 Community Build #14 Pick em up Trucks
Go to page : 1, 2, 3, 4, 5, 6, 7  Next
PostSubject: Community Build #14 Pick em up Trucks   Sat 30 Apr 2016, 7:34 am
That's right, the subject is "Pickup". Starts May first and runs through the end of June. Open ended as before, just get it started before the end of June to qualify. Check out the rules in the discussion thread and HAVE FUN !!!
PostSubject: Re: Community Build #14 Pick em up Trucks   Sat 30 Apr 2016, 8:13 am
well, im doing this.............
..................but not for a couple of weeks cos i want to do a plane first.....i hate doing two kits of the same genre one after the other
PostSubject: Re: Community Build #14 Pick em up Trucks   Tue 03 May 2016, 5:47 pm
Hi all,
Well this is going to be my very first group build, this is what I am starting with, it's going to be a proto-type...: -
I have two the same, this is the better one of the two, there are parts missing from each kit, but enough to make something with them...
Box Art...: -
Bits in box...: -
PostSubject: Re: Community Build #14 Pick em up Trucks   Thu 05 May 2016, 6:48 pm
Hopefully get out of my current rut with this one.
Plan to build it pretty much stock.
PostSubject: Re: Community Build #14 Pick em up Trucks   Sat 07 May 2016, 10:21 am
I like your choice Paul....... Top Gear's toughest truck in the world. Going to bang it up?
Andy..... that will be an interesting conversion to say the least.
Mike.... another great choice..... what are your plans for it?
It's going to take quite a while before my new hobby room is up and running and the little 1:72 plane I'm doing will be finished p.d.q. so I'm going to pitch in with this one:
Been wanting to do an Elkie for long enough so now is a good excuse. Not sure if I will use the decals or not and still undecided on paint colour. I MAY decide to lower the suspension though.
PostSubject: Re: Community Build #14 Pick em up Trucks   Sun 08 May 2016, 10:30 am
nope, its far too nice a kit to do that, im taking a liking to Aoshima...................thing is i have no idea what colour to do it
PostSubject: Re: Community Build #14 Pick em up Trucks   Sun 08 May 2016, 10:42 am
lol...was only a few days ago i watched the Roadkill episode on the El Camino
PostSubject: Re: Community Build #14 Pick em up Trucks   Sun 08 May 2016, 11:06 am
A pick up GB...I really have to keep a better eye on these things...entry by end of June...hmmm
I will be keeping this on my radar, there's already some nice projects here.
Mike - I built the 41 Chevy and it is a very nice kit but just watch for the hood fit. I don't recall if I had to move the firewall forward to fix the issue. Sorry it's been awhile.
PostSubject: Re: Community Build #14 Pick em up Trucks   Sun 08 May 2016, 4:32 pm
A nice Pink would look good...
PostSubject: Re: Community Build #14 Pick em up Trucks   Sun 08 May 2016, 4:52 pm
Lots of great ideas showing up already.
PostSubject: Re: Community Build #14 Pick em up Trucks   Sun 08 May 2016, 5:28 pm
shut up, you lol
i did suggest white but swmbo pulled a disapproving face lol
PostSubject: Re: Community Build #14 Pick em up Trucks   Sun 08 May 2016, 6:36 pm
beowulf wrote:
shut up, you lol
Did you emphasize that it would be Wimbledon white? Then you will get this reaction.
PostSubject: Re: Community Build #14 Pick em up Trucks   Sun 08 May 2016, 7:31 pm
My attempt will consist of using some of these components ... undecided on the wheels untill it's "sort of" together, then i'll faff with the suspension so they look decent (ish)
PostSubject: Re: Community Build #14 Pick em up Trucks   Sun 08 May 2016, 9:23 pm
might be a couple of days before i can make a start but heres the sprue shots
PostSubject: Re: Community Build #14 Pick em up Trucks   Thu 12 May 2016, 12:27 am
Hmmm a Beetle pick up Colin. Interesting.
OK I made a start and the first order of the day was to 'git her down' a bit.
For the front I cut off the spindles and pinned them back on higher up:
For the rear, I simply cut two coils of the springs:
This makes the dif. sit at an angle, which would still work but would not be good practice..... do I care?.... do I heck!! LOL
The drop at each end is approx a scale 85mm (3.5")
This is the stock stance:
And this is where I have her now:
The rear end is as low as it will go but the front end will go down another 1mm (scale 1") when the chassis is glued in.
PostSubject: Re: Community Build #14 Pick em up Trucks   Thu 12 May 2016, 2:31 am
Awesome stance Al !!
PostSubject: Re: Community Build #14 Pick em up Trucks   Thu 12 May 2016, 5:16 am
Stance looks good Al.
PostSubject: Re: Community Build #14 Pick em up Trucks   Thu 12 May 2016, 8:31 pm
Al:  Nice stance for an oldie.
Got a couple of things done here.
Since the last truck I did was red upper with a black lower scheme, I decided this should be blue with black.  I had some Boyd's Paciffic Blue laying around, so that was it.
Engine is painted and wired.  Just a little more to go.
Frame pieces are together and it's been tested for sitting flatly on 4 wheels.
That's all for now.
PostSubject: Re: Community Build #14 Pick em up Trucks   Fri 13 May 2016, 4:03 am
That's a nice blue. I'm looking forward to see what you will do with the black.
PostSubject: Re: Community Build #14 Pick em up Trucks   Fri 13 May 2016, 9:16 am
I agree with Denis...... the blue looks very nice. I'm assuming you will be doing the wings and running boards with the black. If so, that will be a nice combo.
PostSubject: Re: Community Build #14 Pick em up Trucks   Mon 16 May 2016, 9:57 pm
A little more done.
Cut out the aluminum strips of the decal and applied just the wood slats.
The engine detail is done.  Added fuel and vacuum lines.
Handpainted the whitewalls since decal whitewalls were more like 60's style.
But the exhaust pipe doesn't reach to the manifold! Have to fix.
Moving along,
PostSubject: Re: Community Build #14 Pick em up Trucks   Wed 18 May 2016, 6:25 am
Nice call on cutting out the aluminum strips I didn't use the decals because of it and the same with the white walls provided. The engine looks good in gray. I don't remember having an issue with the exhaust pip and the manifold fitting, maybe a bend in the exhaust will fix that. The decals are really going to complete the wheel nicely. Keep it coming Mike!
PostSubject: Re: Community Build #14 Pick em up Trucks   Wed 18 May 2016, 2:28 pm
Nice work so far from everyone who's started ....
I thought i'd best give myself a kick up the backside and got the body out to try and get the imagineering to bloom.
found some pick up bed sides in the bits box ...
and, well, would ya look at that !!!!!
How close is that for size on first eyeball??
TIDY !!!
PostSubject: Re: Community Build #14 Pick em up Trucks   Wed 18 May 2016, 2:42 pm
Looks like a great fit, Colin. The VW rear fenderline should fit well on it.
PostSubject: Re: Community Build #14 Pick em up Trucks   Wed 18 May 2016, 3:50 pm
a long time ago when i was into building kit cars i remember a body kit to turn a beetle into a pick up, was quite taken with it......must see if i can find some pics
*edit* just googled it and cant believe how many there are out there.....cant find the one i was interested in though
Page 1 of 7Go to page : 1, 2, 3, 4, 5, 6, 7  Next
» Community Build #10 'Trucks'
