Lloyd Ruby's 1970 Mongoose Indy Car
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Lloyd Ruby's 1970 Mongoose Indy Car
Looking good all decaled up. Nice work, Art.
A shame you needed to make so many improvements just to get it to a decent standard. Your skills and the work to find good reference fotos really makes a difference! Thanx a bunch.
Stunning work! Your improvements are definitely just that
harron68 wrote:A shame you needed to make so many improvements just to get it to a decent standard. Your skills and the work to find good reference fotos really makes a difference! Thanx a bunch.
Yeah, for a resin kit, it's pretty nice, but I do like to make it more accurate and do things that set it apart. Once I find reference shots, it can make a lot more work!
I got some more done on the interior. The belt kit I got from Scott at futurattraction.com. It has some really small parts, but makes a real nice latch!
Thanks for looking!
Art Laski- New Member
Speed Racer 65 wrote:Very nice crisp paint work Art.
How did you anodize the parts blue?
The blue was Tamiya clear blues acrylic mixed about 1:1 with some thinner that was given to me by a fellow model club member. He had some Gunze thinner reverse engineered then mixed up a big batch. I sprayed it over the polished metal directly, or over Testors Aluminum Plate metalizer on the plastic parts.
Made a wheel that matches the reference shot a little better than the kit wheel. I started with a wheel from another 70's AMT kit.
I tried to make a wheel center cut on a Cricut scrapbook machine, but that didn't work out. So I decided to use some printing plate aluminum my buddy Brad gave me just last weekend. Inspired by how my friend Randy D. uses his files to make parts to perfection, I thought I would give it a try on this. Not perfection, but as good as I could have hoped for.
Polished it up and added some photoetch "bolts".
I also made a shifter mechanism.
Excellent detail work! The belts look great and the steering wheel and shifter are fantastic!
Thanks, Kats!
I was trying hard to finish this build in time for the GSL last weekend, so I haven't made any posts. I did manage to finish it last Friday in my hotel room. Well, almost finished. There are a few things left I'd still like to do. I want to see if I can get a more accurate wheel set up, and I also need to male the fuel buckeyes on the left side of the tub. Here are some shots I manage to take during the push.
When I got the kit, it didn't have any brake discs in it, so I turned a set on my lathe. (It's about all I can do with it :) )
To complete the setup, I made a mold off of the spindle to cast additional brake calipers.
I cut the turbo off and added a Detail Master flange, and also so I can paint it separately.
Here's the intake and exhaust all painted up.
I reconfigured the rear trans cover and machined a starter coupler.
I made a rear bumper from brass. This was before I added the bottom hoop. I painted it with Alclad chrome.
Added a rear pan made from aluminum printing plate and styrene strip. I found that Testors Ford Engine Light Blue is an almost exact match for the decal blue.
Of course I have Pro Tech braided line throughout, but I added some to the interior per the reference pictures.
Here are some "finished" shots I took in a booth called a Shotbox that were available for use at the GSL. I didn't get the lighting right, so I messed with the pics a little. Still not great.
A couple of notes I didn't show. The tires were replaced with Indycals tires for accuracy. I also used aluminum rod instead of the white metal roll bar so I could polish it up. I used Pro Tech nut and bolt heads for the windshield. I also added what I think is a trans cooler and a tank on the right side, and the turbo inlet.
Thanks for looking!
Thanks for looking!
Worthy of ANY contest or model magazine!!!! The phenomenal "extras"on suspensions and engine make it a very unusual and special champ! When you consider how utterly basic the kit is, the work added does do it justice.
Beautiful build! The attention to detail really brings this to life.
Thank you, guys!
NICE !!!!
Intake hose couplings look really good !
Nice work, Art, I'm watching this!
Tom Louis- New Member
Great build.
Page 2 of 2 • 1, 2
Page 2 of 2
