 Bristol F2.B "Crocodile"
PostSubject: Re: Bristol F2.B "Crocodile"   Fri 27 May 2016, 11:05 am
Man, that is some great detail !!!!!
PostSubject: Re: Bristol F2.B "Crocodile"   Fri 27 May 2016, 12:17 pm
Very cool Cole, best of luck with the process. I am really looking forward to seeing what's coming next.
PostSubject: Re: Bristol F2.B "Crocodile"   Fri 27 May 2016, 2:25 pm
Nice masking, Cole. Are all those placed individually?
PostSubject: Re: Bristol F2.B "Crocodile"   Sat 28 May 2016, 5:37 am
The interior is fantastic, I especially love the wicker seat. And the masking for the wings looks like eyestrain and retinal afterimages on the wholesale scale, lol. Looking forward to what comes next
PostSubject: Re: Bristol F2.B "Crocodile"   Sat 28 May 2016, 2:10 pm
Wicker seat and interior make this one fine small scale model. Re: taping off squares, what's your method in how much to press down the tape to prevent bleeding under? How sticky is the tape?
PostSubject: Re: Bristol F2.B "Crocodile"   Tue 31 May 2016, 10:57 am
The engine such as it is. Not much will be visible after assembly. The wings and tail have been masked and will be painted tomorrow.
PostSubject: Re: Bristol F2.B "Crocodile"   Tue 31 May 2016, 11:21 am
Nice work Cole, are there not decals available for the pattern, although greater satisfaction in painting it.
PostSubject: Re: Bristol F2.B "Crocodile"   Tue 31 May 2016, 4:42 pm
Though it may be sparse what there is of the engine looks good!
PostSubject: Re: Bristol F2.B "Crocodile"   Wed 01 Jun 2016, 12:33 pm
Thanks everyone.
Mike and Harron: The masks were all placed individually. I simply pressed each square in place after placing it. Then I let it sit for a day before painting. The base coat is white, the top coat red. Some modellers apply a clear coat before applying the top coat. In this instance, I did not. The Eduard tape is quite sticky. When applying the red top coat I sprayed multiple light coats. My reasoning is that will allow the paint to dry quickly between coats and minimize bleed-through. Also, the Eduard instructions provided an excellent starting point for placing the masks.
Gary: I had no idea that decals may be available! For me personally, the masking job truly makes this a pastime, one that I enjoyed.
As for the results, you be the judge. But even after all this, I still made two glaring errors, which I will correct forthwith.
PostSubject: Re: Bristol F2.B "Crocodile"   Wed 01 Jun 2016, 12:55 pm
Great work Cole, this rocks.
PostSubject: Re: Bristol F2.B "Crocodile"   Wed 01 Jun 2016, 1:25 pm
Cole, I thought that you may prefer to mask and paint, much more creative satisfaction.
A superb result and Im enjoying this coming together.
PostSubject: Re: Bristol F2.B "Crocodile"   Wed 01 Jun 2016, 2:28 pm
Great job, Cole. The painted look is much better than decals, in that there's no 'see-through' as seen with most decals.
PostSubject: Re: Bristol F2.B "Crocodile"   Thu 02 Jun 2016, 3:13 am
Excellent result! Definitely worth the effort involved, it looks fantastic
PostSubject: Re: Bristol F2.B "Crocodile"   Thu 02 Jun 2016, 8:49 am
Anyone for checkers?
Superb job Cole.
PostSubject: Re: Bristol F2.B "Crocodile"   Thu 02 Jun 2016, 3:12 pm
Really crisp lines on the squares. Thanx for the advice on spraying light coats. It also prevents paint buildup along tape edges and makes removing tape easier. Truly a beautiful paint job on a superb small scale (and thereby more challenging) model. She is something!
PostSubject: Re: Bristol F2.B "Crocodile"   Fri 03 Jun 2016, 8:52 am
Cheers gents. The paint and decals are complete for the wings and tail.
PostSubject: Re: Bristol F2.B "Crocodile"   Fri 03 Jun 2016, 9:14 am
They are stunning with the roundels on Cole. Great progress.
PostSubject: Re: Bristol F2.B "Crocodile"   Fri 03 Jun 2016, 9:22 am
Very nicely done Cole, the roundels make more of a difference than you'd think.
PostSubject: Re: Bristol F2.B "Crocodile"   Fri 03 Jun 2016, 1:54 pm
Super job, Cole. A great paint scheme there.
PostSubject: Re: Bristol F2.B "Crocodile"   Fri 03 Jun 2016, 7:13 pm
Should've been "squaredels."
PostSubject: Re: Bristol F2.B "Crocodile"   Fri 03 Jun 2016, 8:39 pm
PostSubject: Re: Bristol F2.B "Crocodile"   Sat 04 Jun 2016, 5:50 pm
Nice work....
PostSubject: Re: Bristol F2.B "Crocodile"   Sat 04 Jun 2016, 7:14 pm
Fantastic work on the cockpit Cole.
PostSubject: Re: Bristol F2.B "Crocodile"   Sun 05 Jun 2016, 2:11 am
Gorgeous! The result is stunning
PostSubject: Re: Bristol F2.B "Crocodile"   Sun 12 Jun 2016, 10:41 am
Thanks everyone. I hadn't paid attention till now, but the manner in which the lower wing is joined to the fuselage seems rather unique. The first attachment points were aligned without any trouble. Now it's time to start painting the fuselage.
