 1993 Lotus Esprit Sport 300 Turbo
Go to page : Previous  1, 2
1993 Lotus Esprit Sport 300 Turbo - Page 2 Empty
PostSubject: Re: 1993 Lotus Esprit Sport 300 Turbo   1993 Lotus Esprit Sport 300 Turbo - Page 2 Icon_minitimeSat 24 Feb 2018, 3:44 pm
Sorry for your trouble Mitch. This is looking like a monster. I'm interested to see how the pilar turns out, good luck.
PostSubject: Re: 1993 Lotus Esprit Sport 300 Turbo   1993 Lotus Esprit Sport 300 Turbo - Page 2 Icon_minitimeSat 24 Feb 2018, 6:56 pm
RetiredMike wrote:
Paint and interior look great.
I put my flocking through a kitchen sifter to keep it fine and fluffy.
Thanks Curt. Do you sift it before you put it away or before/during application?
PostSubject: Re: 1993 Lotus Esprit Sport 300 Turbo   1993 Lotus Esprit Sport 300 Turbo - Page 2 Icon_minitimeMon 26 Feb 2018, 3:42 am
I decided to share the images of my mishap. Its been a less than straight forward repair. The piece that broke out of the A pillar glued back in with very little issues. You could barely even see the cracks. However when I test fitted the side windows there was a 2mm gap around the top front corner about 5mm going down the A pillar and along the roof rail. And the windshield didn't fit well either. I decided to install the windshield and use it as support for reattaching the broken piece. I figured if the windshield fit nicely then the side glass gap would go away. Nope. After everything dried I tested fitted the side glass and the gap was maybe a little worse. I took the windshield back out and removed the piece for the third time and installed the side window assembly. After that was dry I test fitted the broken A pillar piece and it wasn't close to fitting. I had to sand a mm off of both ends to get it to fit. I then test fitted the windshield and it only needed a little filing to fit. Bizarre...
Anyway I got it all lined back up and I masked off the side window and puttied the A pillar and the roof rail where it had cracked too.
I have it primered and the first coats of color on. Hopefully I haven't ruined an otherwise successful build.
1993 Lotus Esprit Sport 300 Turbo - Page 2 20180154
1993 Lotus Esprit Sport 300 Turbo - Page 2 20180153
1993 Lotus Esprit Sport 300 Turbo - Page 2 20180155
PostSubject: Re: 1993 Lotus Esprit Sport 300 Turbo   1993 Lotus Esprit Sport 300 Turbo - Page 2 Icon_minitimeMon 26 Feb 2018, 10:27 am
I must say, this is an astounding repair job. It's things like this that makes the hobby worthwile.
On a side note about flock. I used to have nothing but trouble with it until I started using very fine felt, the kind you might find in jewellry boxes, less messy and makes you feel like a proper carpet fitter when applying it.
PostSubject: Re: 1993 Lotus Esprit Sport 300 Turbo   1993 Lotus Esprit Sport 300 Turbo - Page 2 Icon_minitimeMon 26 Feb 2018, 12:09 pm
Well done Mitch. Thanks for sharing. 1993 Lotus Esprit Sport 300 Turbo - Page 2 1705482731
» FS: 1996 Cadillac Fleetwood Brougham $1,800.00
» F/S 1993 Caprice LS Sedan
» Lotus 107B
» 1991 1992 1993 CHEVY CAPRICE NOS GM QUARTER PANEL P71 LT1
» OTTO Sunbeam Lotus Monte Carlo 1/18 in stock now
