Honda RC211v 2006 - Stoner version..... Long build
HI guys,
Here's my next build, its going to be a long one because of the stuff I have for it.
It will end up being the most detailed build I have tried as they are normally box stock whereas with this I have a couple of extra's which I have never tried before, so here goes with the box art
Sprue shots
Extra's, Carbon decal sheet, Tamiya fork set and the Hobby design chain set
Now onto the build, so far I have filled the front fender and primed a few pieces and thats it for now.
Thanks for looking
Sprue shots
Thanks for looking
Re: Honda RC211v 2006 - Stoner version..... Long build
Hi Ash,
You've got my attention Sir, so I'm in...
that lot should keep you busy, young padawan
I'm in for this one ... Looks a nice detailed kit
So I managed to spend a couple of hours on the bike tonight and having never tried anything photo etched before I decided to give the chain a go... How long does it take to get anywhere with these things??
Anyway here are the pics of my 2 hours hard graft, sorry pics are a little blurry, its from my Iphone
Thanks for looking
Thanks for looking
Man those PE parts looks so good. The chain looks like a real challenge.
Amazing detail in that p/e set!
I see the two part chain and the links and the sprockets, but whats in the little bag with 10 zillion little parts?
Do you need them to pin the chain together Ash?
Cheers guys, Shay the zillion little parts are 116 spacers which sit between the 2 sides of the chain, then the gold links sit on top of the chain sides (with the spacers passing through the side and then into those) then the sprockets in the centre.. Holy ....! That's gonna be a painful task putting those together.
There are also some resin nuts which sit within the large sprocket.
You need to cut the chain at some point so it will go through the swing arm, that will be the hard point because it will need bending and then re straightening.. GULP!
Umm no comment! Lol
Hi Ash,
This looks waaaaay fiddly, best of luck to you Sir, but I'm sure you will conquer it...
Question if I may, how do you stick PE together...
Morning Andy
Your not wrong mate, its a bloomin nightmare this tiny stuff and I keep dropping parts on the floor.
My method has been superglue, place a blob on a plastic bag laid flat then dab a cocktail stick in it.
place dot of glue on largest piece to be glued then carefully sit the adjoining piece to it and apply a little pressure.
Its tedious and really slow going but at the end it looks ok though its a shame you need to paint the parts after as they look cool silver imo.
There's another thread about glues and D mentioned tin foil and pringles lid as a palette to place the glue onto. Now that will be my new method as bags are now 5p and becoming rare in my household
Â
Â
I can only imagine the patience required to do this. I love it!!! Maybe another bike is in order for the future.
You have the patience D and I'm sure you have a kit in your stash which has a p/e set available for it.
Next for me is the zxrr ninja with the top studio detail set I have for it. That's all about connectors and p/e stuff. With resin parts but a wise owl once told me. 'Master one thing at a time and don't try to do everything all at once or you will fail'. He wasn't wrong this far!
Now off to build more chain.
Update later.
Update later.
So I built some more chain but i was disappointed at what happened so its left to one side till I can work out how to straighten it out.. No pics of that yet but I managed to spend a few hours on the bike today so here's it so far
Wheels with tyres, chart called for black, not gloss or flat or metallic just black, well I dont have any just black so I used Hiroboy black gloss without the clear coat (which it says you should use) and im happy with it so that's how they are staying
Front fender painted with a Tamiya spray and then 2k clear over the top.
First time I have managed to mask and paint with no bleed through.. RESULT!!
Engine painted with clutch added from Tamiya fork set
Decals next
I have tried the micro sol/set stuff before and not been very good, I think I am learning how to use it properly now, unfortunately I messed up the lower cowl before I managed to work it out.
Lower cowl
There's also a seem line down it but you wont see that once its on its wheels
The rest so far
The carbon fibre ones are from the studio 27 decal sheet, each piece is split up, the clutch cover had 3 parts to it and the inside of the front cowl is shown below.
Thats it for now, where the decals split I will touch up before I clear over the top but that will be after christmas.
Decals next
Lower cowl
The rest so far
Hi Ash,
These are looking awesome...
Cheers buddy!!
Another update, finished the decals and 2k'd over them. may polish it yet, not decided
Painted the exhaust and tried some heat staining, this time I actually got a picture from the internet unfortunately I can only do so much even with a reference picture but I did fit a spring to it, just like the pic I found.
Almost finished the engine and did my first ever dry brushing, its the honda logo on the rocker cover, its a lot easier this way then trying to paint it like I have done in the past
Hope you like it, C & C welcome and tips are good too.
Man, great detail work!
Cheers Bruce, thanks for looking in
Thats some fancy work you're doing there A5h. Nothing else to comment with really apart from outstanding work! As i've always thought and followed that code myself, it's the attention to the details which makes a great build and here we have one. Great stuff.
Thanks very much D, I appreciate it
Loving it !!!!! The engine rocks and that heating effect on the exhaust is perfect, not over done at all.
» Tamiya RC211V 06 Stoner
» Honda RC211V X 4
» Tamiya RC211v Telefonica
» 2006 Kawasaki ZZR1400
» Wanted Tamiya Rc211v 03 in Telefonica livery
» Honda RC211V X 4
