 32 Ford Five Window. (Open to all)
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Promodmerc
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sun 02 Apr 2017, 2:31 pm
Plastic Freak wrote:
Nice looking results Dan. Did you crack open the pen?
I bought a 30ml refill. The top of the pens come off so you can refill them.
The 30ml cost me just under $35. I bought it off EBay. The seller was in the UK.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sun 02 Apr 2017, 2:50 pm
Great looking wheels.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sun 02 Apr 2017, 4:21 pm
I found that same add just after I posted the question. Damn expensive. We have a dealer here in Canada, going to try there first.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sun 02 Apr 2017, 8:01 pm
It might be expensive, but you can't argue with the result.
It appears to be the best thing on the market.
Nice work Dan, do you have to decant it all at the same time and put the rest into a jar? and how much ink/ how many coats did it take?
Promodmerc
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sun 02 Apr 2017, 10:45 pm
The refill bottle has what I'd call an eye dropper tip. Just squeeze some out and put the cap back on.
I didn't use much ink at all. I would say that the level was around 5mm high in my cup, and I used three fills at the same level.
I gave the wheels 3 or 4 passes.
I'm also going to experiment with using a real fine brush, and see how well it applies. The 1mm tip is even quite large for certain task.
I believe Molotow says you can refill the pens up to 10 times depending on the size of pen. The 1 & 2mm have the same size barrel, the 4mm has a larger barrel.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Tue 11 Apr 2017, 12:46 am
I gave the lines left over
from the roof chop a little bit of filler and sanding and filler and sanding... lol
PostSubject: Re: 32 Ford Five Window. (Open to all)   Tue 11 Apr 2017, 9:43 am
Looking good Shay, brilliant result on the roof chop.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Tue 11 Apr 2017, 7:17 pm
progress Shay.
I am not going to bother with my current build idea project I had posted to join in with. Simply too much for my current build load of stalled kits and other ideas I should pursue and complete first.
Sorry guys.
GeeBee
PostSubject: Re: 32 Ford Five Window. (Open to all)   Tue 11 Apr 2017, 7:22 pm
About time !!, looking good though Shay ....
https://scaleautoreplicas.wixsite.com/mysite
PostSubject: Re: 32 Ford Five Window. (Open to all)   Tue 11 Apr 2017, 9:29 pm
The chop was done really well by a mate of mine in Detriot, he tidied it up, but it needed just a tiny bit more filler.
Oh and if anyone needs parts to be chromed/rechromed properly let me know, he's just taken over a chroming business,I won't peddle his wares here, so PM me if you need anything done, even anodising or gold plating I'll put you in touch with him.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Wed 12 Apr 2017, 5:28 am
Very nice.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Fri 14 Apr 2017, 1:40 am
Ha, I ordered this a couple weeks ago. It showed up today.
I simp,y couldn't resist not joining in. Just didn't want to say anything until it actually came in.
Starting on this tonight.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Fri 14 Apr 2017, 3:37 am
I decided to give it a modest 3 scale inch chop.
Initial chop and fit done. Obvious further work is required.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Fri 14 Apr 2017, 6:49 pm
Looking good Curt, can you take pics of how you'll tidy up the roof?
PostSubject: Re: 32 Ford Five Window. (Open to all)   Fri 14 Apr 2017, 9:54 pm
I will Shay. It will involve reshaping and fitting new pieces and cutting back some areas.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 15 Apr 2017, 12:54 pm
Hi guys, I started on trimming the fit issues.
Shay here you go, a bit of a tutorial. I us the knife to cut/trim as much of the window openings I can with without noticeably altering the look. On panels and flat sections I like scrap the knife to remove material to line up the surfaces.
In the third picture you can see the right C-pillar has been scraped to a rough fit. The window opening on the right side is going to require some sculpting/shaping to get the window lines to line up.
The A-Pillars are going to take another technique.
Of course the panel lines will also have to be altered and aligned.
[/url]
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 15 Apr 2017, 1:40 pm
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 15 Apr 2017, 6:14 pm
Thanks Curt, looks great you can sort of bend back the top of the A pillar I believe?
I must ask George exactly how he did my one, the plastic was untouched on the outside, not even sanded or filled, the step you have on the rear pillar is still there on my one except it's on the inside, seems all the work was done on the inside, but I can't see any grinding or sanding, just tiny amounts of filler.
Keep going!
PostSubject: Re: 32 Ford Five Window. (Open to all)   Fri 21 Apr 2017, 5:24 pm
Hi guys,
I decided before I jumped into this build that I wanted a chopped top. Alway on evil bay I found a chopped Jimmy Flintstone shell. In the add the chop looked clean. This POJ showed up. I know JF stuff is rough but this is outrageous. I have posted my progress to show the comparison.
I have put a claim in with Pay Pal and eBay.
Promodmerc
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 22 Apr 2017, 1:28 am
Hi guys,
I have three Jimmy Flintstone resin bodies. One is really clean, with little flesh. The other two are pretty bad. One is worse than the one you got.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 22 Apr 2017, 1:50 am
I was going to get one of those too originally, but I was warned off them.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 22 Apr 2017, 9:39 am
The body is looking good Shay but I respectfully refer you to post six!!! LOL
Nice work on the chop Curt.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 22 Apr 2017, 9:51 am
Looking good, guys. I have done several of these over the years. I think I have chipped every one of them, some quite severely.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 22 Apr 2017, 2:12 pm
Thanks Al.
I have another shell of a different body that is great, my LHS sells JF stuff, the shells I have looked at are pretty good.
The eBay listing says no returns. I guess they don't really want this crap either.
Anyway, I sent along a nice letter with the pictures I posted here of my chop stating I only have a few hours into mine and it's not even close to being done and looks way better. Further stating the shell I received looked like it had been done by a first timer and should never have been cast.
They, 'Jimmy Flintstone', agreed to a return. The issue now is, I am stuck with paying the return shipping which is about $10.
If the shell actually looked like this I'd be happy.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 22 Apr 2017, 4:45 pm
Did you pay via PayPal Curt? If so open a dispute with them, you should not have to pay return shipping.
Page 7 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Skid's Place :: Community Builds :: Members Group Builds WIP's-
