 Community Build #28 - World War One Aircraft
Community Build #28 - World War One Aircraft - Page 2 Empty
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeFri 21 Sep 2018, 2:32 pm
RetiredMike wrote:
Steel rod or even wire is a good alternative.  It can be roller straightened and easily cut to size.  Would look better on a 1/32nd scale model than it did on my 1/72nd Airco.
Community Build #28 - World War One Aircraft - Page 2 Dh2-9010
Wow nice work Mike, from here the rigging does not look out of scale. That sure is a ton of rigging to do.
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeSat 22 Sep 2018, 3:56 pm
Thanks, Curt. I tried that method because there were so many. When I'd place EZLine on a spot, stretching later pieces would cause previous ones to sag.
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeTue 09 Oct 2018, 9:42 am
Well, I have some catching up to do.
Al; nice to see you joining in. As is usual, you are doing some fine work.
Mike and Paul; I feel your pain.
I have just gotten started on the upper wing frame. The photo etch is delicate to say the least. The center beam really does help to stabilize the frame. Now another test as I go about attaching the ailerons?
Community Build #28 - World War One Aircraft - Page 2 Dscn8812
Community Build #28 - World War One Aircraft - Page 2 Dscn8813
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeWed 10 Oct 2018, 8:42 am
The upper wing is complete. Now to the center wing. The photo etch is holding up well considering all the bending of parts that takes place.
One area of minor disappointment is the wing leading edge. The resin forming jig did not produce the desired contour, or a consistent result.
Community Build #28 - World War One Aircraft - Page 2 Dscn8815
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeSat 27 Oct 2018, 6:37 pm
Well, I think I'll call this one complete.  I won't put the flap controls on for fear I'll botch up the camo decals.  So, here it is.
Community Build #28 - World War One Aircraft - Page 2 Fokker25
Thanks for your comments and for looking,
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeSat 27 Oct 2018, 6:41 pm
Cole: That looks like a real test of patience you have on your hands. Nice work.
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeSat 27 Oct 2018, 11:04 pm
Very beautiful. The camouflage patterning makes the flimsy plane look solid. Fine work, lovely addition to any collection!
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeThu 08 Nov 2018, 7:49 am
Nice work Mike.
I have finished the wings for the tri-plane. Now to get started on the fuselage. This looks to be interresting...
Community Build #28 - World War One Aircraft - Page 2 Dscn8910
Community Build #28 - World War One Aircraft - Page 2 Dscn8912
Community Build #28 - World War One Aircraft - Page 2 Dscn8913
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeThu 08 Nov 2018, 2:48 pm
Very nice detail, Cole.
Bending the fuselage parts can be very tricky. What I used on a recent PART PE fuselage was a pair of kitchen knives. The top one at the bending line, holding the piece down and the other slid underneath. Then just twist the lower knife upright for a good straight bend.
Great work, again.
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeFri 09 Nov 2018, 1:28 am
Thanks Mike. Years ago, I purchased a PE tool from The Small Shop. It has worked very well for me.
https://www.micromark.com/
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeSat 10 Nov 2018, 9:00 am
This particular operation has been rather nerve wracking. But I am impressed at the engineering that went into designing this kit. After I figure out how to install the seat and harnesses into the cockpit I can breathe a sigh of relief.
Community Build #28 - World War One Aircraft - Page 2 Dscn9010
Community Build #28 - World War One Aircraft - Page 2 Dscn9011
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeSat 10 Nov 2018, 7:38 pm
Wow! Slow and steady gets the job done, good so far!
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeTue 08 Jan 2019, 6:39 am
Finally some progress to report. The seat frame did not hold up to my heavy handed technique. So I had to improvise. The result is not as detailed as the original frame but it will suffice. The lower wing has been attached. Now it's on to the tail. Then I can begin thinking about the engine.
Community Build #28 - World War One Aircraft - Page 2 Dscn9114
Community Build #28 - World War One Aircraft - Page 2 Dscn9113
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeTue 08 Jan 2019, 3:30 pm
Nice to see this continuing. Great work and greater patience, Cole. Community Build #28 - World War One Aircraft - Page 2 1817768433
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeThu 10 Jan 2019, 11:56 am
Thank you Mike.
The tail and engine assemblies are next in line.
Community Build #28 - World War One Aircraft - Page 2 Dscn9115
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeThu 10 Jan 2019, 3:55 pm
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeFri 11 Jan 2019, 11:23 am
Eduard went to a good deal of trouble on the wheel rims. The resin forming tools produce a concave/convex spoked rim. It will likely be unnoticeable on the finished model.
Community Build #28 - World War One Aircraft - Page 2 Dscn9121
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeFri 11 Jan 2019, 2:40 pm
Tool does a great job on those wheels. Often when I try to dish those wheels, it'll put a wiggle or a kink in the outer ring. Nice job.
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeFri 11 Jan 2019, 2:47 pm
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeSun 13 Jan 2019, 1:53 pm
Thanks Mike.
The tail, rudder, and rear landing gear is now in place. Also, the engine assembly is now ready. First I need to attach the throttle to the port side. Then I can figure out how to install the power plant.
Community Build #28 - World War One Aircraft - Page 2 Dscn9124
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeTue 15 Jan 2019, 4:21 pm
Throttle detail in 1/72nd? That's pretty cool!
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeTue 22 Jan 2019, 6:36 am
Hello Mike. It is, but will be covered up by the body skin later.
Now, I'm working on the weapons system.
Community Build #28 - World War One Aircraft - Page 2 Dscn9125
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeWed 23 Jan 2019, 8:17 am
The kit is slowly coming together, but I continue having problems with parts coming apart. A test fitting of the wings and upper fuselage.
Community Build #28 - World War One Aircraft - Page 2 Dscn9128
Community Build #28 - World War One Aircraft - Page 2 Dscn9129
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeThu 24 Jan 2019, 3:04 pm
Amazing seeing an entire plane built of PE parts, especially in micro scale!
Nice job. popcorn
PostSubject: Re: Community Build #28 - World War One Aircraft   Community Build #28 - World War One Aircraft - Page 2 Icon_minitimeThu 24 Jan 2019, 8:45 pm
Museum quality!!!!
» "Its a small world after all." by Chrono
» Kinetic Models 1/48th Scale E-2C Hawkeye
» The Wally World Cargo Mat Mod
» Most expensive aquarium in the world
