thanks, yep big project, I don't have any existing parts so yes all scratch built.
A very brave endeavor indeed. Good Luck with that one.
An ambitious project indeed! Looking forward to watching this develop and evolve.
Well first lesson learned I tried to made a cylinder head and bought card stock of the correct thickness and cut out 15 cylinder bits and 17 fins then glued them together after which they should have measured 10.25 mm well after gluing 10 of the fins together it measured 13 mm so I thought I will compress them in my vice trouble with that was it compressed the cylinder bits but not the fins and ended up looking like this
Instead of how it should look. I can only assume the extra thickness was due to the glue so I think I will have to experiment with different thicknesses.
That's quite a major project you're taking on.
Mike C- Rookie Member
» Porsche 1/8 scratch build
» scratch building 1:1
» Scratch built PS Waverley
» Scratch built 1/32 SS Wilton Castle
