 1962 Ferrari 250 GTO Penske Mecum Racer
PostSubject: 1962 Ferrari 250 GTO Penske Mecum Racer    Sun 29 Nov 2015, 4:55 am
I started this kit many many years ago, I want to finish it up.
I was given a PE wire wheel set and I bought some HRM tires.
I was going to use the kit velocity stacks but they look awful, so does anyone know where to get some metal ones?
They're tiny...
I used some brass tube to make the spark plug wire loom and some wire insulation painted yellow for the flexible part of the fuel line
PostSubject: Re: 1962 Ferrari 250 GTO Penske Mecum Racer    Sun 29 Nov 2015, 6:35 am
Re velocity stacks, how about some pop rivets? Or these, I found a heap of these 20 years ago, and
they've done me for short stacks since then.
You're welcome to them if you're interested.
PostSubject: Re: 1962 Ferrari 250 GTO Penske Mecum Racer    Sun 29 Nov 2015, 6:40 pm
Nice subject and a good job on it.
PostSubject: Re: 1962 Ferrari 250 GTO Penske Mecum Racer    Mon 07 Dec 2015, 1:55 pm
I worked on this one a lot this weekend.
I have the engine prepped to accept the new velocity stacks from Mike's Ferrari Parts Emporium
I cut some brass tube and drilled out the carbs to put the tube in. This way the stacks have something to attach to.
I polished through the clear on the right rear quarter. Oh well I am not going to try and fix it.
This kit has a lot of parts and moving suspension but it is very fragile. I have had to replace two of the axle/wheel mounts with brass because the plastic broke off or was too short. I have had to drill the door hinges and glue wire inside as pins because they broke.
The sliding side widows work but I broke one trying to trim the sprue nub off. I made a new on out of the sheet clear I have. It looks better than the kit one that I glued the lever to. I am going to take the kit one back out and replace it acetate to get rid of the fogging.
I am not happy with the ride height but I can't do too much more to fix it. I already installed the front spindles upside down to lower the front about an 1/8"
If I ever build this kit again I am going to thin out the front finders around the side vents and work on raising the rear wheel arches just a little so that the whole back can be lowered without the rear wheel being too far up into the opening.
Just a bit of touch up and clean up, velocity stacks and I am calling this 6 year build done...
I also got tired of Photobuckets slow site and am trying Fotki...
Hosted on Fotki
Hosted on Fotki
Hosted on Fotki
http://media.fotki.com/1_p,rrkdrwsgdfdqdggxsqbsktktstrtg,vi/rtbksqstbxrftdkdrkbxkkrqfkbdt/6/3685306/13876500/DSC00091-vi.jpg
Hosted on Fotki
Hosted on Fotkihttp://media.fotki.com/1_p,rrkdrwsgdqksfkkxsqbsktktstrtg,vi/sbqwbwgbdxwttsttqfsxrkgkfkkgs/6/3685306/13876500/DSC00090-vi.jpg
[URL=http://public.fotki.com/Speed-Racer-65/1962-ferrari-gto-/dsc00093.html]
[URL=http://public.fotki.com/Speed-Racer-65/1962-ferrari-gto-/dsc00090.html]
[URL=http://public.fotki.com/Speed-Racer-65/1962-ferrari-gto-/dsc00091.html]
[URL=http://public.fotki.com/Speed-Racer-65/1962-ferrari-gto-/dsc00100.html]
[URL=http://public.fotki.com/Speed-Racer-65/1962-ferrari-gto-/dsc00097.html]
PostSubject: Re: 1962 Ferrari 250 GTO Penske Mecum Racer    Mon 07 Dec 2015, 4:19 pm
Which kit is it Mitch?
PostSubject: Re: 1962 Ferrari 250 GTO Penske Mecum Racer    Mon 07 Dec 2015, 7:49 pm
Revell
BrentH
PostSubject: Re: 1962 Ferrari 250 GTO Penske Mecum Racer    Wed 09 Dec 2015, 12:56 am
Nice work Mitch, so much detail! Love it!
» Stickers For A Lego Racers Ferrari
» 1962 RCA issue
» Rebuilding a Black Widow, mouse racer style.
» fujimi - ferrari f430 scuderia (1/24)
» 1963 mattel vrroom racer
