 Pocher 1/4 ducati panigale
PostSubject: Re: Pocher 1/4 ducati panigale    Fri 17 Nov 2017, 9:19 pm
That is stunning, I knew Pocher kits were good but this is amazing.
PostSubject: Re: Pocher 1/4 ducati panigale    Sat 18 Nov 2017, 2:08 pm
Beautiful detailing, sir.
PostSubject: Re: Pocher 1/4 ducati panigale    Sat 18 Nov 2017, 4:03 pm
Love the extra wiring.
PostSubject: Re: Pocher 1/4 ducati panigale    Sat 18 Nov 2017, 6:36 pm
Thanks guys l started on the fuel system added the butterfly valves made from aluminium foil onto which I put brass leaf.
Then I cut it to fit
Then cut a piece of sprue then halved it.
Covered it with the brass leaf then drilled two holes and added a couple of screws
PostSubject: Re: Pocher 1/4 ducati panigale    Sun 19 Nov 2017, 8:27 pm
Hi all bit more added here (this is just the supplied detail loads of wiring and connectors still to add) ( I really don't know why they don't supply varying thicknesses of wire surly it wouldn't add more than a tenner to the cost of the kit)
As I said loads more detail to add but couldn't resist trying it on the engine.
Also got the tyres on the wheels (Man they are heavy, but great quality)
PostSubject: Re: Pocher 1/4 ducati panigale    Sun 19 Nov 2017, 9:53 pm
The tanks and body panels look awesome! The wiring detail is great and the butterfly valves are beautiful. The tires and wheels look pretty much 1:1 real. Wow, what a kit.
PostSubject: Re: Pocher 1/4 ducati panigale    Mon 20 Nov 2017, 6:57 pm
Hi all well here's the wiring added to the intake system and said system added to the engine (this thing is getting heavey)
PostSubject: Re: Pocher 1/4 ducati panigale    Tue 21 Nov 2017, 8:18 pm
Hi all here is the next bit the exhaust, let me tell you what a horrendous fit, had to use copious amounts of filler first really disappointing bit of the kit, Paul Koo suggests leaving the screws loose then adjusting the gaps by gradually tightening them whilst adjusting the gaps, well the best I managed to reduce it to was 2 mill for a kit of this price I think that is really bad.
Anyway here it is with all the gaps filled.
Not happy with the silver shields they look very plasticky (I know they actually are) will have to try and change that, I'm thinking of trying foil over them)
PostSubject: Re: Pocher 1/4 ducati panigale    Tue 21 Nov 2017, 9:48 pm
Excellent. Nice and detailed, as it should be.
PostSubject: Re: Pocher 1/4 ducati panigale    Wed 22 Nov 2017, 8:23 pm
Hi all I've detailed up the airbox.
My first attempt at the paper filter
My fourth
PostSubject: Re: Pocher 1/4 ducati panigale    Thu 23 Nov 2017, 8:07 pm
Hi all well I couldn't resist putting together what I have so far.
This thing is huge. This is a 1/6 bike with a similar size engine.
And it's heavy.
PostSubject: Re: Pocher 1/4 ducati panigale    Sun 26 Nov 2017, 5:45 pm
The details are stunning and the size is intimidating. Beautiful!
PostSubject: Re: Pocher 1/4 ducati panigale    Mon 27 Nov 2017, 8:47 pm
Hi all I've started on the wheels I've made up the disks
I've started weathering it
I've ordered some proper button head sockets for the disks instead of the screws that come with the kit (Another thing missing from the upgrade kit)
PostSubject: Re: Pocher 1/4 ducati panigale    Tue 28 Nov 2017, 1:50 pm
The weathering is spot on for me. Im surprised at Pocher not providing authentic detailing.
Keep up the great work.
PostSubject: Re: Pocher 1/4 ducati panigale    Tue 28 Nov 2017, 8:10 pm
Done some to the frame and the swing arm
Couldn't resist trying it with the engine
And the swing arm
PostSubject: Re: Pocher 1/4 ducati panigale    Thu 30 Nov 2017, 7:44 pm
Here is the next bit. Got some blue paintwork on it now.
PostSubject: Re: Pocher 1/4 ducati panigale    Fri 01 Dec 2017, 8:25 pm
Hi all these are the screws that come with the kit.
At a huge cost of 3.49 for 20 including postage I think these look better
(Ron aka silver911 told me where to get them
PostSubject: Re: Pocher 1/4 ducati panigale    Sat 02 Dec 2017, 3:17 pm
Hi all here is the next update pocher would have you attach the rear sprocket like this
Thing is the rear sprocket is attached via nuts screwed onto studs so grubs screws were used to fix it.
Then a try of all we have so far.
PostSubject: Re: Pocher 1/4 ducati panigale    Sun 03 Dec 2017, 6:47 pm
Amazing! This is one big, beautifully detailed kit. And the proper head sockets really pop up the wheel!
PostSubject: Re: Pocher 1/4 ducati panigale    Sun 03 Dec 2017, 8:40 pm
Hi all well flitting about decided to start on the front fairing it may not look it but it's a fairly complex bit
PostSubject: Re: Pocher 1/4 ducati panigale    Tue 05 Dec 2017, 8:43 pm
Moving along now, still a long way to go though, but at least it's looking like a bike now.
Not happy with the oxygen sensor wires I think they're too thick, they're networking wires I don't have anything thinner, any suggestions.
PostSubject: Re: Pocher 1/4 ducati panigale    Wed 13 Dec 2017, 9:22 pm
Hi all well I've got to say I'm very disappointed with the hardware upgrade kit. I'm not an engineer and I don't have a box of assorted small diameter bolt hexnuts or assorted rods but Paul seems to think anyone buying his kit has them I now have to try and find some threaded rod for the foot pegs, anyway whingeing aside the heal guard is missing the attachment hardware Paul suggests to make sure you can get the centred you cut the heads off the bolts and glue them in place allowing you a chance to centre them
On closer inspection looking at the rear of the part there are two lugs where the bolts go through on the real thing which if drilled from the rear gives you the ability to centre them also giving you the realism of having the bolts sticking out the back once added
The top bolt on this bracket as supplied is a Philips screw.
Paul's solution is to cut the head off a socket screw and glue it over the screw
PostSubject: Re: Pocher 1/4 ducati panigale    Sat 16 Dec 2017, 6:08 pm
Hi all finished the rear suspension and made the rear stand as this thing is getting heavy and is not very stable standing on only it's rear wheel and the exhaust
tiking
PostSubject: Re: Pocher 1/4 ducati panigale    Sun 17 Dec 2017, 8:07 am
Darn fine work.
PostSubject: Re: Pocher 1/4 ducati panigale    Sun 17 Dec 2017, 10:20 am
Thanks Charles means a lot coming from you.
» Pocher 1:8 super detailed model kits
» Tamiya Ducati 916
» Ducati MHR
» Tamiya Ducati 916
» Ducati 900SS, Tamiya 1/12
