 AMT '57 Chrysler 300C
Go to page : 1, 2, 3, 4  Next
GeeBee
PostSubject: AMT '57 Chrysler 300C   Thu 09 Feb 2017, 4:46 pm
I've been putting off building the small amount of American cars I have in the stash because the problem of getting hold of the correct shade of paint to paint them in, that problem has now been solved as MCW now send their paint oversea's, and as this is probably the longest American kit that has been sitting in my stash, I thought it was about time it got built.
Looking at the colours of the models I have already in the display cabinet, I wanted something a little different from the blues, greens and other bright colours I've built models in, so this one will be done in Copper brown metallic.
I haven't built an AMT since the mid 90's, and so far I'm pretty impressed with the quality and the detail in this kit, it's certainly made me a fan of AMT kits
As I've said, I've had this kit sitting in the stash for more years than I can remember, but one thing I did notice, was that the rear bumper had previously been stripped of it's chrome and half painted in grey primer, so that was the first job, it was sanded smooth and given a couple of coats of grey acrylic primer, then it will be chromed using the K Colors paint I bought at the IPMS show last year
The body was inspected and there were only a few mold lines that were removed, at the same time I re-scribed the panel lines as I didn't want them covered when I do the painting,
The first job on the instructions is to build the engine, and that's what I did, it seems a shame to put the rocker covers on, as they will hide all the detail of the rocker valves molded into the cylinder head, but I'm not building a garage diorama, so sadly all that detail will have to be covered
The interior was dry fitted before it got a coat of primer, very impressed with the fit of the parts
The mold lines on the exhaust were removed with a small file and sandpaper, the instruction tell you to install them before the front torsion bars and the rear axle and suspension go on, but a dry fit confirmed that they can be fitted afterward, although it does take a bit of jiggling.
One of the mounts for the rear shock absorbers were broken off the crossmember, so I cut the other one off and made a set out of a couple of dressmaker pins
The rocker covers and air filters were airbrushed in gold
The rear bumper, that had previously been primed, was given a couple of coats of the K Colors black basecoat
Nest the interior, seat and side panels were painted in light tan, for this I used Humbrol #103
The battery was first airbrushed in gloss black, then the filler caps were picked out with Tamiya red enamel, the terminals were picked out using Tamiya silver chrome
The next step I deviated slightly from the instructions, as the bulkhead and the small bit of the floorpan need to be done in body colour, and as it will make for a neater job, I used the interior side panels, taped into place, so the bulkhead could be fixed to the floorpan,
Although the sidewalls were molded in white, to me they looked a little too much like white plastic, which is what they are, so they were given a few coats of white acrylic primer, the bottom two still need to be primered
The chassis was first primered and then given a few coats of gloss black acrylic lacquer
The rear bumper, after leaving the black basecoat to dry out for 732 hours, as suggested by K Colours, was chromed
The wheels were built up and fitted to the chassis, and as a bonus, all four wheels touch the ground at the same time
That's one exhaust fitted, took a bit off jiggling, but I got it done
The air filter elements were hand painted in flat white acrylic
Chassis finished
Air filters fitted onto the engine
Dashboard finished
https://scaleautoreplicas.wixsite.com/mysite
PostSubject: Re: AMT '57 Chrysler 300C   Thu 09 Feb 2017, 6:40 pm
That black base coat needs a LONG curing time Geoff, is the chrome K colour Too?. It looks fantastic.
popcorn
GeeBee
PostSubject: Re: AMT '57 Chrysler 300C   Thu 09 Feb 2017, 6:41 pm
Can't believe I've spent most of the day doing the bmf on the side panel, I've still got the other side to do .....
Also got the steering wheel fitted
GeeBee
popcorn
Yes, they are water based, unlike Alclad, so they need a longer time to dry up, yes, the chrome is K Colors as well
PostSubject: Re: AMT '57 Chrysler 300C   Thu 09 Feb 2017, 6:42 pm
Thanks Geoff, stunning BMF work!
GeeBee
PostSubject: Re: AMT '57 Chrysler 300C   Thu 09 Feb 2017, 6:43 pm
Cheers, my eye's are now hurting !
PostSubject: Re: AMT '57 Chrysler 300C   Thu 09 Feb 2017, 7:25 pm
PostSubject: Re: AMT '57 Chrysler 300C   Thu 09 Feb 2017, 9:39 pm
Beautiful work, Geoff.
That is one of the better AMT kits - some of the others are still the same as before.
PostSubject: Re: AMT '57 Chrysler 300C   Fri 10 Feb 2017, 9:29 pm
An amazing amount of kit detail! And your work with it is beautiful, the BMF on the side panels is pristine.
GeeBee
PostSubject: Re: AMT '57 Chrysler 300C   Sat 11 Feb 2017, 7:48 pm
Got the floorpan painted today, 1st time using the paints from MCW, and it won't be the last,
PostSubject: Re: AMT '57 Chrysler 300C   Sun 12 Feb 2017, 12:22 am
Looks like the colour of Jack Reegan's Consul 3 litre GT, pity we can't have a kit of that.
GeeBee
PostSubject: Re: AMT '57 Chrysler 300C   Sun 12 Feb 2017, 8:19 pm
Got the bodyshell and bonnet painted today, also got the floorpan masked up so the fuel tank can be airbrushed
PostSubject: Re: AMT '57 Chrysler 300C   Sun 12 Feb 2017, 9:26 pm
That's quite shiny for a base coat already Geoff, nice job.
A bit of clear and polish and it'll pop.
GeeBee
PostSubject: Re: AMT '57 Chrysler 300C   Sun 12 Feb 2017, 9:45 pm
It's not basecoat Shay, it could be polished as it is, clear coat will just give it a better shine and protection
PostSubject: Re: AMT '57 Chrysler 300C   Sun 12 Feb 2017, 10:08 pm
Interesting, I always understood that you can't polish out metallic paint.
Has this got some clear mixed in with the colour coat?
GeeBee
PostSubject: Re: AMT '57 Chrysler 300C   Sun 12 Feb 2017, 10:21 pm
Metallic finishes were totally different back then to the basecoat and clearcoat that car factories use today, the older paints are Duracryl lacquer, and can be sanded between coats and then the final coat can be polished, a clearcoat isn't necessary, but will add depth to the finish, 1970's Ford and Vauxhall cars over here used the same kind of paint until the 1980's.
PostSubject: Re: AMT '57 Chrysler 300C   Sun 12 Feb 2017, 10:29 pm
So is it like cellulose then from back in the day,
Polish your jam jar every Sunday kind of thing?
Mence
PostSubject: Re: AMT '57 Chrysler 300C   Mon 13 Feb 2017, 10:52 am
Fantastic....especially the chrome. :)
PostSubject: Re: AMT '57 Chrysler 300C   Mon 13 Feb 2017, 2:06 pm
Beautiful paint - color and finish.
GeeBee
PostSubject: Re: AMT '57 Chrysler 300C   Mon 13 Feb 2017, 10:48 pm
It's actually Acrylic Shay, but unlike todays cars, didn't have a UV protective clear coat, which is why you see photos of these cars back in the day faded, because the oxidation, unless they were polished on a regular basis, something you don't see too many people out there in a Sunday polishing their cars, because really there is no need, as your just polishing clear lacquer, they don't fade, so people don't bother anymore.
PostSubject: Re: AMT '57 Chrysler 300C   Tue 14 Feb 2017, 12:53 pm
Really sharp looking build Geoff. I have to agree the detail and engraving of this kit is fantastic. Although I have to say the one I built the fit on a number on parts required some real trimming and manipulating.
PostSubject: Re: AMT '57 Chrysler 300C   Tue 14 Feb 2017, 1:09 pm
Very nice....
GeeBee
PostSubject: Re: AMT '57 Chrysler 300C   Tue 14 Feb 2017, 5:35 pm
Got the body and bonnet clearcoated today, I'll leave it for a few days before wet sanded and polishing
PostSubject: Re: AMT '57 Chrysler 300C   Tue 14 Feb 2017, 6:25 pm
I'd just get the Safe Cut on that Geoff, I can't see any need for wet sanding.
If you got the Promatic, it's "softer" than say Halfords/Holts and polishes out with less elbow grease.
GeeBee
PostSubject: Re: AMT '57 Chrysler 300C   Tue 14 Feb 2017, 7:22 pm
There's a few dust nibs in the paint that need flatting out Shay, might as well do the job properly .....
The lacquer is 1K acrylic lacquer I borrowed from my local bodyshop
» AMT 57 Chrysler 300C
» AMT '57 Chrysler 300c: Redo/Tweak
» 1955 Chrysler 300
» Living with Nature's creatures
» The official pay it forward thread....
