 Revell Volkswagen Beetle 1500 Convertible
GeeBee
PostSubject: Revell Volkswagen Beetle 1500 Convertible   Fri 02 Dec 2016, 7:18 pm
While waiting for some supplies to arrive so I could crack on with the 48 Ford convertible I've got on the go, instead of doing nothing, I opened one of these (Yes, I have 2 more in the stash), and as I had already had the paint mixed up for it, I thought it was about time I made a convertible beetle, it will go nicely with the other 2 Beetle's in the display cabinet.
As with all the recent Revell kit's I've built, the parts fit on these models is just first glass, the body had some very slight mold lines to remove at the front and rear of the body, but nothing too serious and a few minutes with a medium sanding stick soon made history of them
The body and body parts were prepped and then given a couple of coats of Hycote grey plastic primer applied using my Paasche H airbrush with the # 5 tips, and then dry sanded when dried and a few coats of VW Marine blue cellulose was applied
The engine and gearbox and other parts on the chassis just about fall into position, the interior was first painted in satin black acrylic and then flocked, the wheels and the running boards are supplied as part of the chrome sprue, so they were both put into some household bleach to remove the chrome, after a coat of primer the running boards got a coat of satin black to replicate the rubber and the wheels were given a few coats of Tamiya silver leaf and then the hubcaps were doing using chrome bmf, the horn ring on the steering wheel was also picked out using bmf after the wheel had been airbrushed in satin black
https://scaleautoreplicas.wixsite.com/mysite
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Fri 02 Dec 2016, 7:27 pm
Looks like a good detailed kit. I'll have to give it a go sometime.
GeeBee
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Fri 02 Dec 2016, 7:31 pm
The engine, gearbox and suspension isn't as detailed as the Tamiya Beetle, which I built a few years ago, but Tamiya kits can be over engineered and certain parts are fragile because of this, these Revell kits have the detail where you can see it, I built the saloon version earlier in the year, I'll take the Revell version over the Tamiya one any day.
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Fri 02 Dec 2016, 7:51 pm
Excellent. Thanks for that little bit of info.
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Fri 02 Dec 2016, 8:44 pm
BMF the horn ring??!! You have both determination and talent! The BIG folded down top always put me off buying a VW ragtop. It was both so high and just looked too smooth to simulate fabric.
Good luck with this addition to the collection. No oil leaks on the engine bottom?
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Fri 02 Dec 2016, 9:43 pm
More great work Geoff. I agree with you on the rag top, never was fond of it either. Looks like one of those silly over sized rear spoilers.
midnightprowler
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Fri 02 Dec 2016, 10:56 pm
Looking great.
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Sat 03 Dec 2016, 5:27 pm
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Sun 04 Dec 2016, 12:55 am
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Sun 04 Dec 2016, 5:05 am
What blue is it? Really works well, and ditto on the convertible top. Perched there like a county dunny!
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Sun 04 Dec 2016, 8:25 am
That blue is spot on for a Beetle, Ill follow along Geoff. popcorn
GeeBee
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Sun 04 Dec 2016, 11:32 am
VW Marine blue
GeeBee
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Sun 04 Dec 2016, 8:47 pm
Got a little more work done to the Beetle today, masked up the dashboard to airbrush the plastic parts, the glovebox and surround around the speedo are in real life metal, the rest of the dash is plastic, and has a totally different sheen to it, so I used some semi gloss coal black, just has a slightly less glossy appearance to the satin black I'd already airbrushed it, also got the door panels airbrushed in satin black, just the door pull and seat belt buckle to pick out with a little bmf now
Also got the exhaust silencer and towbar fitted
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Sun 04 Dec 2016, 9:35 pm
Brilliant Geoff.
midnightprowler
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Sun 04 Dec 2016, 11:15 pm
Looks great.
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Mon 05 Dec 2016, 12:01 am
Looking good Geoff
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Mon 05 Dec 2016, 1:37 am
Very nice work
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Mon 05 Dec 2016, 10:06 am
Excellent progress. I see they've actually bothered with seatbelts on the door sides, so I wonder, have they bothered with the receiver (seat belt clicky thing) on the seats?
GeeBee
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Mon 05 Dec 2016, 10:55 am
Yes they have, it's molded as part of the front seats
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Mon 05 Dec 2016, 3:36 pm
Excellent workmanship.
GeeBee
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Fri 13 Jan 2017, 7:53 pm
GeeBee
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Fri 13 Jan 2017, 7:54 pm
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Fri 13 Jan 2017, 8:07 pm
Excellent detail painting and clean building as usual Geoff.
What is that tow bar thing?
What could you tow with a Beetle anyway?
Does the kit come with some kind of trailer?
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Fri 13 Jan 2017, 9:12 pm
Beautiful work Geoff. popcorn
PostSubject: Re: Revell Volkswagen Beetle 1500 Convertible   Fri 13 Jan 2017, 9:23 pm
Excellent kit, overall! Nice work on the engine and dashboard. Wheels look great too, but find the tire sidewalls look both a bit flat (no side bulge) and lacking in brand detailing/tire dimensions. Looks like the model company cut corners there. All else okay!
» Volkswagen Beetle 1303S Rally
» 1994 Caprice Convertible (!)
» (2) 1999 Chevy 1500 Burbans
» Revell 1/6 Dodge 426 Hemi
