 BMF "Ultra Shiny Chrome"
PostSubject: BMF "Ultra Shiny Chrome"   Wed 10 May 2017, 10:25 am
Anyone else had issues? My problem is that it won't cut cleanly when the blade is dragged along it. I've not had the problem with other BMF foils.
I tried various shapes of scalpels, with little joy. 5 attempts to trim one piece is past a joke.
The blade seems to 'catch' and bunch up the foil, rather than cutting cleanly through. It's like the Ultra Shiny Chrome foil is more brittle?
GeeBee
PostSubject: Re: BMF "Ultra Shiny Chrome"   Wed 10 May 2017, 10:52 am
I tried it once, never again, it's a lot thicker than regular BMG, doesn't stick that well, and is harder to get it conform to tight curves, you're better off sticking to the New Improved chrome bmf.
https://scaleautoreplicas.wixsite.com/mysite
PostSubject: Re: BMF "Ultra Shiny Chrome"   Wed 10 May 2017, 12:19 pm
Geoff is the Guru with that stuff Chris, if he can't live with it, forget it!!
PostSubject: Re: BMF "Ultra Shiny Chrome"   Wed 10 May 2017, 12:33 pm
Bugger. I've just bought 2 sheets of the wretched stuff. Some Googling revealled the consensus is to steer clear of it, and stick to the regular.
I'll use it in non critical applications, and thanks gents.
Chris.
PostSubject: Re: BMF "Ultra Shiny Chrome"   Wed 10 May 2017, 12:36 pm
I had this problem with 'Ultra bright chrome' at first. I don't know if It's the same brand as yours. My solution, a new and ultra sharp and I mean ultra sharp blade. I don't mess about when it comes to knives. It needs to cut the very words out of the air. Well that's exaggerating things but that was my fix.
PostSubject: Re: BMF "Ultra Shiny Chrome"   Wed 10 May 2017, 1:55 pm
I agree with the concensus that all the other BMF products are thicker and more difficult to work with. I've tried the Black Chrome, Ultra Chrome, Copper, and Matte Aluminum and have found the easiest way to cut, if you can, is to use a curved-edge XActo blade and roll it along for the cut. Similar precautions for tucking it into the details. Tuck it in with the edge of a toothpick or craft stick rather than drag the pick along the surface.
Also the Black Chrome is a nice product, but the black coating can wear off when applying, leaving the chrome understrata.
Promodmerc
PostSubject: Re: BMF "Ultra Shiny Chrome"   Wed 10 May 2017, 7:27 pm
My first foil job was with the Ultra chrome which I used back in January this year. I had a hard time getting it to stick, and it curled up like a pigs tail when I removed it from the backing.
When I put the glass in, I knocked some of it off where there were tight bends. Thank goodness for Molotow Chrome. Touched it wright up and can't tell the difference.
PostSubject: Re: BMF "Ultra Shiny Chrome"   Sat 13 May 2017, 5:13 pm
The few times I've used BMF I found that pulling the blade wasn't as 'safe' as the method Mike mentioned, which is more like 'guillotine' cutting. Never used the Ultra Shiny Chrome version though, that stuff I am not familiar with.
» A.O.I.'s Shiny Center :D (CLOSED UNTIL B/W)
» Chrome R/C Dalek review
» Finding Ralts with will-o-wisp or shiny Tyrogue :D
» WTB FWB OEM Chrome Wheels 94-96
» Shiny Totodile on Black?
