 Pocher 1/4 ducati panigale
Go to page : 1, 2, 3, 4  Next
PostSubject: Pocher 1/4 ducati panigale    Tue 19 Sep 2017, 8:12 pm
Hi all well it's arrived man it's huge here is a pic of the box
And just for size comparison here it is along side a calor gas fire
The instruction manual
It's really well packaged
And here is the Paul Koo upgrade kit
I'm not allowed to start it till my birthday on the 26th of next month though (although I wasn't allowed to open it then);)
PostSubject: Re: Pocher 1/4 ducati panigale    Wed 20 Sep 2017, 6:47 pm
Hi all well I've not actually started building it yet but I couldn't resist comparing it to the biggest scale I've built so far (1/6 bikes) these bikes are huge but putting the ducati crank case and gearbox along side it this is going to be enormous (baring in mind there are no cylinder heads or fuel intake on it) by the time I add those the engine will probably be twice this size.
I will probably being upsetting the purists among you as it won't be the box colours it will be a custom job.
PostSubject: Re: Pocher 1/4 ducati panigale    Sun 24 Sep 2017, 7:38 pm
Holy schmoley! 1/6 is a big scale but I can't imagine 1/4 ... what a monster that's going to be. popcorn
PostSubject: Re: Pocher 1/4 ducati panigale    Wed 25 Oct 2017, 7:38 pm
Hi all well I won't be here on my birthday so I got permission to start it today.
I decided to start on the exhaust as it has been noted as the worst fitting part of the whole kit, this thing is huge the bit of the exhaust I've started is the length of a 1/24 car and that's basically just the down pipe. So here is the start of this massive kit, I must say I'm buzzing with excitement.
I've plugged some of the screw holes
Then decided to add the first missing detail, the welding seam on the curved outside and inside section of the exhaust (i will add the weld seam round the other side when its finally attached to the rest of it)
I've not glued the two sections together yet to make drilling of the holes for the oxygen sensors easier.
There's loads of detail you could add just to this part and I'm going to try and add it all, I did say TRY.
PostSubject: Re: Pocher 1/4 ducati panigale    Sun 29 Oct 2017, 9:20 pm
Great start to a seriously involved build - detailing at 1/4 scale is just ... well ... daunting. Looking forward to seeing this develop.
PostSubject: Re: Pocher 1/4 ducati panigale    Mon 30 Oct 2017, 9:20 pm
Hi all well after an update on my samsung tab s2 it has made it totally useless for posting on forums so I'm now stuck with this incredibly slow and clumsy laptop so here is the next installment. i was following silver911 build of this and decided to emulate his enhancement of the exhaust joins and copied his use of aluminium foil on them.
also I've added the thickening where the oxygen sensors go
[IMG]
(its made from the phillips screw covers from a bedroom unit)
made a start on the engine too. Added some weathering as well. Put a rule in the last pic to give an idea of the size of this beast.
PostSubject: Re: Pocher 1/4 ducati panigale    Mon 30 Oct 2017, 9:44 pm
PostSubject: Re: Pocher 1/4 ducati panigale    Tue 31 Oct 2017, 8:22 pm
Made a start on the exhaust valve and made up the spring hangers soon be ready for priming.
Here's the pic that should have been there
PostSubject: Re: Pocher 1/4 ducati panigale    Thu 02 Nov 2017, 8:03 pm
Hi all I've started weathering the exhaust I'm using Uschi metal powders and a combination of copper and blue grey dry brushed on, still more to do but it looks promising
Added some more engine details like the generator wires
PostSubject: Re: Pocher 1/4 ducati panigale    Fri 03 Nov 2017, 8:11 pm
Hi all well here is the first disappointment with the upgrade kit he supplies the steel beads to make the banjo connectors for various connections but then tells you to use poacher 2 millimetre bolts for the head of the banjo connector (there are none supplied in the kit only cross head screws) I realise Paul has built loads of poacher kits, this is my first so I don't have any poacher 2 mill bolts, what I do have though is these.
So onwards and upwards
I've made the springs for the exhaust too.
PostSubject: Re: Pocher 1/4 ducati panigale    Sat 04 Nov 2017, 4:52 pm
The detail is mind boggling. Great work on the exhaust and engine so far, there are already shots which look like the real thing. Awesome!
PostSubject: Re: Pocher 1/4 ducati panigale    Tue 07 Nov 2017, 8:29 pm
Hi all here is the next instalment.
I got fed up with taking longer to find a part on the many sprues in this kit by looking for the small tab on each sprue with the letter I needed (I'm surprised I didn't think of this the 2 times I built the Traction Avant kit) I've written a large letter on each bag for which sprue is in it.
I've made the starter motor terminal from a piece of whittled down sprue
Added the oil cooler with the added layers and the banjo connector using Paul Coos detail adding info
And the finished starter motor.
Bit more weathering on the engine.
All in all I'm quite pleased with the progress (even if it's glacially slooooow)
PostSubject: Re: Pocher 1/4 ducati panigale    Thu 09 Nov 2017, 8:19 pm
Hi all i wanted to try and show you all just how big this is so, this is a 1/24 lorry engine.
Now put it on the engine and you get an idea of just how huge this is.
I just couldn't wait here is base colour (No clear lacquer yet)
PostSubject: Re: Pocher 1/4 ducati panigale    Fri 10 Nov 2017, 2:06 pm
I'm astounded by the exhaust pipe weathering. Could you share a little bit about how you went about getting the realistic metal effects on it?
PostSubject: Re: Pocher 1/4 ducati panigale    Sat 11 Nov 2017, 4:24 pm
Hi mate I primed it with grey primer then brushed mahogany stains on all the joins and before they dried I dabbed most of it off then blended the edges then I randomly dry brushed copper colour over the exhaust finally I used Uschi metal powders and burnished it till I got the luster I wanted (I may do a bit more to it before I add it to the bike) I'm just living with it at the moment, im not sure if it's interesting enough yet.
PostSubject: Re: Pocher 1/4 ducati panigale    Sat 11 Nov 2017, 5:21 pm
Its going to be a monster!!
Looks like an amazing kit.
PostSubject: Re: Pocher 1/4 ducati panigale    Sun 12 Nov 2017, 7:56 pm
Well we've been away for the weekend at our friends caravan and I came back to a bit of a disaster
All the plastic parts are fine I couldn't work out what had gone wrong but now I have
No primer, I assume the plastic parts were primed hence they are ok.
I've removed the paint
(Another chance to see how big this is its nearly as long as my thigh)
Now I just have to 're prime it, I'm just wondering if I have enough of the blue left this thing is so big it took nearly a whole can to paint it(admittedly I did both sides of all the parts as I was not sure if the back of any parts could be seen) hopefully no more problems will occur.
PostSubject: Re: Pocher 1/4 ducati panigale    Mon 13 Nov 2017, 11:00 am
Thanks for that.
PostSubject: Re: Pocher 1/4 ducati panigale    Mon 13 Nov 2017, 7:56 pm
Hi all repaired the tank. I have to say I really, really, really love this colour
Made the water pump too.
Did I mention how much I really, really, really love this colour.
PostSubject: Re: Pocher 1/4 ducati panigale    Tue 14 Nov 2017, 6:05 pm
The starter motor and water pump are beautiful and that colour is fantastic, I can see why you've fallen in love with it.
PostSubject: Re: Pocher 1/4 ducati panigale    Tue 14 Nov 2017, 8:24 pm
Hi all well I've finished the tank and sprayed the clear coat on the rest of the paintwork.
Such a gorgeous colour (even if I do say so myself)
PostSubject: Re: Pocher 1/4 ducati panigale    Tue 14 Nov 2017, 8:45 pm
STUNNING!!!
PostSubject: Re: Pocher 1/4 ducati panigale    Tue 14 Nov 2017, 9:40 pm
You are doing great with this. You are very good at weathering.
I would fire the "welder" who bird pooped the exhaust pipe together though. On a bike that expensive I would think the welds would look more professional and less like Harry your drunk uncle did them...
PostSubject: Re: Pocher 1/4 ducati panigale    Thu 16 Nov 2017, 8:16 pm
Hi all started adding detail to the starter relay.
PostSubject: Re: Pocher 1/4 ducati panigale    Fri 17 Nov 2017, 8:04 pm
Hi all well I've detailed up the battery and added the upgrade kit decal (the smaller decal is the one that came with the kit.
I must say I am surprised with a kit of this size and price of the huge amount of missing detail, mostly seems to be wiring which surely wouldn't be that expensive to add to the kit.
» Pocher 1:8 super detailed model kits
» Tamiya Ducati 916
» Ducati MHR
» Tamiya Ducati 916
» Ducati 900SS, Tamiya 1/12
