| 1/8 Bobtail T | |
Author | Message |
Sam Moderator
Posts : 1689 Join date : 2013-02-23 Age : 52 Location : Back in Toledo, Oregon
 | Subject: 1/8 Bobtail T Wed 10 Jan 2018, 5:06 am | |
| I have been getting the urge to build again, and of course nothing already started sounded good to me, sooooooo..... I dug up this ancient Lindberg 1/8 T-bucket. What you see is what I have collected. At one show I went to was this partly started kit that was missing a few pieces and the instructions. Couple years go by and I find this old built up that was falling apart and not only does it have the missing parts but came with the instruction sheet. So tonight I sat down and sorted out what I had. Its a basic kit that could be motorized, but will not be. The chrome is not the best with the passing of time, so I will see what can be cleaned up and what cannot be saved. I do not mind if there is little or no chrome on it. The tires, top and interior are actually made out of a rubber or vinyl that is soft and pliable. The tires are two piece with white wall inserts. As you can see in the pic, the white has dirtied with age. It will take some time to strip all the chrome, and clean and prep things as I go so I imagine updates will be sporadic.  If anyone has built this in the past or has dealt with any soft rubber parts like these, what glue have you found that works well ? Any ideas about cleaning/brightening the white rubber parts ? My idea is to start with a tub of soapy water, then a little detergent like 409. I also plan on adding some(read minimal) detail wiring and plumbing, if any of you have found things that look right scale wise, please let me know. Any and all input will be appreciated. Oh, and if anyone has any large scale stuff laying around that you might want to trade off, PM me. Parts/partial/old built/kits,etc. 1/16,1/12,1/8 |
Geezerman Advanced Member
Posts : 3632 Join date : 2013-02-24 Age : 83 Location : Gulf coast of central Florids
 | Subject: Re: 1/8 Bobtail T Wed 10 Jan 2018, 10:43 am | |
| COOL, Sam !! Building a hot rod in that scale would be most interesting. Looking forward to watching this build ! Do it proud ! LOL |
RetiredMike Advanced Member
Posts : 3004 Join date : 2013-04-27 Age : 67 Location : Valparaiso, Indiana
Zbuckster Senior member
Posts : 6951 Join date : 2013-02-17 Age : 70 Location : Aberdeen, Washington
 | Subject: Re: 1/8 Bobtail T Fri 12 Jan 2018, 3:25 pm | |
| Sam I built The "Big Red Rid" for Don Richardson. Same kit just Red instead of Blue. The vinyl tires and the white wall insert were a pain. I never did find an Adhesive that would work with them. I even tries MEK and 3 minute epoxy. I would glue them together and then while trying to sand the "Ridge" off the center of the tires they would come apart again. I finally got it done but it was a chore. Best of luck to ya. |
2whl Admin
Posts : 1374 Join date : 2013-02-22 Location : So Cal
 | Subject: Re: 1/8 Bobtail T Fri 12 Jan 2018, 3:47 pm | |
| What?  Sam playing with models? Come on now.....who is this, really? _________________ Don't think you're on the right road just because it’s a well-beaten path.
2018 A=49 B=0 C=122
 | Subject: Re: 1/8 Bobtail T Fri 12 Jan 2018, 9:53 pm | |
kpnuts Full Member
Posts : 1333 Join date : 2015-01-29
 | Subject: Re: 1/8 Bobtail T Fri 12 Jan 2018, 10:33 pm | |
| I had this model yrs ago but the box got destroyed before I even got to build it (nowadays I could probably fixed it ) interested to see what a master does with it. |
 | Subject: Re: 1/8 Bobtail T Sat 13 Jan 2018, 11:43 am | |
| Sam, PM sent. Forgot to mention, 1/16 scale. |
Plastic Freak Moderator
Posts : 2784 Join date : 2013-06-13 Location : Ancaster/Canada
 | Subject: Re: 1/8 Bobtail T Sat 13 Jan 2018, 3:33 pm | |
| Those kits are huge. With your're skill's Sam you should be able to drive it when you are done. |
Sam Moderator
 | Subject: Re: 1/8 Bobtail T Sat 20 Jan 2018, 11:30 pm | |
| - kpnuts wrote:
- I had this model yrs ago but the box got destroyed before I even got to build it (nowadays I could probably fixed it ) interested to see what a master does with it.
KP, the only thing I am a master at is procrastination when it comes to models. Thanks for all the ribbing and encouragement guys. It's very appreciated. |
disabled modeler Intermediate Member
Posts : 787 Join date : 2016-05-22 Age : 55 Location : Quincy,IL. USA
 | Subject: Re: 1/8 Bobtail T Sun 21 Jan 2018, 1:02 pm | |
| Very cool..! My brother owns a 1 to 1 scale car like that we built for him. I too have been wanting to build some large scale stuff...just to see what all I can do with them. I have the Lindberg Tall T kit but want to put a blower and injection scoop on it that looks the part before I start into it any. There is a few large scale ones Id like to find and afford sometime. |
 | Subject: Re: 1/8 Bobtail T  | |
| 1/8 Bobtail T | |
