 1955 Ford PU Street Rod
PostSubject: 1955 Ford PU Street Rod   Thu 29 Oct 2015, 10:29 pm
I started a new project yesterday based on this kit.
The first thing I did was cut the styrene floor of the bed out.
I then made a new floor for the bed out of oak strips that I cut on my band saw.  I glued them into I-beam shaped styrene.  The oak was stained and finished and the styrene then covered with BMF.
I am toying with the idea of chopping the top about 3 scale inches and would be interested in what you guys think.
I thought going through my mind is that if I chop the top it might cause the front end to look out of proportion and I may have to section the body to make it look right.  As always, suggestions welcome.
RonRyan
RonRyan
PostSubject: Re: 1955 Ford PU Street Rod   Fri 30 Oct 2015, 3:23 am
I like that wood... looking forward to seeing more
Ron
PostSubject: Re: 1955 Ford PU Street Rod   Fri 30 Oct 2015, 12:28 pm
From other trucks with mild chops I've seen, it will work well.  The Monogram line of models was always pretty basic with not great detail or optional parts.  Sometimes even bodies looked out of proportion.  Improving the kit and making it your own will be interesting.  Go for it!
PostSubject: Re: 1955 Ford PU Street Rod   Fri 30 Oct 2015, 5:15 pm
popcorn
PostSubject: Re: 1955 Ford PU Street Rod   Fri 30 Oct 2015, 5:49 pm
Started the chop today.  It's at this point I always get really concerned because it is so, so, so ugly.  It usually works out though; hopefully it will this time!
Like I said, UGLY!!!!  Bear with me, I think I can make it look right
PostSubject: Re: 1955 Ford PU Street Rod   Sat 31 Oct 2015, 4:27 am
If all else fails you already have the plan B of chopping the top right off. The bed look good too btw.
PostSubject: Re: 1955 Ford PU Street Rod   Sat 31 Oct 2015, 10:52 am
I didn't get here in time, but, I will always vote for a top chop.
Gonna be great !!!
PostSubject: Re: 1955 Ford PU Street Rod   Sat 31 Oct 2015, 6:23 pm
Ditto what Clay said.
PostSubject: Re: 1955 Ford PU Street Rod   Sat 31 Oct 2015, 7:33 pm
Hi John,
I'm in Sir, love the wood bed...
Andy... popcorn
PostSubject: Re: 1955 Ford PU Street Rod   Sun 01 Nov 2015, 3:42 am
Got to spend some time on the top today.  I managed to get rid of most of the Ugly, but still have a way to go before I can call it done.
I hope to get to spend some time on it tomorrow which should finish up the chop.
PostSubject: Re: 1955 Ford PU Street Rod   Sun 01 Nov 2015, 3:45 am
looking much better John.
PostSubject: Re: 1955 Ford PU Street Rod   Sun 01 Nov 2015, 4:34 pm
Getting there, Good Job, John.
PostSubject: Re: 1955 Ford PU Street Rod   Sun 01 Nov 2015, 5:17 pm
The FUGLY is going John but the roof still looks a tad too wide!
PostSubject: Re: 1955 Ford PU Street Rod   Sun 01 Nov 2015, 5:34 pm
You have a sharp eye Al. You're right, it is a smige too wide. I'm hoping to take care of that with a sanding stick.
PostSubject: Re: 1955 Ford PU Street Rod   Sun 01 Nov 2015, 5:42 pm
Hmmmmmmmmmm...... I don't think that will do it John. It's short on the inside. Good luck anyway.
PostSubject: Re: 1955 Ford PU Street Rod   Sun 01 Nov 2015, 5:45 pm
I agree with Al, your filer strip is two wide
PostSubject: Re: 1955 Ford PU Street Rod   Sun 01 Nov 2015, 10:24 pm
Here you go guys.  I spent some more time on the top today and I think the width problem is pretty much solved.
There is still sanding, shaping and filling to be done, but I think it is coming together.
PostSubject: Re: 1955 Ford PU Street Rod   Wed 04 Nov 2015, 5:48 am
It looks much better now John. Getting it smooth and shapely will be no problem for you.
PostSubject: Re: 1955 Ford PU Street Rod   Wed 04 Nov 2015, 5:38 pm
Sweet, looks like it will be a cake walk from there.
PostSubject: Re: 1955 Ford PU Street Rod   Fri 06 Nov 2015, 3:46 pm
The chop is complete and the cab has been painted.
There is still a bit of clean up to be done, but it will have to wait until the paint gasses out.  This is going on hold for a week or so while I complete a couple of small dioramas.  I should get back to it about the middle of the month.
PostSubject: Re: 1955 Ford PU Street Rod   Fri 06 Nov 2015, 4:03 pm
Hi John,
WOW, that has come out beautiful Sir...
Andy... popcorn
PostSubject: Re: 1955 Ford PU Street Rod   Fri 06 Nov 2015, 4:54 pm
Great looking in red, John.
PostSubject: Re: 1955 Ford PU Street Rod   Fri 06 Nov 2015, 5:35 pm
John, that rocks, Super job on the body work and the paint.
PostSubject: Re: 1955 Ford PU Street Rod   Fri 06 Nov 2015, 6:58 pm
ooooohhhh shiney !!!
Nice paint job John ... for a red thats pretty awesome in fact
PostSubject: Re: 1955 Ford PU Street Rod   Sat 07 Nov 2015, 12:51 am
That is super sweet John !!
» Revell/Monogram Ford T Street Rod
» 1934 Ford Pickup--RatRod
» 1930 Ford Model A Coupe
» 1969 Ford Galaxie 500XL
» 1955 Chevy Cameo Pickup (Chopped + Jacked rear)
