 Revell 41 Willys Streetrod
Go to page : 1, 2, 3, 4  Next
GeeBee
PostSubject: Revell 41 Willys Streetrod   Sat 22 Apr 2017, 8:09 pm
And now for something completely different !
After a few years of a certain someone, who will not be named  (SHAY !!) kept on, and on, and on, for me to build a hotrod, so here goes .....
And another thing I've never tried is finger nail polish, and not just any finger nail polish, but one with a metal flake in it, hopefully it will work out o.k
Started it later today after getting the Citroen 2cv finished, removed a few fine mold lines and re-scribed the panel lines, got the engine started and the seats fitted together, and started on the interior and got the wheels and tyres built, so far, a nice little kit to put together.
https://scaleautoreplicas.wixsite.com/mysite
PostSubject: Re: Revell 41 Willys Streetrod   Sat 22 Apr 2017, 8:43 pm
PostSubject: Re: Revell 41 Willys Streetrod   Sat 22 Apr 2017, 10:05 pm
be good to see you do something a bit out of the ordinary
PostSubject: Re: Revell 41 Willys Streetrod   Sat 22 Apr 2017, 10:25 pm
Suburb hot rod material. !!
PostSubject: Re: Revell 41 Willys Streetrod   Sun 23 Apr 2017, 1:08 am
This is going to be good.
PostSubject: Re: Revell 41 Willys Streetrod   Sun 23 Apr 2017, 6:06 pm
Looking very forward to this one! The only thing I'd be concerned about is the metal flake polish through an airbrush - I've been told that it can cause issues depending on the size of the flakes.
GeeBee
PostSubject: Re: Revell 41 Willys Streetrod   Sun 23 Apr 2017, 6:17 pm
Yes the flake didn't get through the needle that well, even using the #5 set up on the Passche H, i ended trying a gold nail Polish with a smaller flake in it, even though it worked, you could see the primer through it, so it needs to be airbrushed over a gold or silver base, sadly the body is in the stripper, I'll get back to it in a few days, hopefully round two will grt better results
PostSubject: Re: Revell 41 Willys Streetrod   Sun 23 Apr 2017, 6:46 pm
You didn't do the spoon test?
I'm amazed you went straight at the shell Geoff, new paint medium and all.
GeeBee
PostSubject: Re: Revell 41 Willys Streetrod   Sun 23 Apr 2017, 6:51 pm
Yes, i did the spoon test first, strangely it was fine on that
PostSubject: Re: Revell 41 Willys Streetrod   Sun 23 Apr 2017, 9:01 pm
You can't win em all Geoff. Next time you'll nail it.
PostSubject: Re: Revell 41 Willys Streetrod   Sun 23 Apr 2017, 9:19 pm
x2
PostSubject: Re: Revell 41 Willys Streetrod   Sun 23 Apr 2017, 9:44 pm
Too bad about the paint. I thin the crap out of the nail polish with Acetone and strain the glitter out of it with a reusable Kureg cup.
PostSubject: Re: Revell 41 Willys Streetrod   Mon 24 Apr 2017, 3:00 am
Sorry to hear about the setback with the paint/polish. Curt's sig seems to be the appropriate thing to say (see above).
GeeBee
PostSubject: Re: Revell 41 Willys Streetrod   Tue 25 Apr 2017, 1:17 pm
Got the body back to white styrene, now for round two
PostSubject: Re: Revell 41 Willys Streetrod   Tue 25 Apr 2017, 9:59 pm
Good stuff Geoff boy.
Can you show a file pic of the new blue you'll be using.( I have Geoff's phone tapped, say nothing..lol!)
PostSubject: Re: Revell 41 Willys Streetrod   Tue 25 Apr 2017, 11:45 pm
PostSubject: Re: Revell 41 Willys Streetrod   Wed 26 Apr 2017, 8:33 am
GeeBee
PostSubject: Re: Revell 41 Willys Streetrod   Wed 26 Apr 2017, 6:53 pm
Got it airbrushed this morning, a few dust nibs that needed wet sanding out, the paint must have been a bit thin onbtge rear wing, so ended up blowing the whole body over again, not a bit of dust in sight, so I'm planning on getting a couple of coats of clear coat on it Friday.
PostSubject: Re: Revell 41 Willys Streetrod   Wed 26 Apr 2017, 9:39 pm
Beautiful Geoff.
GeeBee
PostSubject: Re: Revell 41 Willys Streetrod   Thu 27 Apr 2017, 1:29 pm
Got the clearcoat done this morning, i won't have much time to spend invthe hobby room now until Monday, which will give it plenty of time to dry up
Once dry it will be wet sanded and polished
PostSubject: Re: Revell 41 Willys Streetrod   Thu 27 Apr 2017, 2:59 pm
Beautiful color.
PostSubject: Re: Revell 41 Willys Streetrod   Thu 27 Apr 2017, 4:34 pm
GeeBee
PostSubject: Re: Revell 41 Willys Streetrod   Fri 28 Apr 2017, 3:08 pm
As I'm going to be busy over the weekend and not a lot to do today I thought I would make a start on the polishing, so far I've got the roof panel finished
GeeBee
PostSubject: Re: Revell 41 Willys Streetrod   Fri 28 Apr 2017, 4:00 pm
Bootlid finished
GeeBee
PostSubject: Re: Revell 41 Willys Streetrod   Fri 28 Apr 2017, 4:01 pm
» Revell 1/6 Dodge 426 Hemi
» Revell Aqua
» Revell P-47D in 1/72nd
