 Styrene glue not taking...
PostSubject: Styrene glue not taking...   Sun 03 Jul 2016, 4:48 pm
It is the wallice and grommit A35 van,now someone sent me an Airfix tractor of the same vintage and that was the same.
This bit of sprue was glued together last night and it just fell apart using revelll cement - which is a good glue,so this morn I sanded the bits and reglued them - this is the result...
No go.
PostSubject: Re: Styrene glue not taking...   Sun 03 Jul 2016, 5:18 pm
Might need to use CA and that 2ton epoxy you have.
get some thick cyano on it!
PostSubject: Re: Styrene glue not taking...   Sun 03 Jul 2016, 5:47 pm
CA or try MEK Nige.
PostSubject: Re: Styrene glue not taking...   Sun 03 Jul 2016, 6:09 pm
Good ideas all. I have nothing to add to them.
PostSubject: Re: Styrene glue not taking...   Sun 03 Jul 2016, 9:33 pm
What exactly is MEK,will it melt/bond the plastic Al.The plastic is unusual and only the tractor and the A35 van are affected,no othe Airfix kit/plastic is affected.
PostSubject: Re: Styrene glue not taking...   Sun 03 Jul 2016, 9:43 pm
God knows what kind of plastic those kit are Nigel. Epoxy and clamped together?
PostSubject: Re: Styrene glue not taking...   Sun 03 Jul 2016, 10:02 pm
Just ordered some plastic weld and other stuff,will see..............
PostSubject: Re: Styrene glue not taking...   Sun 03 Jul 2016, 10:12 pm
MEK stands for Methyl Ethyl Keytone Nige.
It's not strictly a glue in the usual sense.
You hold the parts to be 'glued' together then dip a fine brush in the MEK and run it along the seam to be glued. Capillary action draws the MEK between the parts and partially melts the plastic, thereby causing a 'weld' or fusion of the two plastic parts, creating a stronger joint than mechanical glue joints.
You can buy it in quantity off ebay (I bought 5 litres which will see me through I suspect) under Meyhyl Ethyl Keytone or you can by much smaller quantities under brand names such as Plastic Weld.
PostSubject: Re: Styrene glue not taking...   Sun 03 Jul 2016, 10:13 pm
Ya sneaked in while I was posting Nige!! LOL
PostSubject: Re: Styrene glue not taking...   Sun 03 Jul 2016, 10:20 pm
It's so thin it evaporates before your eyes, it does work well on normal kit styrene though.
PostSubject: Re: Styrene glue not taking...   Mon 04 Jul 2016, 12:29 am
I've had issues with 'weird' plastic that was supposed to be styrene but didn't act that way. MEK is great for a lot of plastics but not all. When in doubt I resort to CA or epoxy - BUT there is also this stuff called GS Hypo Cement which is used in jewelry making. It's often used to hold watch crystal faces in bezels and it dries clear. But it is not liquid and is quite expensive.
Anyway, best of luck in working this one out ... and I will mention now that using a staple gun is not recommended, though it is oddly satisfying
Promodmerc
PostSubject: Re: Styrene glue not taking...   Mon 04 Jul 2016, 12:44 am
I bought some of the GS Hypo form Micro-Mart a couple of years ago. It was $7-8 a tube. The problem is it gets a an air bubble in the tube and it keeps flowing out like Teastors tube cement. The tiny needle in the cap is also a pain to see and my blind azz can't see to get it back in the tube.
PostSubject: Re: Styrene glue not taking...   Tue 05 Jul 2016, 8:34 pm
I use MEK almost exclusively. In the rare instance it will not work I, like Curt, use a two part epoxy. It has never failed me.
PostSubject: Re: Styrene glue not taking...   Tue 05 Jul 2016, 8:52 pm
Wot everyone who got here before me said
PostSubject: Re: Styrene glue not taking...   Tue 05 Jul 2016, 8:59 pm
Got some today thanks John.
» Epoxy Putty to fix Styrene/Bakelite?
» Good things can happen when you're taking out the garbage.
» [Tutorial] Taking Photos of your Miniatures (by Hyun)
» Glue-ing tyres
» Gator's Grip Hobby Glue
