 1948 Ford Convertible (Monogram)
GeeBee
PostSubject: 1948 Ford Convertible (Monogram)   Thu 17 Nov 2016, 7:34 pm
Not my usual thing, but I've had this model sitting on the shelf for more years that I can remember, so I thought it was time it hit the bench, sadly the clear parts were missing, but thankfully a member on another forum helped me out with the windows, and I was lucky to find a set of headlamp lenses in my spares box that fitted.
Paint is done using automotive acrylics, I'm more used to using cellulose lacquer, but this colour I had in stock, and it's a 99% match for the Ford Barcelona blue, it's actually BMW dark blue.
Interior Finished
Engine Finished and fitted into the chassis
Hubcaps, the Ford lettering was picked out using satin blue paint
Body after being wet sanded
Fuel tank painted Testors steel
More build up shots
Bodywork after being polished and having the chrome done using bmf
https://scaleautoreplicas.wixsite.com/mysite
PostSubject: Re: 1948 Ford Convertible (Monogram)   Thu 17 Nov 2016, 7:39 pm
A lovely piece of work. I'm especially drawn to the effort in the paint finish. Certainly worth it in the end.
PostSubject: Re: 1948 Ford Convertible (Monogram)   Thu 17 Nov 2016, 8:08 pm
Beautiful shine Geoff.
GeeBee
PostSubject: Re: 1948 Ford Convertible (Monogram)   Thu 17 Nov 2016, 8:22 pm
I actually spent more time building and detailing the interior than anything else on the build, so I'm going to be using the top down option, which makes me wonder why I even put so much work on the top up option, the side panels were first primed, them painted a medium brown, masked off so the lighter colour could be done, then masked off again so the light tan panel could be airbrushed at the bottom of the door panel, in real life it is actually the same material as the floor carpet.and then finally the wood door capping was done by airbrushing it Testors wood, followed by dry brushing Tamiya bronze and then using Tamiya clear yellow on top.
Then the chrome strip and all the door and window winder handles were picked out using chrome bmf.
PostSubject: Re: 1948 Ford Convertible (Monogram)   Thu 17 Nov 2016, 8:53 pm
Mirror finish, great job Geoff.
GeeBee
PostSubject: Re: 1948 Ford Convertible (Monogram)   Thu 17 Nov 2016, 8:54 pm
And it has a V8 engine !!
PostSubject: Re: 1948 Ford Convertible (Monogram)   Thu 17 Nov 2016, 8:59 pm
You're on the Slippery Slope to a Hot Rod build Geoff! lol
GeeBee
PostSubject: Re: 1948 Ford Convertible (Monogram)   Thu 17 Nov 2016, 9:02 pm
I better go back to building Trabants, 2cv's and other cars with under powered engines then, Oh I feel a Fiat 500 coming on
PostSubject: Re: 1948 Ford Convertible (Monogram)   Thu 17 Nov 2016, 9:06 pm
Excellent..Fiat 500, build it like this Geoff!
https://www.youtube.com/watch?v=0ZdIYv_xFUc
PostSubject: Re: 1948 Ford Convertible (Monogram)   Thu 17 Nov 2016, 9:45 pm
Great work all round Geoff. Fantastic interior.
PostSubject: Re: 1948 Ford Convertible (Monogram)   Fri 18 Nov 2016, 9:24 am
The bodywork is sublime Geoff, superb paintwork!
PostSubject: Re: 1948 Ford Convertible (Monogram)   Fri 18 Nov 2016, 10:16 am
Nice !!!
Great paint work !
PostSubject: Re: 1948 Ford Convertible (Monogram)   Fri 18 Nov 2016, 1:14 pm
Why go to the effort to do the interior so well? That model, canvas top to white wall bottom, is something special. Take pride in having it on your shelf. Be grateful for the results your skill and, more important, patience proved! Thanx for sharing a genuine classic.
GeeBee
PostSubject: Re: 1948 Ford Convertible (Monogram)   Fri 18 Nov 2016, 1:34 pm
Don't worry, the canvas top up option won't be used on the model, really not sure why I did it, it will more than likely just go next to the model in the display cabinet when it's finished, here's a photo of how it will look when it's finished, I took a photo of the mock up before the body had been painted
Spanky 19
PostSubject: Re: 1948 Ford Convertible (Monogram)   Fri 18 Nov 2016, 2:57 pm
Stunning work. You have a clean and crisp technique that produces an outstanding model. is o
PostSubject: Re: 1948 Ford Convertible (Monogram)   Fri 18 Nov 2016, 6:37 pm
Excellent, most excellent.
Ace
PostSubject: Re: 1948 Ford Convertible (Monogram)   Sun 20 Nov 2016, 1:41 am
Yep, that is real excellent!
PostSubject: Re: 1948 Ford Convertible (Monogram)   Mon 21 Nov 2016, 12:20 am
Gorgeous! The work on the interior is fantastic and the body is amazing, the paint has that 'still wet' look which blows me away!
PostSubject: Re: 1948 Ford Convertible (Monogram)   Mon 21 Nov 2016, 4:31 am
Outstanding paint work.
GeeBee
PostSubject: Re: 1948 Ford Convertible (Monogram)   Mon 21 Nov 2016, 1:44 pm
Well finally got the bmf finished, only had the trim on the rear lamp housings to do, and gave the body a quick wipe over with Novus # 1 to get rid of the fingermarks
Got the heater and batter in place, so now I can start work putting the front windshield and quarter vents in place now
PostSubject: Re: 1948 Ford Convertible (Monogram)   Mon 21 Nov 2016, 2:30 pm
looking good.
PostSubject: Re: 1948 Ford Convertible (Monogram)   Mon 21 Nov 2016, 6:18 pm
Great work fer certain. I talked to a guy once who had an old Ford of the era ('42-'48) and he said that heater (middle below dash) really put out the heat. It had little doors in front. Funny these days to see the huge steering wheel, because power steering and quick (lock-to-lock) steering ratios were so slow. Thanx again.
GeeBee
PostSubject: Re: 1948 Ford Convertible (Monogram)   Mon 21 Nov 2016, 6:58 pm
Windshield fitted, not the best fitting windshield I've ever fitted, but it's in and not a glue mark or finger print in sight, Painting & wet sanding doesn't bother me, I don't even get stressed by the bmf, but getting the clear parts in without making a balls up scares the crap out of me !
PostSubject: Re: 1948 Ford Convertible (Monogram)   Mon 21 Nov 2016, 7:52 pm
Looking great Geoff.
PostSubject: Re: 1948 Ford Convertible (Monogram)   Tue 22 Nov 2016, 6:11 pm
What a beauty. Nice, really nice.
» Imc Union Testors 1948 Ford Carson Top
» 1948 Ford Flathead
» 1937 Ford Convertible
» 1994 Caprice Convertible (!)
