 MFH Porsche 917 LH
Art Laski
Art Laski
MFH Porsche 917 LH - Page 2 Empty
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeFri 10 Feb 2017, 6:22 am
Neat build, Paul!
Curtis
Curtis
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeFri 10 Feb 2017, 2:17 pm
Great detail Paul. You are going to knock this one out of the park.
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeFri 10 Feb 2017, 6:35 pm
Thanks for the info Gentlemen.
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeFri 10 Feb 2017, 9:37 pm
Stunning work!
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeSat 18 Feb 2017, 12:55 am
Thanks guys
I've learned with these kits that every piece has to be checked to make sure it fits to the piece next to it.  I trial fit the rear frame pieces to the front frame.
MFH Porsche 917 LH - Page 2 LH033-vi
MFH Porsche 917 LH - Page 2 LH034-vi
MFH Porsche 917 LH - Page 2 LH035-vi
MFH Porsche 917 LH - Page 2 LH036-vi
Then I started to clean up the rear frame pieces and got most of the holes drilled in them.  The rear frame was dry assembled for fit. I still haven't decided how I will glue this piece together. My options are CA, epoxy or possibly low temp solder.
MFH Porsche 917 LH - Page 2 LH037-vi
MFH Porsche 917 LH - Page 2 LH038-vi
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeSat 18 Feb 2017, 7:01 am
Looks amazing Paul.
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeSat 18 Feb 2017, 5:27 pm
Now that's a spaceframe! Very nice Paul.
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeSun 19 Feb 2017, 8:31 pm
MFH Porsche 917 LH - Page 2 2337884168
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeWed 08 Mar 2017, 7:05 pm
Looking good Paul. Nice work.
I'd go with tiny amounts of epoxy. Bit too much risk with solder and I'm not sure CA would be strong enough!
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeThu 15 Feb 2018, 12:42 am
It's been awhile since I worked on this build.  I had a major falling-out with my build partner, which also killed my building mojo.  But I'm hoping it's back because I got the pieces out and started working on it again.  After attempting to low-temp solder some scrap white metal together, I realized it wouldn't take much of an error to reduce an expensive kit to a puddle of metal. So I decided to try this stuff.
MFH Porsche 917 LH - Page 2 2v2JebC1hxHpLjS
Starting with the five main engine framework pieces, I slowly built my way up to this rear frame.
MFH Porsche 917 LH - Page 2 2v2JebCKVxHpLjS
MFH Porsche 917 LH - Page 2 2v2JebCpCxHpLjS
MFH Porsche 917 LH - Page 2 2v2JebCwDxHpLjS
MFH Porsche 917 LH - Page 2 2v2JebC7CxHpLjS
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeThu 15 Feb 2018, 1:03 am
Very impressive Paul.
Curtis
Curtis
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeThu 15 Feb 2018, 1:13 am
Damn! That is awesome!
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeThu 15 Feb 2018, 1:50 am
Sorry to hear you had a kerfuffle with your build partner but I am glad to see you on this one again.
Location : Haydon Bridge, UK. (Just up the road from Al)
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeThu 15 Feb 2018, 10:00 am
Amazing skills!
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeThu 15 Feb 2018, 10:19 am
Well done Paul, looks like a Krypton Factor mental agility test lol
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeThu 15 Feb 2018, 7:45 pm
The engine itself is so good, it could be displayed outside the body. That is one wicked big scale kit!
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeThu 15 Feb 2018, 10:35 pm
Since the procedure for the rear frame was to glue a couple of pieces, wait 24 hours, then glue a couple more,  I also jigged up the front chassis tubes.
MFH Porsche 917 LH - Page 2 2v2JQaaKrxHpLjS
Then I stuck it into the front floor and added the dash and radiator to check the fit.  The body mates well with the dash and the rad does not interfere with the body.  I had seen another 917 build where the guy had to modify parts to clear the body and rad.
MFH Porsche 917 LH - Page 2 2v2JQaa1jxHpLjS
MFH Porsche 917 LH - Page 2 2v2JQaap8xHpLjS
MFH Porsche 917 LH - Page 2 2v2JQaabNxHpLjS
Curtis
Curtis
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeThu 15 Feb 2018, 11:09 pm
Some more great work Paul. Why the wait if you're using CA? It's instant.
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeThu 15 Feb 2018, 11:19 pm
The stuff I have pictured above isn't CA.  It's a sort of epoxy that you don't have to mix.  I had used it to fix a chair and it proved to be strong, so I went with it for the build.  It says it has a 30 min working time with a cure time of 24 hours.
Curtis
Curtis
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeThu 15 Feb 2018, 11:52 pm
Ah I understand now. Just browsed the pic, looks too much like CA. Good luck with it. I don't have the patients for that kind of set time when building.
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeFri 16 Feb 2018, 4:21 am
Me either Curt. I often use kicker on my CA because 2 minutes is too long...
Great stuff Paul. I"m glad the hood comes off so you can see all that. It would be a shame for hit to be hidden after you put the body on.
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeSat 17 Feb 2018, 2:28 pm
Looks like the geometry is spot on. Nice work, Paul.
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeSun 18 Feb 2018, 1:15 am
Thanks. Glad you guys are enjoying this build as much as I am
I used that same epoxy to add the cylinders to the block because it allowed me to get everything straight before it set up.  Wouldn't be able to do that with CA.
MFH Porsche 917 LH - Page 2 2v2JQwJDnxHpLjS
MFH Porsche 917 LH - Page 2 2v2JQwJ4qxHpLjS
Then I CA'd the heads on and trial fit the fan shroud.   I couldn't resist trying the engine out in its rightful place.  It was a little tight getting it in there.  It's going to be even tighter when completed.
MFH Porsche 917 LH - Page 2 2v2JQwJmFxHpLjS
MFH Porsche 917 LH - Page 2 2v2JQwJSyxHpLjS
MFH Porsche 917 LH - Page 2 2v2JQwJV5xHpLjS
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeSun 18 Feb 2018, 1:30 am
PostSubject: Re: MFH Porsche 917 LH   MFH Porsche 917 LH - Page 2 Icon_minitimeSat 24 Feb 2018, 6:36 pm
Awesome work! The frame is just ... intimidating, lol. The engine looks fantastic - can't wait to see this develop.
MFH Porsche 917 LH
