 Really starting to hate all Alcled
Promodmerc
PostSubject: Really starting to hate all Alcled   Sat 21 Oct 2017, 5:39 am
Tonight I sprayed a transmission & intake with Alclad white aluminum. It laid down fine. It was the clean up that chapped my rear.
I have used it before snd had no issue with using lacquer thinner to clean my airbrush.
Tonight the Alclad reacted to the lacquer and just gummed up. I read the bottle and it aid it contains MEK so now I guess i'm going to have to pick up a can of MEK
I have some valve covers that I plan on using Alclad polished aluminum on. It contains MEK as well.
PostSubject: Re: Really starting to hate all Alcled   Sat 21 Oct 2017, 9:34 am
Dan buddy...sorry to hear that....just send your parts to George for plating. Me..I always have just used spray cans. Hope you can get the air brush cleaned out and ok.
PostSubject: Re: Really starting to hate all Alcled   Sat 21 Oct 2017, 10:55 am
?? Have only used al clad a couple of times had no problems cleaning the air brush. Really don't remember, but there's a good chance I cleaned with reducer. It's quite a bit notter than Lacquer thinner. Never had any luck with MEK as an adhesive, nor melting sprue for filler.
Promodmerc
PostSubject: Re: Really starting to hate all Alcled   Sat 21 Oct 2017, 10:03 pm
I have a quart of House Of Kolor reducer. I'll do test and see how it reacts.
Promodmerc
PostSubject: Re: Really starting to hate all Alcled   Wed 25 Oct 2017, 3:08 am
I did a test, and the reducer did the trick.
Now I don't have to shell out $10 for a quart of MEK.
PostSubject: Re: Really starting to hate all Alcled   Wed 25 Oct 2017, 3:46 am
You may have a problem finding MEK. I haven't seen it here on the shelf here in utah for a couple of years. I use it almost exclusively as an adhesive and have the beer part of a gallon in my stash. For a while there was an MEK substitute on the shelf, but it didn't work worth a damn. Good luck.
PostSubject: Re: Really starting to hate all Alcled   Wed 25 Oct 2017, 11:21 am
I have always used Mr. Hobby, Mr. Tool Cleaner. It works a charm for any type of paint used in the air brush.
Skid's Place :: General :: Off Topic-
