 Community Build #23 - Propeller Aircraft
Community Build #23 - Propeller Aircraft - Page 2 Empty
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeSat 18 Nov 2017, 10:54 pm
Well, something had to go wrong.  Put the side fuselage decal into the water and when it straightened out, it cracked in the center.  Tried to put it on but more cracks appeared as I applied Solvaset to get it to lie down around raised detail.  When I removed it from the fuselage, it left nasty white blotches.
Community Build #23 - Propeller Aircraft - Page 2 Gotha_54
Smaller decals went on fine.
Community Build #23 - Propeller Aircraft - Page 2 Gotha_55
So I decided to paint it on. Decals don't appear old stock. Got the kit directly from the Ukraine.
Community Build #23 - Propeller Aircraft - Page 2 Gotha_56
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeMon 20 Nov 2017, 4:55 pm
Sorry to see that on the decals Mike.  But it looks like you've gotten it under control.  Nice save.
The first steps in my build involve putting the fuselage sides together and assembling the cockpit.   The kit is designed to slide the cockpit into the fuselage after it is together.   So I painted the interior surfaces of the fuselage and the cockpit pieces in IJN interior green.  Then I spent some time detail painting the pieces.  The fuselage has been glued together.
Community Build #23 - Propeller Aircraft - Page 2 2v29pmj78xHpLjS
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjPoxHpLjS
The cockpit pieces are done.
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjU3xHpLjS
Mounting the seat to the bulkhead was a royal pain.  The four stand-offs are separate pieces and getting it all straight wasn't easy.
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjurxHpLjS
 The instrument panel has a clear insert which comes in from the back.  Then the instrument decal is applyed from the back.  The instrument faces are printed on the back side so they show through.
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjE8xHpLjS
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeMon 20 Nov 2017, 5:08 pm
Super detailing Paul.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeMon 20 Nov 2017, 8:10 pm
im slowly making progress but its a bit of a filler queen, definatly showing its age
Community Build #23 - Propeller Aircraft - Page 2 335eb8y
Community Build #23 - Propeller Aircraft - Page 2 2w315l2
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeWed 22 Nov 2017, 12:47 am
Mike: excellent work on the interior, and a nice workaround on the decal issues.
2whl: Great detailing of the cockpit. The pilots seat and harness look fantastic.
Paul: What do you use for filling in the seams? That is one of the areas in which I need much improvement.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeWed 22 Nov 2017, 6:04 pm
Blame Russian meddling for the decal issues! All else by everyone is quality work as always!
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeWed 22 Nov 2017, 6:18 pm
Thanks Mitch and Cole
I got the cockpit pieces assembled
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjazxHpLjS
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjQ3xHpLjS
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeWed 22 Nov 2017, 7:57 pm
Paul:  Cockpit looks friggin' awesome!  Community Build #23 - Propeller Aircraft - Page 2 1705482731 Community Build #23 - Propeller Aircraft - Page 2 1705482731
Cole:  When I'm filling seams, I lay down tape alongside the seam to not blot out adjacent rivet detail or such.  Then it's presicion sanding.
Got the engines attached to the fuselage assembly.  On the GIV, the nacelle was an integral part of the lower wing structure.  In the process of attaching the PE radiator louvers - left side done.
Community Build #23 - Propeller Aircraft - Page 2 Gotha_57
Community Build #23 - Propeller Aircraft - Page 2 Gotha_58
Community Build #23 - Propeller Aircraft - Page 2 Gotha_59
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeWed 22 Nov 2017, 8:43 pm
i use these fillers
Community Build #23 - Propeller Aircraft - Page 2 2wnr3ad
squadron stuff is ok but the other stuff i bought on Al's recommendation and its really smooth, its what ive been using on this kit
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeFri 24 Nov 2017, 7:48 pm
Thanks Mike
I got the rest of the pieces attached to the cockpit.   Next will be inserting it into the fuselage.
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjcMxHpLjS
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjB3xHpLjS
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjtUxHpLjS
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjY9xHpLjS
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeSat 25 Nov 2017, 5:15 pm
Paul:  Beautiful looking cockpit.  Lots of detail.
Got the top wing attached at a few points.  The struts crack in half very easily if I used sprue nippers, so I switched to nail clippers with success.  Windows and frames are in.  Also adapted the radiator louvers from the GV which is a different shape radiator.
Community Build #23 - Propeller Aircraft - Page 2 Gotha_62
Community Build #23 - Propeller Aircraft - Page 2 Gotha_60
This is the turnbuckle PE attached to the top wing.  I hope it turns out well - the hole in the center for the strut to attach is very small and drilling it out wasn't very successful.
Community Build #23 - Propeller Aircraft - Page 2 Gotha_61
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeSat 25 Nov 2017, 6:35 pm
youre a brave man to tackle this but its looking great
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeSat 25 Nov 2017, 7:55 pm
Oh man! These planes are looking great! Keep up the good work!
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeSat 25 Nov 2017, 9:15 pm
Mike that is coming along great.  It looks like it's quite large.
Got the cockpit into the fuselage.  It slid in easily.
Community Build #23 - Propeller Aircraft - Page 2 2v29pmji3xHpLjS
Then I started adding more pieces to the assembly
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjm9xHpLjS
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjVFxHpLjS
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeMon 27 Nov 2017, 8:46 am
Mike and Paul: Thanks for the advice and information. The Gotha is coming along nicely.
Suspicions continue to mount as I assemble the flying boat. I really wonder if the entire model is to scale. I will get into this more when I am farther along. For now I'm assembling the wings and control surfaces. The Hasegawa design includes movable control surfaces. But the wing assemblies leave much to be desired when fitting them together.
Community Build #23 - Propeller Aircraft - Page 2 Dscn0410
Community Build #23 - Propeller Aircraft - Page 2 Dscn0411
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeMon 27 Nov 2017, 8:53 pm
1/72nd and 1/48th bombers do get quite large! Finding display space can be harder than the build itself!
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeMon 27 Nov 2017, 9:48 pm
im having some serious problems with masking up mine but im going to keep plugging away at it
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeTue 28 Nov 2017, 12:06 pm
Community Build #23 - Propeller Aircraft - Page 2 2776978727
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeTue 28 Nov 2017, 5:04 pm
The control surfaces are hinged using p/e and wires.
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjhdxHpLjS
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjL5xHpLjS
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjgNxHpLjS
I've gotten the engine pieces painted and ready to be assembled.
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjGjxHpLjS
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeWed 29 Nov 2017, 7:39 pm
im having a bit of a mare with this
once i sprayed the green it showed up some dodgy seams but its too late now, want to crack on and get it done
Community Build #23 - Propeller Aircraft - Page 2 30lgbrd
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeThu 30 Nov 2017, 2:42 am
2whl:  Nice details there.
Paul:  Sure looks good to me.
Me, I ran into a little unexpected additional work.  Since the PE turnbuckles cannot be drilled out further, and the struts are already very delicate (cracked 4 of them), the thickness of the PE comes into play throwing off the alignment of the lower wing.  I first glued the struts in place on the upper wing and then test fit the lower, nipping material off the struts until everything fit.
Lots of extra work for those turnbuckles.
Community Build #23 - Propeller Aircraft - Page 2 Gotha_63
Community Build #23 - Propeller Aircraft - Page 2 Gotha_64
The old saying goes, "If you had to do it all over again..."
Well unfortunately, I also have a Gotha GII with PART PE in my stash.
We'll see.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeFri 01 Dec 2017, 8:56 am
Paul: The photo shows nothing of which you speak.
Mike: I feel your pain. But you're doing a great job.
I decided to do things a bit differently for assembly and painting of the fuselage. Since there are so many windows and view ports I have painted the fuselage except for the seam area and underbelly. All the internal windows, and cockpit are now in. So I will button up the fuselage, fill the seams then paint the remainder of the fuselage. Hasegawa did quite a job of molding in rivets on all the external surfaces.
Community Build #23 - Propeller Aircraft - Page 2 Dscn0413
Community Build #23 - Propeller Aircraft - Page 2 Dscn0412
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeFri 01 Dec 2017, 9:22 pm
Good work, gentlemen! Keep 'em flying!
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeSat 02 Dec 2017, 8:22 pm
Paul....it looks good to me also
Mike.....I like the look of those turnbuckles.
Cole....is that cockpit window fit any better?  That's quite a gap.
Got my engine assembled
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjFFxHpLjS
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjddxHpLjS
Community Build #23 - Propeller Aircraft - Page 2 2v29pmjyyxHpLjS
PostSubject: Re: Community Build #23 - Propeller Aircraft   Community Build #23 - Propeller Aircraft - Page 2 Icon_minitimeSun 03 Dec 2017, 3:15 pm
beowulf wrote:
i use these fillers
I find the Squadron dries too fast. The Tamiya stuff is what I prefer.
» Kinetic Models 1/48th Scale E-2C Hawkeye
» My custom bumper build
» Build Log: Converting a 31" Super Cub to .049 Power (revisited)
» NorthBurrells 2" never-ending build... and Loco's
