 Airbrush 'Tip Dry'
PostSubject: Airbrush 'Tip Dry'   Tue 07 Jun 2016, 8:42 am
I notice a few guys buying quality airbrushes, and whilst I am NO expert Ive found a good cleaning method whilst
working that removed quite a bit of frustration for me.
As I work in the same room as Stevie I very rarely use anything but Acrylic paint. Because they dry so fast,
when airbrushing the paint tends to dry at the tip of the needle causing blockage which I used to remove with
a cotton bud (Q tip) soaked in thinner.
However I discovered that if you dab the tip of the airbrush into a kitchen sponge this removes the dry paint
and quickly allows you to continue working.
PostSubject: Re: Airbrush 'Tip Dry'   Tue 07 Jun 2016, 2:45 pm
Good tip Gary, I use that too, I also use a stiff tooth brush.
PostSubject: Re: Airbrush 'Tip Dry'   Tue 07 Jun 2016, 3:16 pm
Toothbrush is a good idea Curt cheers
PostSubject: Re: Airbrush 'Tip Dry'   Tue 07 Jun 2016, 6:41 pm
PostSubject: Re: Airbrush 'Tip Dry'   Thu 09 Jun 2016, 1:45 am
Second time today I had to admit I never thought of this, but I'm an AB rookie so I can forgive myself more easily, lol. Thanks Gary!
PostSubject: Re: Airbrush 'Tip Dry'   Thu 09 Jun 2016, 8:18 am
Promodmerc
PostSubject: Re: Airbrush 'Tip Dry'   Thu 09 Jun 2016, 7:28 pm
You maybe a rookie but at least you're not an AB virgin like Shay
PostSubject: Re: Airbrush 'Tip Dry'   Sat 23 Jul 2016, 6:40 pm
He's a dinosaur,......
PostSubject: Re: Airbrush 'Tip Dry'   Sun 24 Jul 2016, 3:08 pm
better than being a gombeen.
PostSubject: Re: Airbrush 'Tip Dry'   Sun 24 Jul 2016, 7:48 pm
PostSubject: Re: Airbrush 'Tip Dry'   Tue 26 Jul 2016, 1:29 am
That's a good tip Gary. Recently had problems and this would have solved it. Thanks.
PostSubject: Re: Airbrush 'Tip Dry'   Tue 26 Jul 2016, 8:51 am
Airbrush 'Tip Dry'
» airbrush from ebay
» A simple tool and airbrush holder
» Chassis painting
» Heinkel He177 A-02
» Silent compressor
