 Gilmore Shell
Go to page : Previous  1, 2, 3, 4, 5, 6  Next
PostSubject: Re: Gilmore Shell   Sat 03 Mar 2018, 9:47 pm
Starting to work on the graphics for the facade. Was brought up short by noticing on some different reference photos that there is white trim at the top of the upper columns !
Minor delay while I deal with those !
PostSubject: Re: Gilmore Shell   Sun 04 Mar 2018, 6:20 am
Great progress Clay, looks brilliant.
PostSubject: Re: Gilmore Shell   Sun 04 Mar 2018, 1:10 pm
Facade is coming alongjust fine, Clay.
PostSubject: Re: Gilmore Shell   Sun 04 Mar 2018, 5:30 pm
Wonderful progress! The trim thing sounds like a hassle but I'm sure you'll work it out
PostSubject: Re: Gilmore Shell   Wed 07 Mar 2018, 11:49 pm
I have added the white trim to the tops of the columns. Now to get serious with the fascia portions.
PostSubject: Re: Gilmore Shell   Thu 08 Mar 2018, 5:20 pm
Lovin' It.
PostSubject: Re: Gilmore Shell   Thu 08 Mar 2018, 8:19 pm
I think this whole thing is awesome
PostSubject: Re: Gilmore Shell   Fri 09 Mar 2018, 2:46 pm
popcorn
PostSubject: Re: Gilmore Shell   Sat 10 Mar 2018, 12:18 am
PostSubject: Re: Gilmore Shell   Sun 11 Mar 2018, 11:27 am
Not a very big update, but showing how the facade will be looking.
PostSubject: Re: Gilmore Shell   Sun 11 Mar 2018, 2:06 pm
Excellent!
PostSubject: Re: Gilmore Shell   Wed 14 Mar 2018, 11:28 am
A trip to a 3rd eye Dr, a retina specialist, concludes that I have a blood vessel issue directly behind my right retina, causing macular degeneration. So, I am reduced to working with my left eye that normally is farsighted.
I will be plodding on with the Shell station, but , my workmanship is leaving me with a lot to be desired !
Geezer
PostSubject: Re: Gilmore Shell   Wed 14 Mar 2018, 6:43 pm
This is coming along nicely Clay, sorry to hear about the sight issues. I recently had an exam, Dr, says 'did you know you have a piece of metal in your right eye'. For the past yr I have woken up with pain in that eye, turned out to be a teeny tiny piece of aluminum embedded in the iris.
Good luck with the eyes Clay. Looking forward to seeing this dio in some photos.
PostSubject: Re: Gilmore Shell   Fri 16 Mar 2018, 12:20 am
I need to be more observant !! What I thought was white trim all across the tops of the facades, wasn't white at all. Must have just glanced at a photo that had  reflections on the top edges. Also a new look let me know that there was a thicker edge lining the top. So, I'm in the process of correcting my previous assumption by attaching a 3/16" lip to the pieces. The entire top edges are chocolate brown, like the base of the columns !
PostSubject: Re: Gilmore Shell   Fri 16 Mar 2018, 4:33 pm
PostSubject: Re: Gilmore Shell   Tue 20 Mar 2018, 9:55 pm
Nothing new and exciting. I do have the facade pieces in paint. just have to clean up and put on a final coat. Starting on some auxiliary companion pieces.  Some of the reference photos show a pair of benches on each side of the front door. Depending on the outcome, I may just make one.
PostSubject: Re: Gilmore Shell   Tue 20 Mar 2018, 11:24 pm
PostSubject: Re: Gilmore Shell   Wed 21 Mar 2018, 4:25 pm
bob29579
PostSubject: Re: Gilmore Shell   Wed 21 Mar 2018, 11:44 pm
Looking really good.
PostSubject: Re: Gilmore Shell   Thu 22 Mar 2018, 2:00 pm
Coming along beautifully.
PostSubject: Re: Gilmore Shell   Sat 24 Mar 2018, 5:04 pm
Excellent progress! And though it may not seem 'new and exciting' every little bit of work adds up to what is going to be a superb diorama.
PostSubject: Re: Gilmore Shell   Mon 26 Mar 2018, 11:29 pm
Some small progress to report. I made 3 cast iron (matt board and wire) seat brackets. They left me with a desire not to do it again, so, there will be only one bench ! ( second foto), there will be no closeup shots....It's that bad !
PostSubject: Re: Gilmore Shell   Mon 26 Mar 2018, 11:55 pm
PostSubject: Re: Gilmore Shell   Tue 27 Mar 2018, 3:40 pm
Cool little item, Clay.
PostSubject: Re: Gilmore Shell   Tue 27 Mar 2018, 5:06 pm
From here that bench looks great. I know you think it could be better, but man it looks great.
Gilmore Shell
Page 5 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» Revisting the Crown Lynn 539 Shell Wall vase
» Triton Shell Stitch
» Shell Stitch Potholder
» Selling Hummer H2 SUT body shell. 1/10
» Small shell dish or ashtray
