 Revell Metal axle replacement.
PostSubject: Revell Metal axle replacement.   Wed 17 May 2017, 12:01 pm
I'm always loosing the metal 'stub axles" that some new Revell kits feature. The RHD Camaro build is no exception.
Solution? This, the humble pop rivet.
Remove and discard the alloy rivet bit. It's the stem we want.
File the domed end flat. On this one I also had to run a file over the stem area too.
Cut to length and file the other end square. Done! You'll probably have slightly enlarge the holes where the stub axles fit into.
PostSubject: Re: Revell Metal axle replacement.   Wed 17 May 2017, 12:52 pm
 Thanks Chris, great tip.
PostSubject: Re: Revell Metal axle replacement.   Wed 17 May 2017, 3:28 pm
Thanks for that. I'll need to do something like this with the big Mustang I'm doing.
PostSubject: Re: Revell Metal axle replacement.   Wed 17 May 2017, 4:47 pm
PostSubject: Re: Revell Metal axle replacement.   Sat 20 May 2017, 10:01 am
PostSubject: Re: Revell Metal axle replacement.   Mon 22 May 2017, 3:50 pm
