 MFH Porsche 917K "Michael Delaney"
MFH Porsche 917K "Michael Delaney" Empty
PostSubject: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeThu 15 Feb 2018, 11:17 pm
I had planned to do this build after the LH car, but when that build was put in limbo, and not knowing where it was going, I started the 917K.  It was the other Porsche that started the 70 Le Mans at the front.
MFH Porsche 917K "Michael Delaney" 2v2JQcB1qxHpLjS
MFH Porsche 917K "Michael Delaney" 2v2JQcQvgxHpLjS
MFH Porsche 917K "Michael Delaney" 2v2JQcfanxHpLjS
I also like this car because of Michael Delaney.
MFH Porsche 917K "Michael Delaney" 2v2JQcfHGxHpLjS
The un-boxing.
MFH Porsche 917K "Michael Delaney" 2v29y2h8WxHpLjS
.html" class="postlink" target="_blank" rel="nofollow">MFH Porsche 917K "Michael Delaney" 2v29y2C2FxHpLjS
.html" class="postlink" target="_blank" rel="nofollow">MFH Porsche 917K "Michael Delaney" 2v29y2C9NxHpLjS
.html" class="postlink" target="_blank" rel="nofollow">MFH Porsche 917K "Michael Delaney" 2v29y2CEnxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29y2CedxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29y2CbNxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29y2CcqxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29y2CAyxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29y2hnWxHpLjS
First order of business was to lay out all of the parts and get them into their respective steps.  Fortunately...MFH has parts lists on their website which I used to identify the parts by number.
MFH Porsche 917K "Michael Delaney" 2v29y2hNyxHpLjS
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeSat 17 Feb 2018, 6:52 pm
Bodywork was taped together so I could check the fit.  Started tweaking the white metal doors to fit
MFH Porsche 917K "Michael Delaney" 2v29yHatGxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29yHHyhxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29yHHLyxHpLjS
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeSat 17 Feb 2018, 10:05 pm
Engine parts for the K version are identical to the LH version.
MFH Porsche 917K "Michael Delaney" 2v29NGjArxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29NGj68xHpLjS
MFH Porsche 917K "Michael Delaney" 2v29NGjYFxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29NGj7dxHpLjS
Curtis
Curtis
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeSat 17 Feb 2018, 10:17 pm
MFH Porsche 917K "Michael Delaney" 1705482731 Good stuff Paul. I assume you can just 'bend' the doors to fit them.
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeSat 17 Feb 2018, 11:08 pm
Curt, the white metal is fairly stiff, but has enough give to take a shape.  I've been using various things like dowels and the rounded edges of furniture (don't tell my wife) to help with the complex curves.  The problem is the top and bottom bodywork need to be fastened firmly together to get the opening in the right shape, but still be able to be taken apart to be painted.  I'm thinking some sort of white glue that is water soluble so I can un-bond the pieces.
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeSat 17 Feb 2018, 11:12 pm
Front sub-frame assembly.  Again, similar in appearance to the LH car, but I assembled this one using CA
MFH Porsche 917K "Michael Delaney" 2v29NGjs5xHpLjS
MFH Porsche 917K "Michael Delaney" 2v29NGjPNxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29NGjkrxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29NGjijxHpLjS
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeSun 18 Feb 2018, 10:23 pm
Same engine framework as the LH car.  With a mock-up of the finished pieces.
MFH Porsche 917K "Michael Delaney" 2v29NGjD8xHpLjS
MFH Porsche 917K "Michael Delaney" 2v29NGj4MxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29NGjmFxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29NGjTdxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29NGjV5xHpLjS
Curtis
Curtis
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeSun 18 Feb 2018, 11:01 pm
Looking good man. Lol @ using the furniture. Try this stuff Paul, it is pretty tough and is water soluable.MFH Porsche 917K "Michael Delaney" Img_0732
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeMon 19 Feb 2018, 12:43 am
Curt, is that a glue?
Almost all of the rear frame completed.
MFH Porsche 917K "Michael Delaney" 2v29jvofqxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29jvoAFxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29jvoBdxHpLjS
The last two pieces at the rear appear to be too long.  Thinking that something else would be off, I assembled the side pods and rear splash shields to see if anything was amiss.  Looks good to me, so I'm going to have to shorten those two tubes.
MFH Porsche 917K "Michael Delaney" 2v29jvownxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29jvo6yxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29jvotLxHpLjS
MFH Porsche 917K "Michael Delaney" 2v29jvoYgxHpLjS
Curtis
Curtis
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeMon 19 Feb 2018, 1:10 am
I use it as glue. It is a form of hoge poge, it dries crystal clear. I use it for windows,PE or anywhere CA or  model glue will be seen. It is super tough stuff. I love it.
You are really banging through this build Paul.
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeMon 19 Feb 2018, 4:19 pm
Sort of a "birdcage" Porsche! So much detail and so much work. Thanx, good luck!
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeTue 20 Feb 2018, 2:42 pm
Great work with those cages, Paul.
MFH Porsche 917K "Michael Delaney" 1705482731 MFH Porsche 917K "Michael Delaney" 1705482731
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeSat 24 Feb 2018, 6:44 pm
Wow, the shot of the parts laid out made my brain implode. Amazing work. MFH Porsche 917K "Michael Delaney" 1705482731
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeWed 22 Aug 2018, 11:31 pm
Exactly, brain implodingasItype. This is an incredibly detailed kit, no doubt!
Dirkpitt289
Dirkpitt289
PostSubject: Re: MFH Porsche 917K "Michael Delaney"   MFH Porsche 917K "Michael Delaney" Icon_minitimeMon 03 Sep 2018, 10:13 pm
SWEET MOTHER OF.... that's AWESOME!
https://www.youtube.com/channel/UCY6YJLP_EUL5tQhLLIdnyxg?view_as
» In memory of the Michael Oliver MBE
» How Did You Become a Phan?
» Island Glass / Alum Bay Glass
