MFH Ferrari 312PB
+3
7 posters
MFH Ferrari 312PB Empty MFH Ferrari 312PB
Post by Guest Fri 28 Sep 2018, 12:38 am
I got this kit last year and the itch to start playing with it finally got the best of me.  It will build any one of 14 different cars from the 1972 season.
MFH Ferrari 312PB 2v298fa3rxHpLjS
MFH Ferrari 312PB 2v298wBvqxHpLjS
MFH Ferrari 312PB 2v29zy5ndxHpLjS
MFH Ferrari 312PB 2v29zy5qyxHpLjS
MFH Ferrari 312PB 2v29zy5dNxHpLjS
MFH Ferrari 312PB 2v29zy5yrxHpLjS
The first thing the instructions call for is building the chassis.  I got the pieces out and cleaned them up, drilled holes and polished the white metal.  I temporarily dry-fit the pieces and held them together with rubber bands.
MFH Ferrari 312PB 2v2JrLZroxHpLjS
MFH Ferrari 312PB 2v2JrLZj2xHpLjS
MFH Ferrari 312PB 2v2JrLZ83xHpLjS
MFH Ferrari 312PB 2v2JrLZzrxHpLjS
MFH Ferrari 312PB 2v2JrLQojxHpLjS
MFH Ferrari 312PB Empty Re: MFH Ferrari 312PB
Post by dublin boy Fri 28 Sep 2018, 7:27 pm
Art and Sandro version please Paul.
Post by Guest Sat 29 Sep 2018, 10:02 pm
dublin boy wrote:Art and Sandro version please Paul.
Sorry Shay, I'm leaning towards the Ickx/Regazonni version.  I like both drivers and the accent color is yellow.
I put the wheels together, and tried the tires.
MFH Ferrari 312PB 2v2JrLQ28xHpLjS
MFH Ferrari 312PB 2v2JrLQ3MxHpLjS
I also started the engine.
MFH Ferrari 312PB 2v2JrGg4MxHpLjS
MFH Ferrari 312PB 2v2JrGgmzxHpLjS
MFH Ferrari 312PB 2v2JrGgV3xHpLjS
MFH Ferrari 312PB 2v2JrGgCUxHpLjS
Post by dublin boy Sat 29 Sep 2018, 11:16 pm
Gorgeous wheels Paul, I knew you'd go for the F1 guys.
Post by Guest Sun 30 Sep 2018, 1:02 pm
Looking good Paul.
Post by KatsZenJammer Sun 30 Sep 2018, 4:55 pm
Great start! These MFH kits are something else - looking forward to seeing the bazillion little details coalesce into one truly cool build.
Post by RetiredMike Mon 01 Oct 2018, 2:20 pm
Great to watch one of those fine kits go together.
Post by Geezerman Mon 08 Oct 2018, 12:32 pm
MFH Ferrari 312PB 1705482731
MFH Ferrari 312PB 2776978727
Post by NISMOR34 Thu 22 Nov 2018, 2:23 am
just a technical inquiry sir ,ive never worked with a multimedia type kit are the white metal bits difficult to work and what type of glue or adhesives do you use on them ?? pardon my utter stupidity im quite fascinated by the mfh kits but the price point definitely holds me back from purchasing one
NISMOR34
NISMOR34
Post by kpnuts Wed 02 Jan 2019, 10:00 pm
Superb work on a great kit.
Post by GaryDainton Thu 03 Jan 2019, 11:08 am
These kits are superb, great work Paul. popcorn
Post by Guest Fri 04 Jan 2019, 9:47 pm
Thanks guys
NISMOR34 wrote:just a technical inquiry sir ,ive never worked with a multimedia type kit are the white metal bits difficult to work and what type of glue or adhesives do you use on them ?? pardon my utter stupidity im quite fascinated by the mfh kits but the price point definitely holds me back from purchasing one
Chuck, sorry for the delayed reply.  I haven't been to the bench in two months, and missed your post.  Working with white metal isn't all that difficult.  The pieces don't necessarily fit together and usually need a little tweaking to fit properly.  But being white metal, you can bend/change their shape.  It's sort of like scratch building were you need to 'fit' each part.  Also, most WM kits don't have any of the holes drilled for locating pins.  So a set of drills is a must.  I usually use either CA for adhesive, or epoxy for a joint that would need more strength.  WM also needs a little more prep.  I use a brass brush to scuff/clean the parts, then go after any seams with a file or sanding sticks.  For a more polished surface, I have been using #000 and #0000 steel wool.
MFH Ferrari 312PB 2v22zSZiFxHpLjS
Don't worry over your lack of knowledge regarding these kits. If anything, ask as many questions as you want. I'm more than happy to pass on what I've learned while building these kits. For a price comparison, look at a Tamiya Porsche 935 in 1/12th. Kits are in the $150 range and the SMS set was sold at $500. The SMS kit was all of the turned metal and p/e needed to super detail that kit. So when you consider what you get in a MFH kit, it's really not that bad. It's just that you pay it all at once rather than to two or three vendors. Plus most of the MFH kits are subjects no one else does. Like this car.
