 Bantam II
PostSubject: Re: Bantam II    Thu 01 Sep 2016, 9:17 pm
I admire your work ethic! Best of luck. I'm curious as to if you'll scribe in door lines or leave it like a "top loader"?
PostSubject: Re: Bantam II    Mon 05 Sep 2016, 4:54 pm
Excellent progress! Love the look of the frame/chassis with the body
PostSubject: Re: Bantam II    Sun 18 Sep 2016, 1:51 am
PostSubject: Re: Bantam II    Sun 18 Sep 2016, 10:17 am
Nice work Chris and good call on opening the roof!!
Spanky 19
PostSubject: Re: Bantam II    Wed 21 Sep 2016, 4:50 pm
Fabricated the front engine mount and set the radiator, engine and body in place.  This is the first all three core components are together and right off I saw the grill sits too hight.  Look's like I need to trim a bit off of Frankenstein's head.
PostSubject: Re: Bantam II    Wed 21 Sep 2016, 5:10 pm
Dirkpitt289
PostSubject: Re: Bantam II    Wed 21 Sep 2016, 5:42 pm
Pretty cool looking
https://www.youtube.com/channel/UCY6YJLP_EUL5tQhLLIdnyxg?view_as
PostSubject: Re: Bantam II    Fri 23 Sep 2016, 2:28 pm
Spanky 19
PostSubject: Re: Bantam II    Sun 25 Sep 2016, 3:43 am
Transmission sourced from the parts box, glued in place then the floor board cut open and worked to fit the outline.
Two parts box buckets were sourced and formed into a bench. Still some tweaking to do but I think this will work.
PostSubject: Re: Bantam II    Sun 25 Sep 2016, 5:12 pm
PostSubject: Re: Bantam II    Sun 25 Sep 2016, 6:13 pm
Really like the potential in this build, can't wait to see how it ends up.
PostSubject: Re: Bantam II    Sun 25 Sep 2016, 10:01 pm
Good progress! Looking forward to seeing what comes next
Ace
PostSubject: Re: Bantam II    Mon 26 Sep 2016, 6:41 am
I am enjoying this one: I like the free flowing parts box fabrications like the grille. Also the 6 looks innerestin.
PostSubject: Re: Bantam II    Mon 26 Sep 2016, 10:34 am
Long 'n low. Ideal hot rod !!!
PostSubject: Re: Bantam II    Mon 26 Sep 2016, 10:56 am
Nice work Chris, I like the ide of the 'bucket-bench' seat.
Spanky 19
PostSubject: Re: Bantam II    Mon 10 Oct 2016, 11:03 pm
Grabbed a sprint car wing to use as the firewall.  I chose this because of the parallel lines that mimic those on the rear of the body.
Here is the firewall - pre putty to blend it in.  Also are the components of the engine.  I made the blower intake from the curved side of an old Alacart hood.  Pulleys are separated and I'll be using painted medical tape for the new belts.   I'm still considering the lines on the firewall. They may be too much of a distraction.
Spanky 19
PostSubject: Re: Bantam II    Tue 11 Oct 2016, 10:20 pm
Crafted some basic exhaust pipes from solder and plastic tubes.
I also scrounged the wheels and tires for the build. Using the advise and comments from my earlier Bantam build, I went with a smaller street tire on the rear this time around (instead of slicks) I couldn't find an inner rim with the correct off set so I used a second set of rims after trimming them down about 2mm
PostSubject: Re: Bantam II    Tue 11 Oct 2016, 11:14 pm
PostSubject: Re: Bantam II    Wed 12 Oct 2016, 12:02 am
Really good work. Since it's a parts box rod, anything goes, but the front grille is pretty tall. Old style wheels could look fine. Seat idea is different and a welcome addition.
PostSubject: Re: Bantam II    Wed 12 Oct 2016, 12:16 pm
A good tip for blower belts are to use old computer printer belts...they look very realistic. Just cut to sized and glue them on.
PostSubject: Re: Bantam II    Wed 12 Oct 2016, 12:48 pm
PostSubject: Re: Bantam II    Wed 12 Oct 2016, 2:51 pm
Looking good so far. Lines don't appear distracting to me - might add a small gusset to the frame at the bottom like some of the oldies had.
PostSubject: Re: Bantam II    Wed 12 Oct 2016, 4:43 pm
PostSubject: Re: Bantam II    Tue 18 Oct 2016, 12:15 am
Looking good Chris
PostSubject: Re: Bantam II    Tue 18 Oct 2016, 1:46 am
Going to really be cool, when this all comes together.
Bantam II
» DC Bantam 0.75cc
» My Favorite Austin Bantam Roadster ............
» Austin Bantam Altered ........
