 Geezer's Garage rebuild
PostSubject: Geezer's Garage rebuild   Tue 26 Apr 2016, 11:58 am
This first photo shows taking the werck out side on the picnic table where I had room to see if I could remove the remaining stuff with minimal damage.
Managed to get stuff removed with minimal damage.
Inside my 'shop', this is a piece of old 1" thick building foam. 24" X 36", on top of an art table next to my bench, where I will try to rebuild it.
PostSubject: Re: Geezer's Garage rebuild   Tue 26 Apr 2016, 12:08 pm
Hi Mr G,
I'm in Sir... popcorn
PostSubject: Re: Geezer's Garage rebuild   Tue 26 Apr 2016, 1:59 pm
Proper tools there Clay .............
Cant beat a hammer and chisel !!!!!
looking forward to the resto updates mate
PostSubject: Re: Geezer's Garage rebuild   Tue 26 Apr 2016, 2:22 pm
Go for it Clay. With your talent you will have it fixed to the point that no one will ever know you had to do a rebuild.
PostSubject: Re: Geezer's Garage rebuild   Tue 26 Apr 2016, 6:33 pm
I am so glad to see you rebuilding this dio. It has always been high on my list of favorites. I would hate to see it scraped.
PostSubject: Re: Geezer's Garage rebuild   Wed 27 Apr 2016, 8:37 pm
The garage is getting a new back wall. This is a piece of 5/8" construction foam. It has been laying around for years. Just big enough with a minor trimming. It won't be warping like the old foamboard did.
A character flaw, I guess, but I usually save tag ends of stuff. Comes in handy some times.
PostSubject: Re: Geezer's Garage rebuild   Wed 27 Apr 2016, 9:09 pm
Nothing wrong with saving leftover scraps. Re: hammer and chisel, they come in handy during gator season too!
PostSubject: Re: Geezer's Garage rebuild   Wed 27 Apr 2016, 10:03 pm
Glad to see you rebuilding this, I always enjoy seeing your builds pictured in and in front of this Dio. The first time I saw it was when you built that wild squirrel head car.
PostSubject: Re: Geezer's Garage rebuild   Wed 27 Apr 2016, 10:52 pm
Go to it Clay.
PostSubject: Re: Geezer's Garage rebuild   Thu 28 Apr 2016, 5:33 pm
PostSubject: Re: Geezer's Garage rebuild   Thu 28 Apr 2016, 6:02 pm
Definitely nothing wrong with saving scrap bits of anything Clay ... i do it all the time ... just in case .
It's what my big MASH diorama is made from.... bits, scraps, odds and sods ...
Keep the updates coming pal !!
PostSubject: Re: Geezer's Garage rebuild   Fri 29 Apr 2016, 3:11 pm
Putting some windows in the back wall. Might show some back ground light thru the open front door. Back side shown here, beveled to eliminate the thick wall showing,
PostSubject: Re: Geezer's Garage rebuild   Fri 29 Apr 2016, 3:36 pm
This is great. We all could use a dio/display for our built and WIP shots. Your work here is a real inspiration Clay.
PostSubject: Re: Geezer's Garage rebuild   Fri 29 Apr 2016, 5:33 pm
PostSubject: Re: Geezer's Garage rebuild   Fri 29 Apr 2016, 7:53 pm
Great looking update.
PostSubject: Re: Geezer's Garage rebuild   Fri 29 Apr 2016, 9:42 pm
Addressing some of the damage, the shop truck had taken a hit. Might need it to chase some parts.
A little history, This model was built in 2006. In a moment of brilliant inspiration, I had made a set of 6 carb scoops out of elbow macaroni. Checking it out several months later, out in the studio shed, I discovered that some vermin had eaten all of the macaroni. I later got some plastic scoops to replace them.
PostSubject: Re: Geezer's Garage rebuild   Fri 29 Apr 2016, 9:48 pm
Too funny. So is that where the squirrel skull came from for that wild build, you caught the little bugger?
PostSubject: Re: Geezer's Garage rebuild   Sun 01 May 2016, 11:50 am
Next is the old beater I had setting in front of the garage with a for sale sign.
Story on this one is that it's the one that cured me from using salt to create weathering effects ( I use fine, filtered actual dirt now). I had this looking pretty good, but again, out in the shed studio, mother nature threw me a curve ball. After some time had elapsed I found a thin layer of moisture over certain portions and whitish residue had formed. Florida humidity had saturated all of the salt that I had used. Model was never the same.
PostSubject: Re: Geezer's Garage rebuild   Sun 01 May 2016, 2:37 pm
Between weather and vermin you have had your problems Clay. Both of those trucks though have the potential to be outstanding again. popcorn popcorn
PostSubject: Re: Geezer's Garage rebuild   Sun 01 May 2016, 2:55 pm
Do you ever use sand in place of salt?
PostSubject: Re: Geezer's Garage rebuild   Sun 01 May 2016, 10:17 pm
Yes I do, exclusively. I have a couple of batches of different sifted coarsenesses.I even have a can with it filtered thru a paint strainer, for fine textured surface rust.
PostSubject: Re: Geezer's Garage rebuild   Sun 01 May 2016, 10:31 pm
Nice to get a little history behind the scenes. You will get the garage back up and running in no time.
PostSubject: Re: Geezer's Garage rebuild   Mon 02 May 2016, 2:31 am
This 40 Ford junker was the first model built specifically for the garage. Built while the garage was under construction.
Rebuild will have blacktop out front !
PostSubject: Re: Geezer's Garage rebuild   Mon 02 May 2016, 2:41 am
Thanks for sharing your sand technique Clay. I am really digging this project.
PostSubject: Re: Geezer's Garage rebuild   Mon 02 May 2016, 6:00 pm
WOW!!!!! Pavement, Really stepping up now. Looks great Clay.
» Link to Dynaco SCA-35 rebuild article - good information
» FM-3 rebuild
» Scrapbooking garage sale - Arana Hills, Brisbane
» Mark III Rebuild
» Just Completed My ST70 Rebuild
