 Fokker DVII-F Roden 1/72
PostSubject: Fokker DVII-F Roden 1/72   Mon 15 May 2017, 8:09 pm
Well, the Nieuport is nearing completion and it's time for another project.  I saw some Part photoetch for a Fokker DVII F on ebay and had to grab it.  It's a rather intense photoetch for 1/72 scale.  The framework ribbing and it's interior parts get assembled by itself and later slid into the shell of the fuselage.  I acquired their PE kit for a Gotha II Bomber some time back, but felt I needed something smaller to test my skills and eyes on first.
So here is Hermann Goering's Fokker DVII-F that's going to be the test subject.  It's another Roden 1/72 scale kit.  I like the Roden line because it's well detailed, low priced and a bit easier for me than Eduard's.
The framework comes out as 1 piece that gets folded up to form the cage.
Wish me luckon this one,
PostSubject: Re: Fokker DVII-F Roden 1/72   Mon 15 May 2017, 9:05 pm
Good luck Mike, you'll nail it!! popcorn
PostSubject: Re: Fokker DVII-F Roden 1/72   Tue 16 May 2017, 4:17 pm
Superior model for 1/72! Let us know which mental institution you'll be at when you're done. I'll want to send my thanks.
PostSubject: Re: Fokker DVII-F Roden 1/72   Tue 16 May 2017, 8:34 pm
Hey, it's only 1/72 - after doing the PE for the 1/600 Iron Duke, this should be almost 9 times easier - Right?  LOL
This is the frame cage, cut out successfully.  The PART photoetch cuts a lot easier than Eduard or Tom's Modelworks.
Laying a single edge razor at the bend line on top, I used another single edge blade underneath to lift and make the bend.
A little final adjustment to make it square and it's ready to be CA'd tight. Floorpiece looks crooked because its not glued on the right side yet.
So far, so good.
PostSubject: Re: Fokker DVII-F Roden 1/72   Tue 16 May 2017, 9:27 pm
Fantastic PE work Mike, shame to hide it with the plastic!
PostSubject: Re: Fokker DVII-F Roden 1/72   Mon 22 May 2017, 3:50 pm
That PE is amazing - hard to believe it's out of the box and not an add-on. Looking forward to seeing this develop.
PostSubject: Re: Fokker DVII-F Roden 1/72   Sat 27 May 2017, 4:32 pm
Minor setback on this one. I primed the frame with Tamiya grey and trying to duplicate the light grey frame on Goerring's plane, shot some rattle can light grey enamel. It clogged up the little holes and filled in the gussets. So, it's been sprayed with oven cleaner to try again.
It looks like this will be a long term project with slow progress. So, another project will be started.
PostSubject: Re: Fokker DVII-F Roden 1/72   Sun 28 May 2017, 4:22 pm
Sorry to hear about the paint issue. Here's to the clean up being smooth, complete and uneventful.
