 32 Ford Five Window. (Open to all)
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Promodmerc
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 04 Mar 2017, 4:17 am
dublin boy wrote:
You should run for President Dan.
It's all fake news that you haven't put up any pics yet!
My first order of business is to sign an executive order, sending the U.S. military to China, to confiscate all of Revell's and Roun2's molds and bring them back to the U.S.
I spent at least 30 minutes sanding that retched mold blob off the back of my body tonight.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 04 Mar 2017, 9:21 am
Looks brilliant Al, If the step is going to be black that would break up the silver a bit, you must be happy with it!
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 04 Mar 2017, 10:52 am
I spent at least 30 minutes sanding that retched mold blob off the back of my body tonight. wrote:
My, that must have been painful.!!
Gary... yes the step will be black, maybe with chrome trim with the help of a Molotow Chrome pen!!
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 04 Mar 2017, 12:21 pm
Laid the gloss coat last night:
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 04 Mar 2017, 12:53 pm
Looking good Al. I am noticing labels on the lids of the Tamiya jars. Is that normal labelling, what does it say?
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 04 Mar 2017, 1:28 pm
That shine looks great, Al.
Promodmerc
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 04 Mar 2017, 1:57 pm
I should have taken a picture before I sanded it off. I'm taking it your's wasn't that bad? Mine had to be close to 1mm thick.
Now as far as other mold lines, the two 3 window kits I have had several, but my 5 window didn't.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 04 Mar 2017, 2:46 pm
Looks very nice to me Al....
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 04 Mar 2017, 6:09 pm
Thanks three.
Now, just for Shay, this is how I do a covered roof. (And how NOT to do it)
You will need some suitable medical tape. Wide enough to cover the whole area if you want it in one piece or narrower if you want to do it multi piece. You will also need a sheet of styrene.
Cut a piece of medical tape over size and stick it to the styrene sheet.
Now spray it your chosen colour. It will probably take several coats to get good coverage.
Now lay it over the edge to be covered and lightly burnish the edges:
Now burnish well as you would BMF and cut as per BMF and remove unwanted tape. This normally works well but in my haste I think I didn't allow enough time for the paint to dry properly, as you can see:
To remove tape glue residue in the past, I have had success with Methylated spirits but not this time. I cut through the clear gloss and the paint in double quick time.
So in the bath it goes.
Oh well, the sun will still rise in the East tomorrow.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 04 Mar 2017, 7:03 pm
Was that 2k or Promatic clear Al?
The Surgical tape is very tacky obviously.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 04 Mar 2017, 7:18 pm
Promatic Shay.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sat 04 Mar 2017, 7:57 pm
I've only used it once, but it does seem to take a day or two to cure, it doesn't "smell" dry for want of a better explanation.
If you had sticky residue, you might have had some joy with Fairy Liquid, hot water and a toothbrush?
Just wondering.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sun 05 Mar 2017, 6:38 pm
I have never known this to happen before.
Primer, base silver, base clear red, clear coats....... when stripped the clear red has 'dyed' the styrene orange!!!
Thanks for your thoughts Shay. I'm going to let it cure for a few days this time, change the medical tape I used AND do a small test piece first this time.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sun 05 Mar 2017, 6:43 pm
Well, that's a strange one!
Could it be a reaction between the clear red and the Promatic I wonder?
Gives a whole new meaning to bleed through. LOL
You're painting it red again I guess?
Promodmerc
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sun 05 Mar 2017, 6:47 pm
Finally a couple of pics of a little bit of work.
This should keep the little green man at bay for now
The result of sanding off the retched mold blob. To get completely rid of it, I sad to sand the rear window trim off and make it smooth. I however like the smooth look.
The canvas top insert removed.  I ain't afraid of no ghost
A resin firewall & resin Raider wheels I will be using.
Both came from the same place. Forward_Resin from eBay.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sun 05 Mar 2017, 6:48 pm
I might sand of that top too.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sun 05 Mar 2017, 6:55 pm
You're painting it red again I guess? wrote:
Already done Shay. Just have the clear to lay down.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sun 05 Mar 2017, 7:06 pm
The Tutorial on how to do the top was bloody fantastic otherwise Al...
PostSubject: Re: 32 Ford Five Window. (Open to all)   Sun 05 Mar 2017, 7:20 pm
I was going to suggest cutting the material before you paint the car and apply it later, but you're way too quick, Al.
Have another kit of that type?
PostSubject: Re: 32 Ford Five Window. (Open to all)   Mon 06 Mar 2017, 11:27 am
Hope you have better luck this time Al, the finish was beautiful.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Mon 06 Mar 2017, 12:45 pm
Too bad Al, better luck on the second go round.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Mon 06 Mar 2017, 4:56 pm
Thanks guys. Resto is on the way.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Wed 08 Mar 2017, 6:07 pm
Finally making progress again.
Engine completed and installed, wheels on and detailed, fabric on roof. (courtesy of a fresh roll of Micropore and patience)
PostSubject: Re: 32 Ford Five Window. (Open to all)   Wed 08 Mar 2017, 6:09 pm
Looks stunning Al.
PostSubject: Re: 32 Ford Five Window. (Open to all)   Wed 08 Mar 2017, 7:47 pm
X2.
Page 5 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
» '34 Ford 5 window coupe
» 32 Ford 5 window coupe
» AMT John Milner 32 Ford Coupe
» 1932 Ford Sedan High Boy
» GN rear window mod
Skid's Place :: Community Builds :: Members Group Builds WIP's-
