 Lindberg Stutz
PostSubject: Re: Lindberg Stutz   Sat 12 Dec 2015, 5:29 pm
PostSubject: Re: Lindberg Stutz   Sat 12 Dec 2015, 6:43 pm
Swing back to the engine this morning. Kinda glad I was able to permanently shoehorn the  water pump and the starter junk in place, and still be able to set the engine in and out between the frame mounting brackets.
PostSubject: Re: Lindberg Stutz   Sun 13 Dec 2015, 5:49 pm
Clay, the Fuman Mercer distributor is 1/2" tall by 1/4" thick by ~11/16" long (not counting the mounting tab. Hope this info isn't too late for you. I'll send some photos of the assembled unit shortly.
Are the spindles on your axle plastic tubing and if so are the axles from the kit? Great job by the way.
PostSubject: Re: Lindberg Stutz   Sun 13 Dec 2015, 7:37 pm
Here's pictures of the distributor and with it attached to the timing case. Some are a bit fuzzy. Hope they help.
PostSubject: Re: Lindberg Stutz   Mon 14 Dec 2015, 11:45 am
Thanks, Dave. I have already scratched up a distributor of sorts My imagineered fan pulley mount is a little different though. wanting to get some paint on the engine and parts before I continue.
Spindles are the kits. I drilled through, and then separated them from the axle ends.
PostSubject: Re: Lindberg Stutz   Tue 15 Dec 2015, 10:16 pm
Linkage to the pose-able steering.
PostSubject: Re: Lindberg Stutz   Wed 16 Dec 2015, 4:59 pm
PostSubject: Re: Lindberg Stutz   Thu 17 Dec 2015, 2:13 pm
Engine starting to shape up pretty good.
PostSubject: Re: Lindberg Stutz   Thu 17 Dec 2015, 2:19 pm
Looks great Clay. The finish on the engine is spot on.
PostSubject: Re: Lindberg Stutz   Thu 17 Dec 2015, 4:17 pm
Engine looks great Clay. Keep it up!!
PostSubject: Re: Lindberg Stutz   Fri 18 Dec 2015, 5:26 pm
PostSubject: Re: Lindberg Stutz   Sat 19 Dec 2015, 12:54 pm
Man you do nice work.
PostSubject: Re: Lindberg Stutz   Mon 21 Dec 2015, 9:40 pm
Plugs wired and routed to the distributor and the priming valves installed.
The plugs and valves were made from stuff saved over from a 20+ year old model ship build.
Plugs from white metal railing risers and the primers made from brass rope pins.
(mind blanked  - belaying pins ?)
PostSubject: Re: Lindberg Stutz   Mon 21 Dec 2015, 9:59 pm
PostSubject: Re: Lindberg Stutz   Tue 22 Dec 2015, 4:31 pm
Sweet Clay, I never even thought of doing this stuff when I built mine.
PostSubject: Re: Lindberg Stutz   Tue 22 Dec 2015, 9:24 pm
Cool looking engine, Clay.
PostSubject: Re: Lindberg Stutz   Wed 23 Dec 2015, 8:05 am
The engine and rear end are now mounted on the frame.
PostSubject: Re: Lindberg Stutz   Wed 23 Dec 2015, 10:43 am
This is all looking great Clay, particularly the engine.
What diameter wire did you use for the valve springs and where did you get it?
PostSubject: Re: Lindberg Stutz   Wed 23 Dec 2015, 11:08 am
Quality work on the engine, Clay. Really looks the business, comparared to the blob of plastic it was.
PostSubject: Re: Lindberg Stutz   Wed 23 Dec 2015, 1:37 pm
PostSubject: Re: Lindberg Stutz   Thu 24 Dec 2015, 12:45 pm
You got the engine wiring and detail right!  I did a 1/25 Stutz and included brass and copper foil (candy wrappings) to make it good.  Then the body paint went South and I lost interest.  Glad you're doing well with yours!
PostSubject: Re: Lindberg Stutz   Fri 25 Dec 2015, 12:14 am
Up on wheels (not completely painted yet) and detailing the dash/firewall.
A small tank of some sort is being imagineered as a steering box. It'll be almost completely hidden behind the cowl, but it gives me something else to add. Starting to look pretty good with the cowl in place :o)
PostSubject: Re: Lindberg Stutz   Fri 25 Dec 2015, 12:32 am
Hi Mr G,
This is look very sweet so far Sir, that engine looks brilliant...
PostSubject: Re: Lindberg Stutz   Fri 25 Dec 2015, 12:40 am
Looking good, Clay.
PostSubject: Re: Lindberg Stutz   Fri 25 Dec 2015, 12:47 am
Wow Clay! That is looking the part.
Lindberg Stutz
» Lindberg Stutz
» Lindberg Stutz
» Lindberg 1914 Stutz Bearcat
» Stig Lindberg "Pottery" Fabric
» Stig Lindberg Table for Nordiska Kompaniet
