 Community Build #23 - Propeller Aircraft
Go to page : 1, 2, 3, 4  Next
PostSubject: Community Build #23 - Propeller Aircraft   Fri 20 Oct 2017, 4:47 pm
Community Build #23 - Propeller driven aircraft
1 This build starts November 1st 2017......it does not have an end date, however you must start your build between 1st Nov and 31st Dec.....thread will be locked until the start date...there is a discussion thread here.... http://skidsplace.forumotion.com/t3746-community-build-23-aircraft#64701
2 The subject for the Build is propeller driven aircraft so no jets or helicopters allowed........any scale, military or civilian allowed
3 All build progress to be recorded in this thread, please include a pic of the box art if possible and a shot of the sprues in your first post....you may complete previously started projects which have stalled provided you show pics of where you are when you join the Build
4 A suitable thread will be started for pics of completed projects
5 Any questions just ask.....and above all, Have Fun!!
Colour Sergeant Bourne: It's a miracle.
Lieutenant John Chard: If it's a miracle, Colour Sergeant, it's a short chamber Boxer Henry point 45 caliber miracle.
Colour Sergeant Bourne: And a bayonet, sir, with some guts behind it.
2017 A:19 B:7 C:12.....2018 A:32 B:11 C:1
PostSubject: Re: Community Build #23 - Propeller Aircraft   Mon 30 Oct 2017, 4:44 pm
thread is now unlocked ready for the 1st of November
PostSubject: Re: Community Build #23 - Propeller Aircraft   Tue 31 Oct 2017, 6:18 am
Kawanishi Type 97 flying boat in 1:72
PostSubject: Re: Community Build #23 - Propeller Aircraft   Tue 31 Oct 2017, 2:27 pm
Gotha G-IV 1/72 by Roden with Part PE detail kit.
And the PART photoetch (for a G-V , but it should work with a G-IV).
Sure glad it's open-ended!
PostSubject: Re: Community Build #23 - Propeller Aircraft   Wed 01 Nov 2017, 2:43 pm
I've been studying both sets of instructions the past two days to see how to approach this project.  A lot gets replaced bythe PE.  Even the Roden instructions call for cutting out a portion of the fuselage and replacing with styrene card to accurately depict the G-IV.  Apparently, the sprues were engineered to be good for the entire line of GII, GIII, GIV and GV with minor mods.  There are over 225 pieces of which about 30 are for versions other than the GIV.
Below is the PART PE. Not enough room to cut with PE nippers, but it cuts and bends easily. I highly recommend it.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Thu 02 Nov 2017, 2:40 pm
Mike: I've always been interested in Roden so I'm very glad to see you taking this on, modifications and all.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Thu 02 Nov 2017, 3:06 pm
well you two seem to be going for large and complicated kits...........im going to the other extreme lol
1/72 Hurricane by HobbyBoss
i bought this on a whim ages ago just cos it was cheap, im not really a plane builder any more, always seem to struggle with aircraft
its very nicely moulded.....the wings are one bit and the fuselage is one bit, with the cockpit moulded in,.........in one way its nice cos theres no joins to worry about but it dosnt make for many parts in the box lol
PostSubject: Re: Community Build #23 - Propeller Aircraft   Fri 03 Nov 2017, 1:02 am
Glad you can join in, Paul.
Started in removing injection points and molded framework from the fuselage.  This allows the PE framework to set in properly.
Before:
After:
The insert:
Then it's getting to work on some PE.
This...
becomes this.
More PE ...
And it's just the beginning.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Fri 03 Nov 2017, 1:35 pm
Paul: That's a very interesting kit. Looking forward to see what you do with it.
Mike: Very cool. You know how I enjoy working with photo etch. I will definitely be on the lookout for Roden here in Japan.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Fri 03 Nov 2017, 6:26 pm
only needed a smear of filler on the wing roots so all good so far
PostSubject: Re: Community Build #23 - Propeller Aircraft   Sat 04 Nov 2017, 12:41 am
Nice, Paul.  I like the idea of 'just a smear of filler'.  LOL
Cole:  The PE I'm using comes from PART, a Polish company.  I haven't seen any Roden kits that come with PE.
I scraped and sanded off about 26 of the 30 louvers off each side of the nacelles that house the engines.  Roden supplied enough louvers to build any of the GIV's built by 4 different supppliers.
Nice little engines are supplied, but with the closed up nacelles, they're barely visible.  Besides that, they don't fit well inside as other online builders have found.  So, I'm only using the exhaust manifold since it's the only exposed part.  I'll scratch up something for the propeller to mount on later.
With the radiator on the front and the propeller on the rear, it won't be noticeable.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Mon 06 Nov 2017, 2:35 am
These are the finished nacelles.
There are different lower wingspans, so Roden says to cut the center section.
This is with the wing PE installed.
Roden also says to cut out this rounded out fuselage section and replace it with flat styrene sheet.
The new piece with a window is cut from a template they provide.
But it seems a bit too large.
So I taped everything in place for proper registration/fit.
The final product glued and filled.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Wed 08 Nov 2017, 9:01 am
Great work Mike, especially in this scale.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Wed 08 Nov 2017, 7:40 pm
Got some paint started on the fuselage.  With all the PE being added to the interior, I figured I'd get color on most of it, install the PE that can't be fitted later, close up the fuselage and fill the seams and finally touch up the color.
The first attempt at pale blue appeared too blue compared to the boxart.  So I mixed it 50/50 with white and came up with an acceptable pale color.  There'll also be some Tamiya white weathering cake rubbed on afterwards.
Before:
After:
With framework and tunnel added:
Thanks for looking,
PostSubject: Re: Community Build #23 - Propeller Aircraft   Wed 08 Nov 2017, 8:32 pm
well my hurricane is on the back burner,......you get two canopies, 1 one piece and a 2 piece......and neither fits!!!!.....tried trimming and shaping and its not going to work
so back to the stash to see what else i have instead
PostSubject: Re: Community Build #23 - Propeller Aircraft   Fri 10 Nov 2017, 11:55 am
Mike; Great progress. The interior is looking very good.
Paul; Sorry to hear about the canopies. Nevertheless, looking forward to your next project.
I finally got started on my flying boat. There will be some significant seams to fill along the fuselage. The cockpit is very basic (that's being kind). I will include the pilot figures just to fill up some of the space.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Fri 10 Nov 2017, 1:12 pm
not to worry, it was incredibly cheap to start with, but still a disapppointment
ive going up in the loft in the next few hours to view the stash, so watch this space
PostSubject: Re: Community Build #23 - Propeller Aircraft   Fri 10 Nov 2017, 10:42 pm
since the Hurricane i was building came to a very sudden halt and i still fancy doing an aircraft i have pulled this from the stash
https://en.wikipedia.org/wiki/Petlyakov_Pe-2
this was originally new tool back in 1968 and this is an offering post 2010....always like a challenge with an old kit....this is one i remember when i was a kid but never did
TimJ
TimJ
PostSubject: Re: Community Build #23 - Propeller Aircraft   Tue 14 Nov 2017, 6:00 pm
Here's my entry for this Community Build.
DSCF9103 (2) by timothy jones on Flickr
DSCF9104 by timothy jones on Flickr
DSCF9105 by timothy jones on Flickr
DSCF9106 by timothy jones on Flickr
DSCF9107 (2) by timothy jones on Flickr
PostSubject: Re: Community Build #23 - Propeller Aircraft   Wed 15 Nov 2017, 8:36 am
Tim: Glad to see you joining in.
I'm currently working on two other projects, but have made a wee bit of progress on the flying boat. The yokes will get a coat of flat black. And perhaps, a navigation chart on the table behind the pilots.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Wed 15 Nov 2017, 6:34 pm
Cole....you weren't kidding about a basic cockpit.....lol
Mike, that's quite project with that P/E.
I finally got the itch to get back to the bench.  And maybe it's the IPMS contests I've been to lately that has got me into a plane mood, but I decided to jump into this CB.  I'll do a Tamiya 1/32 Zero.
Some sprue shots......
2018 A=49  B=0  C=122
PostSubject: Re: Community Build #23 - Propeller Aircraft   Thu 16 Nov 2017, 12:35 am
2whl: Excellent! I have this kit as well, so I will enjoy watching and learning from your build.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Thu 16 Nov 2017, 5:16 am
Tim and 2whl:  Welcome aboard!
Cole: nice work painting 1/72 figures.
Got a little more done on the interior and fuselage.
Tiny molding of the fins on the small bombs is somewhat incomplete, but they'll hardly be seen.  Floor sections and bulkheads are in.
And the fuselage is now together, seams filled and paint touched up.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Thu 16 Nov 2017, 5:09 pm
WOW, there's some progress! Luv the time and work put in. I did the Ju-88 years ago, don't remember which company.
PostSubject: Re: Community Build #23 - Propeller Aircraft   Sat 18 Nov 2017, 10:57 am
Wow ! These look pretty intricate !
As cool as these old warbirds are, I never got into modeling them.
Gonna be some killer models coming from this community build !
» Community Build #11 "Airplane" Propellers R Us
» Community Build #15 WWII Ships
