 Community Build #12 "Race Cars"
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Community Build #12 "Race Cars" - Page 5 Empty
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeTue 26 Jan 2016, 6:33 pm
Beautiful seats, Cole.
As for me, I guess I'm out of this one for awhile.  My old demons of decaling have struck me again.  The nose decal is a one piece wraparound deal.  I used very warm water to apply it.  The clear areas showed the very milky white adhesive beneath.  The compound curvey wraparound didn't work quite well, though.  To fix it I tried for about 40 minutes applying Solvaset, working out the wrinkles, apply more Solvaset, work out more wrinkles, over and over.  But the wrinkles just kept moving elsewhere.
Community Build #12 "Race Cars" - Page 5 Lotus-21
Community Build #12 "Race Cars" - Page 5 Lotus-22
I finally threw in the towel.  The yellow wasn't as dense as I liked anyway.  I'll look for aftermarket decals somewhere.  In removing the decal with water and finger rubbing, the lacquer clearcoat started to come up also.  So, there's a lot to be done to fix this one.
Community Build #12 "Race Cars" - Page 5 Lotus-23
The new year is certainly not starting off well for me.  Maybe back to the Felixstowe, now.
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeTue 26 Jan 2016, 11:23 pm
Sure sorry about the decal problem.  If the paint, lacquer should dry fast, but it doesn't hurt to wait extra time for it to dry completely.  There are some good vids on Y.T. on decaling. sometimes with wrap around decals it's best to cut into half pieces.  You're correct on the see-thru on light decals over dark surfaces too.
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeWed 27 Jan 2016, 1:09 am
Man it's a real bummer when that happens Mike.
Never fear though, replacements are available although you will need to paint the stripe:
Rep Decs
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeWed 27 Jan 2016, 4:59 pm
Not if he gets the CORRECT ones from Indy Cals.... Community Build #12 "Race Cars" - Page 5 3647921533 Community Build #12 "Race Cars" - Page 5 2704104872
http://www.indycals.net/decals/indy/63lotus29.html
They have an up grade kit too that has the correct nose cone, tires, thin wind screen and decals.
http://www.indycals.net/parts/indyparts/63lotus29upgrade.html
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeWed 27 Jan 2016, 5:28 pm
How on Earth did you find those Mitch? I looked all over Indycals site as I was sure they did them.
The upgrade kit looks good but isn't available at the moment.
May need to order those decals myself!!
Mike, decals aside what do you think of the rest of the kit?
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeWed 27 Jan 2016, 6:22 pm
Bummer, glad you found the after market ones. Community Build #12 "Race Cars" - Page 5 1705482731
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeWed 27 Jan 2016, 7:49 pm
Completed the interior and wired the electronics boxes.
I also added roll cage padding by using small bore silicone tubing and replicated cable ties with fishing line.
Community Build #12 "Race Cars" - Page 5 02112
Community Build #12 "Race Cars" - Page 5 02210
Community Build #12 "Race Cars" - Page 5 02310
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeWed 27 Jan 2016, 9:27 pm
Awesome work Al. How did you do the electric wire connectors?
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeWed 27 Jan 2016, 11:30 pm
Mitch.... they are molded into the electronics boxes. I simply drilled them, glued in the wires and painted the connectors.
For me, painting rubber window surrounds is a daunting task. Recently, Tamiya brought out some new 'bendable' tape and I wondered how good it was. Time to find out I guess. Community Build #12 "Race Cars" - Page 5 1578238153
Community Build #12 "Race Cars" - Page 5 02410
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeThu 28 Jan 2016, 2:06 am
AL, Mitch: Already found the Indycals site and they're on their way, along with some new John Zink decals for a very old stalled WIP.
Al: Great looking interior work.
The MPC kit isn't your usual MPC quality, it's not bad. I like the fact that they provide pin attachment for the engine cowl and body top that allows display, but there's minimal detail underneath. The instructions leave a bit to be desired, though. What they label as front wheels are really the rears. Also, attachment points could be much clearer, so test fit everything.
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeThu 28 Jan 2016, 5:07 am
Nice interior work Cole and Al.
Bummer about those decals Mike.  The Indycals should do the trick though.
Started (and finished) the decals tonite.
Community Build #12 "Race Cars" - Page 5 12619-th
Mounted the body to the chassis
Community Build #12 "Race Cars" - Page 5 12620-th
Got the front suspension on
Community Build #12 "Race Cars" - Page 5 12621-th
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeThu 28 Jan 2016, 12:39 pm
Nice work on the Cals!
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeThu 28 Jan 2016, 7:32 pm
Well that didn't work out too good. Despite clear coating first, I still got 'creep'. So it's taking a bath right now.!! Community Build #12 "Race Cars" - Page 5 1757741307 Community Build #12 "Race Cars" - Page 5 1757741307
The decals are looking good Paul.
I have this kit too, so what were the decals like to work with?
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeThu 28 Jan 2016, 9:36 pm
Al, the decals are OK. They are work-able. I was going to ask about the new tape and how well it sealed, but you seem to have answered that question.
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeThu 28 Jan 2016, 10:20 pm
Don't write off that tape yet Paul.
I think much of it has to do with me. Since the flood, my heart and soul aren't in it as much as they used to be. Once we are able to move back in downstairs and I have my room and new bench set up, that will return.
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeFri 29 Jan 2016, 4:59 am
I can certainly understand that Al.
Since there is a model show this Saturday, I did the finishing touches and will call this done. I will post more pics of the finished car when I get my camera.  These were taken with my smart phone.
Community Build #12 "Race Cars" - Page 5 12624-th
Community Build #12 "Race Cars" - Page 5 12623-th
Community Build #12 "Race Cars" - Page 5 12622-th
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeFri 29 Jan 2016, 5:30 am
Beautiful work Paul !
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeFri 29 Jan 2016, 3:09 pm
Ferrari looks super!  You really ARE productive as well as skilled.  The base looks interesting too.
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeFri 29 Jan 2016, 4:24 pm
Ferrari looks fabulous Paul. Very nice workmanship!
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeFri 29 Jan 2016, 5:33 pm
Great looking Ferrari, Paul.
Sorry to hear about the 'creep', Al. I assume it's on the window black.
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeFri 29 Jan 2016, 5:54 pm
Gorgeous Paul!
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeFri 29 Jan 2016, 7:36 pm
Harron....the base is my modeling buddies....I'm using it as a flat plate to make sure the wheels all touch
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeSat 30 Jan 2016, 8:22 am
Fine work on the Ferrari Paul. I never realized the rear spoilers were offset like that.
I was curious to see how twenty year old wet transfers worked. I will have to do a better job of trimming for the remaining transfers. Even so, I really like the Michelin logo for these tires.
Community Build #12 "Race Cars" - Page 5 Dscn0711
PostSubject: Re: Community Build #12 "Race Cars"   Community Build #12 "Race Cars" - Page 5 Icon_minitimeSat 30 Jan 2016, 2:52 pm
Very nice tires, Cole.
Page 5 of 10Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
» Help: Need Thimble Drome quarter midget race car parts
» 1940 Ford Jalopy Dirt Racer
» My Monte Carlo SS build
» Junkyards with newer cars?
